Headphones
Urbanears Tanto Headphones
80’s Style Headphones Available in 14 Colors
Urbanears has just introduced the Tanto headphone — a tribute to the ’80’s revolution in mobile music, updated with the latest technology and is designed for maximum mobility without the compromise of performance. The Tanto takes you back in time and away from downtown Stockholm. Named after a vibrant park in the South Central area of the Swedish capitol, the design and function of the Tanto reminds you where headphones once came from.
The Tanto is made for everyday use, to be taken along wherever you go. It comes with a custom microphone and remote which is compatible with iPhone, Nokia, HTC and Blackberry.
Urbanears Tanto Headphones Specifications
Specifications
  • Microphone and remote compatible with iPhone, Blackberry, HTC, Nokia and most other devices;
  • 36 mm Handmade driver unit;
  • Frequency response: 20-20kHz;
  • Impedance: 32 ohms;
  • Sensitivity: 118dB;
  • Max input power: 30mW;
  • 47″ Fabric cord;
  • 3.5 mm Stereo plug.
Tanto headphones are priced at $39.99 MSRP and are available now at Nordstrom, American Rag and online at Karmaloop.com.
The Tanto comes in 14 colors.
Urbanears Tanto Headphones Colors
About Urbanears
Urbanears makes headphones that fit your everyday life. Based in Stockholm and founded in 2008, we supply the perfect listening device for anyone with a pocket full of music and a wish to make the most of it. Their models are designed to optimize sound and captivate self-aware customers by matching preferences in size, style, design, function and relation to music.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
