Velodyne SC-602 Dual Subwoofer Amplifier
The SC-602 dual-mono amplifier, available from Velodyne Acoustics, controls up to two SC-600 Series in-wall, in-floor or in-ceiling subwoofers. The two-unit high, rack-mount SC-602 is the newest addition to the SC-600 Series which includes the SC-600 IW (In-Wall) and SC-600 IF/IC (In-Floor/In-Ceiling) subwoofers and the single-sub SC-600 amplifier. The SC-600 Series are affordable, easy-to-use subwoofer systems designed for the custom installation market.
Using two Class D amplifiers with 400 watts peak power each and 200 watts RMS each, the SC-602 comes complete with a one-touch, five-band Auto-EQ room bass correction system and IR remote with customized listening presets for movies, R&B/rock, jazz/classical and games. Subwoofer volume, phase and night mode can also be adjusted via the remote control. The SC-602 amplifier is easily connected to one or two subwoofers with conventional speaker wire and includes RS-232 control (Crestron certified), 12V trigger and an IR repeater jack.
Velodyne SC-602 dual-mono amplifier - back
“With the SC-602, a custom installer can now specify a dual-sub solution for $1699,” said Doug Smith, national sales director for Velodyne. “Set up is as easy as cut, plug and play using the SC-602 with one or two SC-600 IWs, and the use of dual subs dramatically improves the bass response in any room.”
The companion SC-600 IW subwoofer installs easily, as a single or in pairs, in either new construction or retrofit applications due to its one-piece sealed enclosure. A unique triple vector design, with two active 6.5″ long-throw drivers and two custom passive radiators firing at 45 degree angles, maximizes excursion within the wall cavity and reduces wall vibration by 50%.
One or two SC-600 IF/IC subwoofers can be concealed in the floor, ceiling, riser, closet or other enclosures. The 12″ driver mounted in a slot-loaded, bass-reflex cabinet minimizes distortion and maximizes both bass output and impact.
About Velodyne
Velodyne Acoustics, Inc., founded in 1983, is universally recognized as the leading manufacturer of high-performance, low distortion powered subwoofers at all price levels. Headquartered in Silicon Valley, California, the company’s technically innovative audio products are available through a select group of authorized dealers, custom installers, and distributors worldwide.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
