ViewSonic PJD7820HD DLP Projector
ViewSonic announced a Full HD 1080p DLP projector with 3,000 ANSI lumens and 15,000:1 contrast ratio for under $700. The new PJD7820HD projector is packed with features including 3D Blu-ray ready capability, the latest HDMI connection, multiple PC and video input options (dual VGA, composite, S-video, RS232, VGA/audio out), 1.3x optical zoom, vertical keystone correction and an integrated speaker. Designed as a business office projector, the PJD7820HD is perfect for displaying graphic intensive applications, CAD engineering drawings or high-def multimedia files. Plus, the versatile PJD7820HD can also be used for watching Blu-ray movies. Add in a filter-less design and a DynamicEco “standby” energy-saving mode reducing brightness down to 30 percent when the projector is not in use, the PJD7820HD delivers enhanced product reliability and virtually zero maintenance.
[youtube id=”7uV4g3_Fr0s” width=”610″ height=”373″]
ViewSonic’s PJD7820HD projector with BrilliantColor technology features multi-color processing to produce stunning, vibrant colors. Its sophisticated 6-segment color wheel enhances the yellow color performance that is the key to accurate and vivid color reproduction. With multi-color processing, colors are richer and more vibrant with exquisite and precise detail. In addition, ViewSonic claims 6000 hours of lamp life.
“Our new PJD7820HD offers best in class price-performance for a Full HD 1080p DLP projector on the market today, making it the ideal crossover model for both SMBs and home office consumer use,” said Roger Chien, product manager for ViewSonic.
Price and Availability
The ViewSonic PJD7820 DLP projector will be available in North and Latin America in late February 2013 for $699. It comes with a three-year limited parts and labor and one-year lamp warranty, along with Express Exchange Service.
DISPLAY SPECIFICATIONS
  • Type: 0.65″ Digital Micromirror Device (DLP)
  • Resolution: 1080p 1920×1080 (native)
  • Lens: 1.3x manual optical zoom / manual optical focus
  • Zoom Factor: N/A
  • Keystone: Manual vertical digital keystone correction (+/- 40º)
  • Display Size: 30 – 300 in. / 0.7 – 7.6 m (diagonal)
  • Throw Distance: 2.5 – 25.0 ft. / 0.8 – 7.6 m
  • Throw Ratio: 1.15~1.5:1
  • Lamp Type: 210 watt
  • Lamp Life (normal/eco-mode): 4000 / 6000 hours* (Normal / Eco-mode)
  • Brightness: 3000 Lumens
  • Contrast Ratio: 15,000:1 (w/DynamicEco)
  • Aspect Ratio: 16:9 (native)
  • Color Wheel: 6-seg RGBCYW / 7200rpm
  • Color Depth: 30 bits, 1.07B Color (10+10+10)
  • Color Gamut: N/A
INPUT SIGNAL
  • Computer and Video: NTSC M (3.58 MHz), 4.43MHz, PAL (B, D, G, H, I, M, N, 60), SECAM (B, D, G, K, K1, L), SD 480i and 576i, ED 480p and 576p, HD 720p, 1080i, 1080p
  • Frequency: Fh: 31–100KHz, Fv: 48–120Hz
COMPATIBILITY
  • PC: VGA to 1920×1200
  • Mac: Up to 1920×1200 (may require MAC adaptor)
ViewSonic PJD7820HD DLP Projector - back
CONNECTOR
  • Audio Input: 3.5mm mini jack
  • Audio Out: 3.5mm mini jack
  • RGB Input: 15-pin mini D-sub (x2)
  • Composite Input: RCA jack
  • S-Video Input: 4-pin mini-DIN
  • Component: 15-pin mini D-sub (x2, shared with RGB)
  • RGB Output: 15-pin mini D-sub
  • Control: RS-232 (DB-9)
  • Digital: HDMI (x1)
  • Network: N/A
  • USB: Mini Type B (mouse control and service)
  • Mic-In: N/A
  • Screen Trigger: N/A
  • Card Reader: N/A
AUDIO
  • Speakers: 2-watt (x1)
  • Amplifier: N/A
POWER
  • Voltage: 100~240VAC (Auto Switching), 50/60Hz (universal)
  • Consumption: 260W (typ) / <0.5W (Stand-by mode)
CONTROLS
  • Basic: Power, keystone/arrow keys, left/blank, menu/exit, right/panel key lock, mode/enter, auto, source
  • OSD: Display, Picture, Source, System Setup (Basic), System Setup (Advanced), Information (See user guide for full OSD functionality)
OPERATING CONDITIONS
  • Temperature: 32°F–104°F (0°C–40°C)
  • Humidity: 10%–90% (non-condensing)
  • Altitude: 0~6,000 ft (1,800m), operational up to 10,000 ft (3048m)
NOISE LEVEL
  • Normal: 35dB
  • Eco-Mode: 29dB
DIMENSIONS (WxHxD)
  • Physical: 10.6 x 3.3 x 8.7 in. / 268 x 84.4 x 221 mm
  • Packaging:
  • 14.2 x 12.8 x 7.4 in. / 360 x 325 x 188 mm
WEIGHT
  • Net: 4.6 lbs. / 2.1 kg
  • Gross: 7.5 lbs. / 3.4 kg
2 Comments
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
