Vincent Audio KHV-111MK Hybrid Tube Headphone Amplifier
Vincent Audio has introduced a high-quality headphone amplifier that uses a hybrid of vacuum tube and solid-state circuitry to enable serious headphone listeners to get the most pleasure out of their music.
The Vincent Audio KHV-111MK headphone amplifier combines premium solid-state discrete component circuitry with a classic 12AX7 vacuum tube input stage that is ideally matched to the headphone use. The 12AX7 is a two-channel, pure Class A triode vacuum tube noted for its high gain, accuracy and musical character.
With the higher operating voltages of vacuum tubes, and the different requirements of the solid-state sections, Vincent Audio gave the KHV-111MK a very large and stable power supply section. With the combined weight of the power supply combined with the heavy-duty chassis used to shield the sensitive circuitry, the KHV-111MK weighs in at a hefty 7 pounds, well above that of most headphone amplifiers.
Vincent Audio KHV-111MK Hybrid Tube Headphone Amplifier - Black
The Vincent KHV-111MK has separate, front-panel volume controls for the left and right channels, a front 1/4-inch headphone jack, power switch, and a window to monitor the glow of the vacuum tube filament. The rear-panel has gold-plated stereo RCA input jacks.
KHV-111MK Hybrid Tube/Solid-state Headphone Amplifier Features & Specifications
  • Hybrid vacuum-tube / solid-state design
  • Vacuum tube input stage
  • Tube compliment: 1 x 12AX7 (two channels)
  • Separate volume control for each channel
  • Heavy-duty chassis construction
  • Choice of Black or Silver faceplate
  • Front-panel filament inspection window
  • Oversized power supply
  • One RCA rear-panel stereo input
  • One front-panel 1/4″headphone output jack
  • Nominal output power: 5 Watts
  • Harmonic distortion: < 0.1 % (1 kHz, 1 Watt),
  • Input sensitivity: 5 mV
  • Signal-Noise ratio: > 90 dB,
  • Inputs: 1 x RCA
  • Dimensions (WxHxD): 8.5″ x 3.75″ x 12″
  • Weight: 7lbs
The Vincent KHV-111MK is currently available in black or silver finish, and with a suggested retail price of $499.95.
About Vincent Audio
Vincent Audio manufactures high-end audio components that use vacuum tube and hybrid tube/solid-state technology to produce sound that is powerful, accurate, and texturally satisfying. The brand’s exclusive North American distributor is WS Distributing, LLC, of Grand Rapids, Michigan.
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
