Viewsonic’s X2-4K Projector is the first Projector “Designed for Xbox”
Xbox users who desire a much larger gaming experience that can also be taken outside need to check out the Viewsonic X2-4K Projector.
Viewsonic X2-4K Gaming Projector Xbox Game Play
Are you looking to expand your gaming experience this summer? ViewSonic has announced the X2-4K, the world’s first “Certified for Xbox” projector as part of Microsoft’s “Designed for Xbox” program which includes several third-party branded products including controllers, gamepads, racing wheels, headsets, and more.
X2-4K Xbox Support
Viewsonic X2-4K Gaming Projector Tilted
Xbox certification means that the Viewsonic X2-4K is designed to support the best possible gameplay from Xbox gaming consoles with the following gaming-centric features:
  • Native 1440p resolution at a 120 Hz refresh rate experience from either of the Xbox Series X|S consoles.
  • The X2-4K can output native 4K @ 60Hz and 1080p @ 240Hz with a 4.2ms response time for the fastest possible player reaction times for the PC gaming audience. Auto Low Latency Mode (ALLM) is also supported. This allows users to choose an “Ultra-Fast Input” with 1/10th of the delay compared to the average 4K UHD TV.
  • The Xbox Series X|S consoles can use HDMI Consumer Electronics Control (CEC) to send commands to and from CEC-enabled devices, which includes the X2-4K. This allows Xbox users via the gaming controller, to turn the power on/off on the X2-4K as well as control the volume.
Tip: In addition to Xbox, HDMI-CEC works with other current gaming consoles and X2-4K.
From Mia Shen, Sr. Business Line Manager at ViewSonic: “The X2-4K projector was developed to be considered a true gaming projector…It went through 63 tests conducted by Team Xbox to ensure ultimate console compatibility and is designated as the world’s first ‘Designed for Xbox’ certified projector.
Additional X2-4K Projector Highlights
The projector comes with a short throw lens with an adjustable 0.69-0.83 throw ratio, H/V keystone correction, and 4-corner adjustment capabilities
Tip: The X2-4K can project a 100-inch image from a distance of 5 feet.
UST vs. Short Throw Distance from Screen Comparison
The X2-4K also has TÜV SÜD’s Low Blue Light Certified. This is great for gamers and it means that you will not suffer eye damage or discomfort caused by prolonged viewing.
For audio, the X2-4K includes integrated dual Harman Kardon speakers. The projector also has a 3.5 mm analog audio output for connecting to an external soundbar, AVR, or compatible powered speakers.
Tip: Just like TVs, sound systems built-into projectors don’t provide the optimum audio experience.
Viewsonic X2-4K Gaming Projector Front/Rear
Viewsonic X2-4K Specifications
  • Imaging Chip: Single Chip DLP
  • Light Source: RGB LED
  • Light Source Life: Up to 60,000 hours
  • Display Resolution: 4K (3840×2160) via pixel shifting
  • PC/MAC Resolution (max): 3840 x 2160 (UHD)
  • PC/MAC Resolution (min): 640 x 480 (SD)
  • Brightness (Lumens): 2,900 LED Lumens/2,150 ANSI Lumens
  • Screen Size (Diagonal): 60 – 120 in. / 1.5 – 3.0 m
  • Throw Distance: 3 to 7 ft (100-inch image @ 5 ft)
  • Throw Ratio: 0.69-0.83
  • Keystone Correction: Vertical (+/- 40º) / Horizontal (+/- 40º)
  • Lens: 1.2x optical zoom
  • Color Depth: 1.07 Billion Colors
  • Dynamic Contrast Ratio: 3,000,000:
  • Aspect Ratio: 16:9 (Native)
  • Input Lag: 37ms
Viewsonic X2-4K Gaming Projector Connections
Wired Connectivity
  • (1) USB 2.0 Type A
  • (1) USB Type C
  • (1) 3.5mm Audio Out
  • (1) Control (RS232)
  • (1) HDMI 1.4 In
  • (1)  HDMI 2.0 In
Viewsonic X2-4K Gaming Projector Bluetooth
Wireless Connectivity
  • Wifi: 5Gn
  • Bluetooth ver 4.2 Audio-in
  • Bluetooth ver 4.2 Audio-out
Viewsonic X2-4K Gaming Projector Controls
Control
  • Physical Controls: Keypad, Power key – Wireless Remote control also included.
  • On-Screen Display: Display, Image, Power Management, Basic, Advanced, System, Information (See user guide for full OSD functionality
  • Dimensions (WDH): 13.9 x 9.9 x 4.8 inches/355 x 251 x 121 mm
  • Net Weight: 7.9 lbs/3.6 kg
Remote Control for Viewsonic X2-4K Gaming Projector
Package Contents
  • X2-4K projector
  • Power cable
  • Remote control
  • Quick Start Guide
Pricing and Availability
The Viewsonic X2-4K has a list price of $1,709.99 (US) at Viewsonic.com
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Ask an Expert
If you can't get picture or sound from your TV or projector don't despair. Here are some debugging tips from our resident home theater...
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
Digital Music Systems
At $999, the FiiO S15 Network Music Streamer offers up to 768kHz/32-bit, DSD512 via USB, with support for Optical, HDMI and Bluetooth.
Epson's crusade against misleading specifications forces AWOL and JMGO to correct lumens output ratings on some of their projectors.
HDTV 4K & 8K TV
Amazon introduces top-of-the-line Omni Series Mini-LED QLED 4K TVs in sizes from 55 to 85-inches at affordable price points.
At $499, the TCL A1 is a 1080p portable lifestyle projector that lets you bring big screen entertainment wherever you go.
