Vincent Audio SA-T7 Diamond Tube Preamplifier Features Ultra-rare PCF803 Telefunken Tubes
At $3,995, the SA-T7 Diamond from Vincent Audio features German PCF803 Telefunken Tubes and built-in Bluetooth.
Vincent Audio SA-T7 Diamond Tube Preamplifier Silver Front
Vincent Audio, the German designer and manufacturer of elegant high-fidelity stereo and multichannel components, announced today the limited production run of the new SA-T7 Diamond, a tube preamplifier featuring prized German Telefunken tubes manufactured decades ago.
SA-T7 Diamond Overview
The new SA-T7 Diamond features the same audiophile-grade circuitry as the SA-T7 MK, which utilize 85A2, 6SCH9P, and 6SCH51P grid pentode tubes. Both tube preamps also include a built-in Bluetooth receiver. However, the SA-T7 Diamond makes use of hard to find Telefunken PCF803 tubes, which claim to offer an even greater sense of musicality.
Vincent Audio SA-T7 Diamond Tube Preamplifier Black Front
“The SA-T7 Diamond represents a once-in-a-lifetime opportunity to experience one of the most esteemed tubes in audio incorporated in a product that is a perfect match for their unique characteristics,” says Steve Niemi, Director of Global Sales, Pangea Audio, LLC. “No fewer than four PCF803 tubes contribute to the outstanding sonic characteristics of the SA-T7 Diamond.”
Designer, Frank Blöhbaum says the SA-T7 Diamond offers much higher gain with less noise than comparable triodes, thanks in part to the BestPentode-circuit he developed.
Extremely pure audio transmission is accomplished with a low-noise power supply coupling of the BestPentode stage. Vincent Audio developed a proprietary module for this stage, called Vimala, the Sanskrit term for, “pure, transparent, clear.” A second gain stage affords precision control over treble and bass, though tone controls can be bypassed in order to hear the purest music signal.
Vincent Audio SA-T7 Diamond Tube Preamplifier Silver Rear
The SA-T7 Diamond features connections for a wide range of analog and digital audio sources, accommodating both analog and digital. Included are six stereo RCA-type connections, one Toslink optical digital connection, and one coax digital connection. Internally, there is a PCM 5102-based DAC providing 24-bit/192 kHz performance.
Bluetooth 5.0 allows listeners to wirelessly stream high-resolution audio files to the preamplifier.
Comparison
SA-T7 DiamondSA-T7 MK
MSRP$3,995$3,499
Frequency Response10Hz – 100kHz +/- 0,1 dB10 Hz – 100 kHz ±0.1 dB
Output Voltage3 V3 V
T.H.D.< 0,001 % (1 kHz, Output Voltage 2Veff an 10 KOhm)< 0.001 % (1 kHz, Output Voltage 2Veff at 10 kOhm)
Amplification typ.Typical 13.3 dB (Volume Controller max. Gain)Typical 13.3 dB (Volume Controller max. Gain)
Input Sensitivity430 mV (2V Output Voltage)430 mV (for 2 Volt Output Voltage)
Signal-to-Noise Ratio (typ.)> 100dB (A)> 100 dB (A)
Input Impedance22 kOhm> 22 kOhm
Inputs6 x Stereo RCA
1 x Optical
1 x Coaxial
1 x Bluetooth
6 x Stereo RCA
1 x Optical
1 x Coaxial
1 x Bluetooth
Max. Power Consumption:58 watts58 watts
Outputs2 x Stereo RCA Pre-Out
1 x Stereo RCA Rec-Out
2 x 3.5 mm Jack (Power Control)
2 x Stereo RCA (Pre Out)
1 x Stereo RCA (Rec Out)
Tubes4 x Telefunken PCF 803
1 x 85A2
2 x 6SCH9P
4 x 6SCH51P
4 x 6SCH9P
1 x 85A2
Playable Digital FormatsWAV, FLAC, APE, LPCM, MP3, ACC, AC3, WMAWAV, FLAC, APE, LPCM, MP3, ACC, AC3, WMA
ColorBlack / SilverBlack / Silver
Weight8.5 kg (18.7 lbs)8.5 kg (18.7 lbs)
Dimensions (WxHxD)430 x 135 x 370 mm430 x 135 x 370 mm
Price & Availability
The Vincent Audio’s SA-T7 Diamond tube preamplifier is available now for $3,995 at Audio Advisor in black or silver.
The Vincent Audio SA-T7MK is available for $3,499 at Amazon.
2 Comments
2 Comments
  1. ORT
    March 20, 2024 at 12:58 am
    I now have “tube envy”. Not to be confused with any other form of “envy”. For example I have always wanted to play the piano bu never wanted to learn, ergo it could be said that I have…wait for it…”Pianist Envy”.
    Yup. My mom would have me watch two films whenever they were on TV back in the days of (mostly) black & white – “Pygmalion and My Fair Lady”.
    “Remember that you are a human being with a soul and the divine gift of articulate speech…” I was already familiar with the Greek Myth upon which both were primarily based and it is a favorite of mine: “Pygmalion and Galatea”.​​​​
    R A M B…L I N…Ramblin’!​
    ​What hath this to do with tubes, you say?! Nothing.
    And everything. Because many tubes are beautiful in the way that Galatea was. Created by human hand to be perfect. Beautiful beyond words, even when one has be given the divine gift of articulate speech.
    I am SpORTicus!
    • Ian White
      March 20, 2024 at 11:20 pm
      ORT,
      LOL.
      Ian White
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
At only $279, the Schiit Saga 2 Preamplifier claims to be the best volume control in the world.
Looking for a high-end streaming pre-amplifier that can be the hub of your system with a power amplifier or pair of active loudspeakers? You...
Vincent Audio's SV-237MK II Hybrid Integrated Amplifier offers the best of vacuum tube and solid-state design with Bluetooth thrown in.
The Chord ULTIMA PRE 3 leverages 30 years of amplifier building expertise, the latest in power supply technologies and a new fascia.
If the $2,500 Vincent Audio SV-228 Integrated Amplifier delivers the sonic fireworks of the pricier SV-737 -- it might be one to really consider.
An amplifier that has flown under the radar for far too long. The Vincent SV-737 Integrated Amplifier is the real deal.
The McIntosh C12000 Preamplifier goes both ways; tube and solid state and is the perfect companion to the MC3500 MMKII Tube Amplifier.
I’ll have a lot more to say about the Vincent SV-737 Integrated Tube Stereo Amplifier next week in the second part of my review...
