Vincent Audio SA-31MK Hybrid Vacuum Tube Preamplifier
Vincent Audio SA-31MK Hybrid Vacuum Tube Preamplifier - Back
Vincent introduces a step-up version of its most popular stereo preamplifier with added remote control and improved Class A vacuum tube output stage.
Vincent Audio has introduced the SA-31MK a higher performing step-up version of its popular SA-31 hybrid solid-state, vacuum tube line-stage preamplifier. The new SA-31MK incorporates new output circuitry with two more vacuum tubes, precision European resistors and capacitors, electronic volume and input controls, two added line inputs, and the addition of a wireless remote control.
The Vincent SA-31MK is clearly much more than just an upgrade of the SA-31’s convenience features. The output stage incorporates a proprietary new design configuration with a short signal path using two 6N16 vacuum tubes that allow a detailed and delicate soundstage. The final output stage is a Pure Class A design using two additional 6N16 tubes. The new SA-31MK has a very substantial power supply with a large toroidal power transformer that ensures all the circuit elements have a rock-steady voltage supply and never lack for current when needed.
The SA-31MK adds full wireless remote control capabilities with a precision electronic volume control, and six remote-selectable line inputs.
The new Vincent SA-31MK is currently available in black or silver at a suggested retail price of $1,399.95. The SA-31 continues in the line at $649.95.
Vincent Audio SA-31MK Hybrid Vacuum Tube Preamplifier - Inside
Vincent Audio SA-31MK Preamplifier Specifications
  • Frequency response: 20 Hz – 50 kHz +/- 0.5 dB,
  • Output voltage: 2 V
  • Total harmonic distortion: < 0.1 % (1 kHz, 1 Watt)
  • Input sensitivity: 350mV
  • Signal-Noise ratio: > 95 dB
  • Input impedance: 47 kOhm
  • Inputs: 6 x RCA
  • Outputs: 2 x RCA, 1 x RCA Rec Out
  • Tubes: 4 x 6N16
  • Color: black/silver
  • Mains supply: 120 V/60 Hz,
  • Weight: 18 lbs, 8 kg,
  • Dimensions (WxHxD): 17 x 3-3/4 x 14-3/8 inches; 430 x 95 x 365 mm
About Vincent Audio
Vincent Audio manufactures high-end audio components that use vacuum tube and hybrid tube/solid-state technology to produce sound that is powerful, accurate, and texturally satisfying. The brand’s exclusive North American distributor is WS Distributing, LLC, of Grand Rapids, Michigan.
Pro-Ject Audio CD Box RS2 Tube Silver CD Player
CD Players
Pro-Ject’s CD Box RS2 Tube doubles down on Red Book CDs with a balanced tube stage—no SACD, no digital inputs, and a $2,300 price...
Backert Labs Optik Phono 1.1 Backert Labs Optik Phono 1.1
Backert Labs’ $11,500 Optik Phono 1.1 targets DS Audio optical cartridges and five-figure turntables—impressive at shows, uncompromising in design, and firmly not for casual...
2026 Samsung Music Studio Series Speakers 2026 Samsung Music Studio Series Speakers
Samsung will preview its 2026 audio lineup at CES, highlighting new Q Series soundbars, Music Studio Wi-Fi speakers, Q Symphony integration, and Sound Towers...
HumminGuru EZ Record Washer Package HumminGuru EZ Record Washer Package
HumminGuru’s EZ Vinyl Record Washer targets Spin-Clean with a more refined manual cleaner—effective, easy to use, and price will determine its appeal.
Hisense PX4-PRO UST Projector Hisense PX4-PRO UST Projector
Hisense previews the PX4-PRO UST projector ahead of CES 2026, promising 200-inch images, higher brightness and contrast, built-in Atmos audio, and a flexible alternative...
Hisense XR10 High-end Lifestyle 4K Laser Projector Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
