Newcomer Valerion Stirs The Lifestyle Projector Pot with VisionMaster Max at CES 2025
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
Valerion VisionMaster Max Lifestyle Projectors Best in Show CES 2025
When it comes to video projectors, Valerion is not a brand that is widely known. In fact, they’ve just arrived on the scene with a massive Kickstarter project that raised over $10 million in 2024, making it the highest-funded projector project in crowdfunding history. But this is not to say that they’ve come out of nowhere. In fact, they’re a sister company to AWOL, whose UST projectors have been available in the U.S. for the past few years.
At CES 2025, Valerion spotlighted its flagship VisionMaster Max projector along with the rest of its product line. And what we saw at the show was impressive enough for the projector to earn our coveted “Best in Show” award for best lifestyle projector.
Valerion VisionMaster Max Lifestyle Projector Close-up
Valerion claims that the VisionMaster Max incorporates advancements that “set a new standard” for cinematic-quality projection in the lifestyle category. For those unfamiliar with the term, lifestyle projectors are those that come in a fairly small chassis, can be mounted or installed a number of different ways, and include built-in speakers. They’re normally not considered for “serious” home theaters as their compact designs can sometimes sacrifice performance. But this does not appear to be the case with the Valerion VisionMaster Pro, Pro 2 and Max.
Product Design
The Valerion VisionMaster Max measures in at a svelte 10.2 x 7.3 x 8.5 inches, identical in size to the rest of Valerion’s current projector offerings. The chassis features 14 electroplated metal strips, engineered to endure up to 100 kilograms (220 pounds) of pressure, but we wouldn’t recommend standing on it. The company says that this advanced structure delivers “superior strength and reliability” while maintaining a sleek, modern visual appearance.
To provide a wide breadth of content access and ease of use, in addition to three HDMI and two USB ports, the VisionMaster Max incorporates Google TV+ with access to all the top streaming apps such as Netflix, Amazon Prime Video, Max, AppleTV+ and Disney+. It also includes support for Airplay 2, Chromecast & Miracast wireless streaming, and works with Google Home, Apple Homekit, and Amazon Alexa. It even offers Control 4 compatibility for integration with CI (Custom Installation) systems.
The VisionMaster Max offers IMAX Enhanced certification and supports HDR10, HDR10+, Dolby Vision and HLG high dynamic range formats. It also supports Dolby Atmos sound.
Lens, Imaging and Optics
The VisionMaster Max, Pro 2 and Pro incorporate a professional-grade OpticFlex lens system, supported by an optical engine featuring the commonly used 0.47-inch TI DLP Chip paired with the latest generation XPR module. As with most 4K DLP projectors, the VisionMaster projectors use pixel shifting on the 1080p DLP chip to produce 4K resolution (3840×2160 pixels) at 60 Hz. They can also support a 240 Hz refresh rate at 1080p resolution. The integrated triple laser RGB laser light source enables the VisionMaster projectors to support up to 110% of the BT2020 color gamut.
Keystone and Lens Shift
Designed with flexible placement options in mind, the VisionMaster Max includes a number of manual and automatic picture adjustments to assure proper screen geometry. The projector’s automatic image correction system includes tilt, keystone, and digital zoom correction, with the image processor performing the necessary scaling of the image to create a perfectly rectangular 16:9 screen shape.
But the VisionMaster Max is different from most lifestyle projectors – even some home theater projectors – in that it also includes optical lens shift as well as optical zoom. Lens shift is superior to keystone adjustment in that it can adjust the position of the image on the wall or on the screen without losing any image detail. This can allow you to place the VisionMaster Max on a coffee table or mount it on the ceiling and still hit your projection screen in an optimum viewing position with perfect screen geometry. The VisionMaster Max vertical lens shift range is a full screen height (+/- 50%) which is a greater than many dedicated home theater projectors. There is no horizontal lens shift, so you will need to make sure that the projector is centered on the screen in order to avoid any keystone adjustments.
The projector’s 0.9-1.5:1 throw ratio and optical zoom lens also increase installation flexibility, allowing the projector to throw a 200-inch diagonal image from approximately 18.5 feet away or a massive 300-inch image from 22.5 feet away. We have heard that additional lens options may be offered in the future.
Valerion VisionMaster Max Lifestyle Projector Promo with Screen
Improved Dynamic Contrast with Enhanced Black Level
Perhaps the most impressive feature on the VisionMaster Max (as well as the Pro and Pro 2) is that, when the Enhanced Black Level mode is activated, a special algorithm adjusts various parameters such as the intensity of the laser light engine, the gamma curve, and the RGB levels for each IRE of the grayscale dynamically on a frame-by-frame basis. This can result in improvements in overall dynamic range and contrast by lowering the black level and boosting the highlights.
Beyond what’s capable with processing alone, the VisionMaster Max model is the only one in the line-up that combines this EBL processing with a dynamic iris for even greater contrast. This dynamic iris and optical lent shift set the Max apart as the top performer and most installation-friendly projector in VisionMaster’s current line-up.
Feature and Specs Comparison for Valerion VisionMaster Projectors
Valerion VisionMaster Projector Product Line
MaxPro 2ProPlus 2Plus
Price$3,999 $2,999$2,499$1,999$1,499 (not currently available)
Imaging Chip TI 0.47-inch DMDYesYesYesYesYes
RGB Triple Laser Light Source – 25,000 use hour lifeYesYesYesYesYes
4K UHD Display Resoluition (via pixel shift)YesYesYesYesYes
Brightness (ISO Lumens)3,0003,0002,5002,0001,500
Contrast Ratio15,000:115,000:110,000:110,000:110,000:1
Dynamic IRISYes
Vertical Lens ShiftYes
Optical Zoom0.9-1.5:10.9-1.5:10.9-1.5:11.2:11.2:1
4:3, 16:9, 21:9, 32:9 Aspect Ratio  SupportYesYesYesYesYes
110% REC 2020 Color SpaceYesYesYesYesYes
ISF Certificated YesYesYesYesYes
40 to 300-inch Image Size RangeYesYesYesYesYes
IMAX EnhancedYesYesYesYesYes
Filmmaker ModeYesYesYesYesYes
HDR Support (HDR, HDR10+, Dolby Vision, HLG)YesYesYesYesYes
Dynamic Tone MappingYesYesYesYesYes
Active 3DYesYesYesYesYes
Audio Output: 2x12W YesYesYesYesYes
DTS Virtual:XYesYesYesYesYes
Dolby AudioYesYesYesYesYes
Google TV OSYesYesYesYesYes
Gaming SupportYesYesYesYesYes
HDMI2×HDMI 2.1
1×HDMI 2.0 (eARC)
2×HDMI 2.1
1×HDMI 2.0 (eARC)
2×HDMI 2.1
1×HDMI 2.0 (eARC)
2×HDMI 2.1
1×HDMI 2.0 (eARC)
2×HDMI 2.1
1×HDMI 2.0 (eARC)
USB1×USB 3.0, 1×USB 2.01×USB 3.0, 1×USB 2.01×USB 3.0, 1×USB 2.01×USB 3.0, 1×USB 2.01×USB 3.0, 1×USB 2.0
WiFi 6eYesYesYesYesYes
Bluetooth 5.2YesYesYesYesYes
Digital Audio Output (1 x S/PDIF)YesYesYesYesYes
Analog Audio OutputYesYesYesYesYes
Fan Noise28dB28dB28dB26dB26dB
Dimensions (10.23″ x 7.3″ x 9.2)YesYesYesYesYes
Weight (15lbs/8oz)YesYesYesYesYes
Valerion VisionMaster Max Lifestyle Projector Promo Showing Projector Size
The Bottom Line
Valerion is staking out new ground here by offering the performance of a dedicated home theater projector in the compact elegant chassis of a lifestyle projector. We’ve never seen a lifestyle projector with the performance and installation flexibility of the VisionMaster Max and, for these reasons, it earned our “Best in Show” award for Best Projector at CES. Valerion received quite a bit of buzz and attention at the show, and if what we saw was any indication, their projector line-up is poised to stake a significant claim in the marketplace.
The other projectors in the Valerion VisionMaster series include many features in common – but do have some significant differences in light output, contrast and lens shift capability. Also, while the VisionMaster Pro, Pro 2 and Max offer an optical zoom lens, the entry-level Plus and Plus 2 include a fixed focus lens assembly, which can limit placement options.
The success of the VisionMaster Max is not guaranteed. With the proliferation of inexpensive TVs sized at 98 inches and beyond, some prospective buyers may choose a flat panel TV instead. However, the Valerion VisionMaster Max offers a strong value proposition for those who want to replicate that cinematic viewing experience at home, without breaking the bank.
Valerion VisionMaster Max Lifestyle 4K Projector wins Best in Show CES 2025 Mug
Valerion VisionMaster Max Lifestyle 4K Projector at CES 2025
Price & Availability
The Valerion VisionMaster Max is available for pre-order for $3,999 at Valerion’s website, with deliveries expected to start February 2025.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
At 85 or 98-inches, the top-of-the-line 2025 TCL X11K 4K TVs boast 6,500 nits, 14,000 dimming zones and HALO Control Technology.
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
