ViewSonic V350 Dual SIM 3G Smartphone
ViewSonic announced the V350 dual SIM 3G Smartphone which allows two SIM cards to be used simultaneously. The V350 runs Android 2.2 and includes a 5-megapixel camera, wireless B/G support and a bright clear 3.5″ screen.
Business users can keep business and personal calls and data separate. International travellers can keep their current number, while getting a local SIM card to save on expensive international roaming charges.
The ViewSonic V350 features GPS/AGPS and gravity sensor functions to enable navigation and location finding. The built in sensors detect device orientation to maximize viewing area and provide access to augmented reality applications.
The fast 600MHz Qualcomm MSM7227 processor, 512MB memory and a slot up to 32GB Micro SD card provide the usual expansion options. A unique ViewScene3D home screen implements a 3D menu to slide to various options.
Price and Availability
The ViewSonic V350 Dual SIM 3G smartphone is available for £249.99 at Amazon UK.
See more about: Smartphones, ViewSonic
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
