Victrola’s Stream Carbon Wireless Turntable Wants To Dance With Your Sonos Speakers
Wireless audio and vinyl playback converging? Sonos and the Victrola Stream Carbon Wireless Turntable are an interesting partnership.
Victrola Stream Carbon Turntable with White Sonos Wireless Speaker
Victrola and Sonos? The convergence of vinyl playback and wireless audio? The Victrola Stream Carbon Wireless Turntable makes more sense than you think. A partnership with Sonos was a brilliant idea.
According to a recent report, the renewed popularity of vinyl records over the past few years shows no sign of letting up. This means that along with vinyl records the demand for turntables needed for playing records has returned as a viable product category.
Victrola Stream Carbon Turntable with Black Sonos Wireless Speaker
How You Normally Connect A Turntable
Typically turntables need to be physically plugged into an audio system in order for you to listen to your records unless you have an integrated record player system such as the Victrola Premiere VT, +Audo +Record Player, or Andover–One or –One E
Turntable connection options may include standard phono connections which require the audio system to have a built-in phono preamp, or, if it doesn’t, you may have to connect an external phono preamp between the turntable and the audio system. However, that creates more connection clutter.
To make things easier, a growing number of turntables incorporate a phono preamp which allows connection to any audio system that has an available analog audio input. Some turntables even have USB outputs, for playing on a PC or transferring vinyl to a digital storage device via a PC, but you still have to use a connection cable.
Wireless Turntable Connection Options
Some turntables provide built-in Bluetooth or you can get a Bluetooth transmitter/receiver adapter kit. However, the quality of Bluetooth audio varies depending on what Bluetooth version is being used.
Another solution is Wi-Fi. Back in 2018, Yamaha introduced a Wi-Fi-enabled streaming turntable, the Vinyl500 which is still available. However, it is limited to use with Yamaha’s MusicCast System.
However, for 2022, Victrola and Sonos have teamed up to offer a  wireless streaming turntable that works within the Sonos infrastructure, which not only includes Sonos-branded products, but Sonos-enabled wireless speakers from IKEA and select home theater receivers from Onkyo, Integra, and Pioneer Elite
Victrola Stream Carbon Turntable Dark
Victrola has launched the Victrola Stream Carbon, a new multi-room vinyl listening solution that’s certified by the Works with Sonos program.
The Stream Carbon allows users to enjoy their record collection on a Sonos sound system with no additional equipment required, and be controlled within the Sonos app, creating an easy-to-use, whole-home vinyl listening experience.
The Victrola Stream Carbon features a sleek modern design with a carbon fiber tonearm, easy-to-adjust counterweight, machined aluminum headshell, and a premium Ortofon 2M Red cartridge.
How To Connect The Stream Carbon With Sonos
The Victrola Stream app provides easy setup and connects the Victrola Stream Carbon wirelessly to your Sonos system. Once set up, the turntable fully integrates with the Sonos app, allowing you to stream music from Stream Carbon to any compatible Sonos speaker (including the Sonos ARC, Beam, and Ray soundbars).
How Victrola Stream Carbon Turntable Works with Sonos Wireless Speakers
Tip: If you don’t have a Sonos System, you can also connect the Stream Carbon to any external audio system using Stream Carbon’s audio outputs. Since the Stream Carbon has a built-in phono preamp you aren’t restricted to traditional phono input connections.
Victrola Stream Carbon Turntable Top
Victrola Stream Carbon Turntable Front and Back
STEP 1: Download the Victrola Stream App (iOS, Android) for a step-by-step installation guide.
STEP 2: Assemble Turntable according to the illustrated instructions in the Victrola Stream App.
STEP 3: Plug in the Turntable and connect to Wi-Fi Network.
STEP 4: Connect your Victrola Stream Carbon to your Sonos system using the Victrola Stream App instructions.
STEP 5: Start streaming directly from your Victrola Stream Carbon using the Sonos App.
Setup Video
Core Features
  • Wirelessly stream vinyl to your entire Sonos system
  • 2-speed, belt-driven turntable with Victrola silicone slipmat plays all your favorite 33 1/3, and 45 rpm vinyl records.
  • The Victrola Stream app allows easy setup and adjustments
  • Includes Built-in Phono Preamp and RCA output for use with non-Sonos powered speakers or external audio systems.
Ortofon 2M Red Phono Cartridge
Victrola Stream Carbon Turntable Tonearm
Specifications
  • Mobel Number: VPT-3000-BSL
  • Turntable Type: Belt Drive
  • Platter: Die-Cast Aluminum
  • Speed Options (RPM):33-1/3, 45
  • Cartridge: Ortofon 2M Red
  • Tonearm Length: 225mm
  • Overhang: 18.5 mmm
  • Tracking Error Angle: <2 Degrees
  • Wow & Flutter: Less than .175 dB
  • Connections: Wireless (802.11A/B/G/N/AC), Wired (10/100 Ethernet)
  • Audio Outputs: RCA (built-in preamp)
  • AC Power: 100-240V/50HZ/60HZ
  • Exterior Construction: Carbon Fiber Tonearm, MDF (Medium Density Fireboard), Aluminum, Plastic
  • Color Finishes: Black, Silver
  • Dimensions (LWH): 13.58 x 16.93 x 4.37-inches)
  • Weight (with dust cover): 13.2 lbs
Availability and Pricing
The Victrola Stream Carbon is now available for pre-order for $799.99 at victrola.com and Crutchfield. It’s expected to ship October 15, 2022.
Victrola Stream Carbon Turntable with Black Sonos Wireless Speaker Front
Victrola Introduces Innovative Record Players and Bluetooth Speakers
Sonos Unveils The Sub Mini: Preview
The Sonos Ray Aims To Disintegrate The Affordable Soundbar Competition
Sonos Acquires Mayht To Develop Smaller Speakers That Really Sing
Sonos Beam 2 Soundbar With Dolby Atmos Is Easier On The Wallet
Sonos One SL: Simply Average Or The Best Wireless Kitchen Speaker Ever?
9 Comments
9 Comments
  1. Mike Cornell
    September 28, 2022 at 5:36 pm
    Kind of interesting. For $800, wish it had more substantial feet and a proper dustcover. Also seems to be missing a cue lever.
  2. ORT
    September 28, 2022 at 9:19 pm
    That “dustcover” is stooooopid. If for no other reason than the truth of that statement..P A S S.
    Denon uses a similar pieceapoo for its 400/450 ‘tables. Ridiculous and cheapass. Oh Wait! The Denon “dustcover” also works as an album holder.
    Wewease da Kwaken!
    ORT
    • Ian White
      September 29, 2022 at 12:56 am
      The dustcover looks like a knock-off of the Kuzma Stabi dustcover.
      Ian White
      • Mike Cornell
        September 29, 2022 at 11:50 am
        I think Rega has something similar as well.
        • Ian White
          September 29, 2022 at 1:19 pm
          Mike,
          Cambridge Audio has two wireless turntables. I’m reviewing one at the moment.
          Ian White
          • Mike Cornell
            September 29, 2022 at 5:22 pm
            I was referring to the so-called dust cover. But yes, Cambridge Alva turntables look interesting….looking forward to the review, Ian.
  3. ORT
    September 29, 2022 at 2:34 am
    I thought those Kuzmas were just a drop-down-on-it piece of nice, clear, thick acrylic? Those look classic and actually work, this thing is stupid and pretty much not pretty and totally useless. At least to me, it is.
    ORT
  4. David
    September 29, 2022 at 4:00 am
    Huh. Decidedly digital analogue playback. Perfect for Mo-Fi vinyl albums?
    Written with tongue firmly planted in cheek. Wink wink.
    • ORT
      October 3, 2022 at 12:24 pm
      Well done, Sir David!
      ORT
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Qobuz partners with ACT Music for an exclusive, high-res jazz experience, offering playlists, videos, and 24-bit downloads.
Loudspeakers
KLH Audio and Victrola now exist under the same umbrella keeping two legacy American Hi-Fi brands alive.
Home Video
Can a new video streamer save Sonos from a year of horrible missteps? Project Pinewood does not have us convinced - and now it...
Daily Deals
With the introduction of the Sonos ARC Ultra Soundbar - it is time to clear out the remaining stock of the original Sonos ARC
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Sonos ventures deeper into the business and commercial landscape with a variation of its ERA 100 wireless speakers with features specifically designed for that...
