Vincent Audio’s SA-T7 MK Tube Preamplifier Adds Bluetooth
Looking for a high-end streaming pre-amplifier that can be the hub of your system with a power amplifier or pair of active loudspeakers? You may want to check out the Vincent Audio SA-T7 MK.
Vincent Audio SA-T7 MK Preamplifier Silver Front Angle
Vincent Audio’s range of integrated amplifiers, pre-amplifiers, and phono stages don’t get enough love from the Hi-Fi press and that’s slightly weird to us. The German manufacturer has been around for years and we had nothing but praise for the Vincent Audio SV-737 Integrated Amplifier that I reviewed back in 2021.
The build quality is superb and it belongs on any audition list if you can afford the $3,500 USD asking price. Not inexpensive but a very solid piece of engineering.
The one hole in the lineup has been a streaming pre-amplifier that can be used with any power amplifier or pair of active loudspeakers like the ATC SCM40A that we just reviewed last month.
Vincent Audio SA-T7 MK Preamplifier Black Front Angle
The Vincent Audio SA-T7 MK is available in black of silver.
Not offering some form of streaming capabilities in 2023 is the kiss of death for some products and it would appear than Vincent Audio understands that the market wants it.
The new SA-T7 MK features the same audiophile-grade circuitry and renowned sound quality as its predecessor, but with the added benefit of a built-in Bluetooth receiver.
“The SA-T7 was one of Vincent Audio’s most popular pre-amps,” says Steve Niemi, Director of Global Sales, Pangea Audio, LLC. “And, with the addition of Bluetooth, the updated version will handle nearly any source imaginable. The SA-T7 MK will bring out the best of any recording.”
Vincent Audio SA-T7 MK Tube Preamplifier Front Silver
Vincent Audio SA-T7 MK Tube Preamplifier Front Black
Available in both black and silver, the new SA-T7 MK (MSRP: $3,499.95) features the original circuitry as the previous version, with the same outstanding sonic output. Linear amplification is combined with extreme low-noise characteristics, thanks in part to the BestPentode-circuit that eliminates the electrical current noise often associated with pentode tubes.
The BestPentode stage employed on the SA-T7 MK boasts a much higher gain with less noise than comparable triodes. The tubes, including 85A2, 6SCH9P, and 6SCH51P grid pentodes, are notable for amplifying high frequency signals.
The SA-T7 MK features connections for a wide range of analog and digital audio sources, accommodating both analog and digital. Included are six stereo RCA-type connections, one Toslink optical digital connection, and one coax digital connection. Internally, there is a PCM 5100-based DAC providing 24-bit/192 kHz performance. Compatible audio formats include WAV, FLAC, APE, LPCM, MP3, AAC, AC3, and WMA music files.
Vincent Audio SA-T7 MK Tube Preamplifier Black Rear
The addition of Bluetooth 5.0 allows listeners to wirelessly stream high-resolution audio files to the preamplifier. In addition, the front panel received a cosmetic upgrade, with a new modern, elegant appearance.
Extremely pure audio transmission is accomplished with a low-noise power supply couplings of the BestPentode stage. Vincent Audio developed a proprietary module for this stage, called Vimala, the Sanskrit term for, “pure, transparent, clear.” A second gain stage, featuring the 6H9P, 6H51P, 6S3P-EV, and Vimala modules, affords precision control over treble and bass, though tone controls can be bypassed in order to hear the purest music signal.
Vincent Audio VRC-13 Remote Control
SA-T7 MK Specifications
  • Frequency Response: 10Hz – 100kHz +/- 0.1dB
  • Output Voltage: 3V
  • T.H.D.: <0.001% (1kHz, Output Voltage 2Veff on 10 K Ohm)
  • Amplification: typ. 13.3 dB (Volume control max. Gain)
  • Input Sensitivity: 430mV (for 2V Output Voltage)
  • Signal-to–Noise Ratio: typ. >100dB (A)
  • Impedance: >22kOhm
  • Tubes: 2 x 6H9P, 2 x 6H51P, 4 x 6S3P-EV; 1 x 85A2
  • Dimensions: 16.9″ wide x 5.3″ high x 14.5″ deep
  • Weight: 18.7 lbs. (8.5 kg)
  • Color: Black, Silver
For more information: vincent-tac.de
Related reading: Vincent SV-737 Integrated Stereo Amplifier Review
1 Comment
1 Comment
  1. Jonas
    March 14, 2023 at 2:13 pm
    No headphone amp? Pffft… That should have been mandatory on a 3.5k usd preamp
Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Ask an Expert
Just what is a network streamer? Our explanation and 9 digital streaming options from $99 to $2,500 that offer the best for less.
Digital Music Systems
At $4,000, the McIntosh DS200 is a high-end music streamer with HDMI ARC, TIDAL Connect, and a Quad Balanced 8-channel, 32-bit DAC.
SV-500 MK Adds HDMI ARC and Bluetooth 5.0 Connectivity and outputs 50 watts per channel for $1,500.
At $1,999, the Technics HA-507 is a pure analog headphone amplifier and preamplifier with a balanced/dual mono configuration.
At $3,680, the Eversolo DMP-A10 music streamer packs in so much it just may be the Swiss Army Knife of network streamers.
Cambridge Audio introduces the EXA100 stereo integrated amplifier for $2,199 and the EXN100 Network Music Streamer for $1,799.
The SR11 joins the K11 DAC and headphone amp to create a powerful, compact sound system at an affordable price point. WiiM rival for...
Can the $1,600 Denon DNP-2000NE Network Player measure up to the competition in a very crowded category?
