Velodyne SC-IW In-Wall Subwoofer Redefines In-Wall Bass Performance, Installability and Adaptability
Morgan Hill, CA (September 11, 2006) — Velodyne Acoustics broadens its support of the fast-growing custom installation market with the introduction of the SC-IW subwoofer, an in-wall able to fit flush in a standard 2×4 wall, show less than 5″ high of grill area, and deliver reference quality bass performance. The SC-IW is the ideal solution for installations that demand an easy-to-install subwoofer with an unobtrusive design that won’t compete with a room’s decor, and delivers deep, accurate and visceral bass performance with minimal wall vibration.
The SC-IW subwoofer can be used for either new construction or retro-fit installations. The SC-IW features a unique two-piece cabinet design with separate driver and back box enclosures. In new construction, the back box can be mounted at the rough-in stage at very little cost to the installer, while the driver module is installed at the trim-out stage. In retrofit situations both enclosures are mounted together.
The innovative, vertically firing T-shaped driver is specifically designed to maximize the SC-IW’s performance while significantly reducing wall vibration. The driver uses a quad spider design using a patent-pending “drive shaft,” a neodymium motor structure and a ½” thick composite drive surface. These enhancements enable an extremely long throw driver sporting more then one inch peak-top-peak travel while exhibiting exponentially less wall vibration than traditional in-walls that fire in and out.
Complementing the cutting-edge driver technology is the enclosure, also specifically designed for in-wall installations. The enclosure utilizes a propriety multilayer “sandwich” material that is laminated under high pressure. This yields an extremely rigid cabinet that has the density and performance of traditional high-end enclosures while having very thin walls allowing for maximum internal driver air volume.
The SC-IW includes both a 14-inch high standard grill for easy installation and servicing and a sub-five inch high grill for the absolute minimum of visible grill area. Both grills can be painted to match the room’s decor, and feature a 90&#186 scoop that enables the vertically firing woofer to project bass into the room.
The SC-1250 amplifier, sold separately, powers the SC-IW with 1250 watts of continuous RMS power and 3000 watts dynamic power. This rack-mountable amp is a two-unit high design and features a DSP-controlled built-in seven-band automatic room-EQ to provide the best bass performance regardless of subwoofer placement. The amp can drive up to two SC-IW subs using conventional speaker wire.
The SC-IW has a suggested retail price of $999. Velodyne provides custom installers with greater flexibility by providing two separate model numbers for the SC-IW to provide convenience in staging and installation. The SC-IWBB is the enclosure and can be installed at the rough-in stage at very little cost to the installer. The SC-IWDVR is the driver module and comes complete with the two grills mentioned above. The SC-1250 amplifier has a suggested retail price of $999.
The SC-IW is part of the new SubContractor series of subwoofers from Velodyne. The SC series consists of the SC-8, SC-10, SC-12, SC-15, and SC-IF/IC (in-floor/in-ceiling) subwoofers, also driven by the SC-1250.
About Velodyne
Velodyne Acoustics, Inc., founded in 1983, is universally recognized as the leading manufacturer of high-performance, low distortion powered subwoofers at all price levels. Headquartered in Silicon Valley, California, the company’s technically innovative audio products are available through a select group of authorized dealers, custom installers, and distributors worldwide. For more information visit www.velodyne.com.
Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
QUAD 3DCT CD Transport QUAD 3DCT CD Transport
CD Players
Quad’s new 3CDT CD transport keeps it simple: no DAC, no SACD, just solid build, clean digital output, and a sensible match for the...
Emotiva Nostala LB12 Loudspeakers Pair no grilles Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
