Urbanears Plattan Headphones
Urbanears just introduced the Plattan Headphones — designed to be the perfect classic product, utilizing innovative functions and performance with todays technology. The Plattan which collects its name from Stockholm’s most central and classic meeting point, is the rendezvous of timeless features and pioneering solutions in contemporary design and function.
The Plattan is a medium size headphone allowing for rich, secluded sound. And for maximum mobility, you can fold it down to the size of your fist for safe keeping when not in use. It also comes with a custom microphone and remote which is compatible with iPhone, Nokia, HTC and Blackberry.
The Plattan’s unique feature is the Zound Plug socket on the earcap that allows your friend to plug into your earcap and listen to the same thing as you are listening to.
Urbanears Plattan Headphones Zound Plug
The Plattan comes with a exclusive designed hinge which allows you to fold the headphone for safe-keeping when not in use.
Specifications
  • Microphone and remote compatible with iPhone, Blackberry, HTC, Nokia and most other devices;
  • 40 mm Handmade driver unit;
  • Frequency response: 20-20kHz;
  • Impedance: 32 ohms;
  • Sensitivity: 112dB;
  • Max input power: 40mW;
  • 47″ Fabric cord;
  • 3.5 mm Stereo plug.
  • Zound Plug
  • Hinge construction allows the headphone to fold down to a fraction of its size.
Urbanears Plattan Headphones Specifications
Plattan headphones are priced at $59.99 MSRP and are available now at Nordstrom, American Rag and online at Karmaloop.com.
About Urbanears
Urbanears makes headphones that fit your everyday life. Based in Stockholm and founded in 2008, we supply the perfect listening device for anyone with a pocket full of music and a wish to make the most of it. Their models are designed to optimize sound and captivate self-aware customers by matching preferences in size, style, design, function and relation to music.
Beats Cables Promo Image
Audio Cables
Networking
Earbuds & In-Ear Headphones
