Vertere DG-1S Turntable: The Death Star Is Approaching
Touraj Moghaddam has pulled back the curtain on the new Vertere DG-1S Turntable and we are more than just a little intrigued.
Vertere Acoustics have pulled back the curtains on an updated version of their award-winning Vertere DG-1S Turntable and the changes are not superficial; the unique design turned a lot of heads and raised some interesting questions about the suspension and tonearm when it was first introduced. The new changes are designed to take this turntable to another level of performance.
Touraj Moghaddam, CEO and Founder, has a long track record of innovation in the turntable category going back to the Roksan Xerxes, and there is a lot going on with the DG-1S that is definitely not conventional.
The job of a record player is very simple and very linear,” explained Touraj Moghaddam, “the most accurate measurement of something going past the stylus and throwing it from side to side over 1000 times every centimetre.”
The improvements to the Vertere DG-1S are designed to deliver higher resolution replay, greater dynamic contrasts, and improved stereo separation with greater precision while simultaneously keeping the musicality that the original DG-1 delivered.
Vertere DG-1S Turntable Tonearm on
Having had the opportunity to listen to the original Vertere DG-1 in two separate high-end audio stores in London, I was immediately impressed by the innovative tonearm that provides a very stable and adaptable platform for cartridges.
The choice of cartridge had me slightly perplexed; the DG-1 was sold with a rebadged Audio-Technica AT-VM520EB in a different body, and it felt like a rather inexpensive stock cartridge for such an expensive turntable.
You can certainly use a wide range of cartridges on the DG-1S and that is one of the benefits of the tonearm design.
The DG-1 is a lightweight design that delivers the presence and impact of a higher mass turntable like a VPI; just without a dense MDF plinth and 2-inch aluminum platter. It had an excellent sense of flow and detail and it felt rather obvious that the cartridge was holding the overall sound quality back.
Vertere DG-1S Turntable Rear
The DG-1 excelled in the low end and I was surprised that such a thin deck could compete with much more expensive designs in that regard. The industrial design is truly unique, but the sonic performance is the real star of the show.
The Vertere DG-1S will launch in September with the original Magneto cartridge for $4,995 USD; an increase of almost $1,000 over the original turntable when it was released over 3 years ago.
Upon closer inspection, the tonearm is actually more robust than the original design and we suspect that it works better now with a wider range of cartridges.
The design of the platter is also rather interesting; the markings help with cartridge alignment which is a rather clever touch.
One thing I still don’t like is the placement of the speed button which is far too close to the belt; it seems odd that it can’t be moved even a few centimeters from the button. Odd.
If you are in the market for a Rega Planar 8 or Planar 10, the DG-1S should most certainly be on your audition list. We hope to get a review sample in October and will share our thoughts when we do.
Vertere DG-1S Turntable Angle
Vertere DG-1S
DG-1S Features
  • Advanced, improved, microprocessor-generated electronic motor drive for the best possible drive
  • Fully Programmable and Copper/Stainless Steel shielded Motor Drive PCB – allowing for future upgrades
  • Low voltage 24 Pole Precision Synchronous Motor, with its dedicated motor drive supply precisely adjusted for lowest motor noise and vibration
  • Improved super-accuracy polished stainless steel, high aspect ratio, main bearing spindle and main bearing housing with Tungsten Carbide super-precision Ball
  • High precision CNC machined aluminium alloy drive pulley
  • High Precision Machined Aluminium Alloy Platter with bonded PETG Record Interface Mat and Cork/Neoprene/Nitrile bonded underside plus resonance control disk
  • Noiseless and Stiction eliminating Thread Tonearm Bearings, each made up of hundreds of 3 microns thick twined Nylon 6.6/6 strands horizontal and two Kevlar threads vertical
  • Twin Bonded five-layer Polymer sandwich non-resonant Tonearm Beam
  • One piece, Gold Plated Flexible PCB Tonearm Internal Wiring
  • Stainless Steel Main Balancing Counterweight and Tracking Adjustment Weight with azimuth adjustment
  • Three new design adjustable feet with Resistive Felt Pads
  • Non-resonant, triple sandwich Cast Acrylic Main and Sub Plinth structure with improved intercoupling and coupling to the steel main-chassis for rigidity and structural support
  • Low frequency compliant, Tuned Silicone rubber integrated isolation system
  • Bespoke clear precision silicone rubber round ‘belt’ – stable with temperature and humidity
  • Non-resonant clear Polycarbonate dust cover with elegant Integrated hinges
Vertere DG-1S Turntable Top View
The Skinny
Improved platter bearing – The precision machining and polishing operations have a higher tolerance with the variation halved statistically. The super smooth finish bore with the precision Tungsten Carbide interference fit ball delivers lower noise, lower rumble, a lower effort for the motor and less rotational variability.
Groove Runner S tonearm – The arm beam is now constructed from a five-layer polymer laminate bonded to a second five-layer polymer laminate. The PCB flex signal carrier is bonded in-between the two laminates. The profile of the arm and bearing has improved the counterweight/bearing/headshell/cartridge alignment.
Vertere DG-1S Tonearm
Improved tonearm bearings – The Vertical Kevlar thread bearing is now adjustable for tension and azimuth. The Horizontal nylon thread bearing is now fitted with greater precision to ensure even greater consistency.
New Motor Drive software allows separate adjustment in two steps, initially the sine wave voltage and then the cosine wave adjustment at the final stage for the absolute lowest noise and vibration. Improved coupling between the three plinths – improves resistive damping and reduces noise
For more information: vertereacoustics.com/dg1-s
2 Comments
2 Comments
  1. ORT
    September 26, 2022 at 10:48 am
    Well, it gets my vote for looking kinda-sorta “Vaderish”. Far more attractive than those udderly resembling a cow’s innards after being examined by…I’m NOT sayin’ it’s aliens but it’s definitely frAudiophilians from the planet Yo’Annus, turdtables.
    Verily, this ‘table looks pretty nifty to me. Something Poindexter from “Felix The Cat” or Sherman and Mr. Peabody from “Peabody’s Improbably History” would own. In plebeian parlance, it really is nifty.
    Would that I had the wherewithal to owneth one. To the “WayBack Machine”! Yes! The cool one not the interwebs archaic archive.
    ORT
    • Ian White
      September 26, 2022 at 10:21 pm
      ORT,
      I’m probably one of the few N. American reviewers to actually listen to one and it was really quite good. It has a lightweight feel to it but it hits like a mule.
      There is a new “white” version. Our photos will be updated on Wednesday.
      IW
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Are you one of those people who hates having to install a phono cartridge? The Waiting for Ideas PP-1 might be exactly what you're...
Looking for ways to improve the sound from your turntable? Our favorite phono preamplifiers we've tested offer a solution at every budget.
Audio Cables
At £1,000, Chord Company's PhonoARAY can minimize external interference and ground issues that may affect turntable performance.
Upgrade the sound of your turntable with our favorite MM and MC phono cartridges you can buy in 2024 without breaking the bank.
Looking for your first high-end audiophile turntable but don't want to spend more than $3,500 for something that will be your deck for many...
Our favorite audiophile turntables in 2023 include Pro-Ject, Rega, Technics, Orbit and more.
Daily Deals
Our favorite turntables on sale for Black Friday 2024 that we would actually buy for ourselves or recommend to family and friends.
