Universal Introduces Wireless Keypad — Unique Dual-Use Remote for Home Entertainment Systems
Versatile New KP-900 Custom Keypad Mounts on Walls and Doubles
As a Handheld Remote; Ideal for Both New Homes and Retrofits
Universal Remote Control, Inc., the leader in control system design and manufacturing for home and professional entertainment systems, will introduces the wireless, dual-use KP-900 Wireless Keypad at this Spring’s Electronic House Expo, beginning Mar. 13 in Orlando, Florida.
The KP-900 is a powerful keypad remote that controls all audio and video equipment in a home, simplifying and automating the operation of even the most complex Home Theater system to achieve an extraordinary combination of power and flexibility. It can be mounted on a wall AND used as a handheld remote, making it ideal for retrofitting into homes with existing entertainment systems, as well as for new homes.
Four simple screws attach the KP-900’s bracket to a wall, eliminating the expense and inconvenience of running new wires or opening the wall to add new wires. The keypad can be mounted in any room, and anywhere in a room. It can be used on the wall in its bracket, independently as a handheld, or affixed to a refrigerator or other metal surface thanks to a built-in magnet. The keypad is compatible with iPods and other portable music players, and comes in three decorator-friendly finishes — white, light almond and black.
The KP-900 is equipped with a bright, easy to read, backlit LCD screen, and injection-molded backlit buttons with laser-etched labeling. Six buttons to the right of the screen are labeled based on what a user is watching or listening to, and change accordingly. Someone ‘Watching TV,’ for example, will see a list of buttons useful to that activity. If he selects ‘DVD,’ the buttons will automatically change to control the DVD — making operation of the system simple, fluid and intuitive.
To further enhance customized installation, the keypad comes with three sets of keycaps for the top buttons. One set has no labels. The other two simplify volume control (Volume Up, Mute and Volume Down) and transport control (Seek–, Shuffle and Seek+). They help installers more perfectly adapt the keypad to specific systems and user preferences, and cannot be removed once installed.
Any Room, Anywhere
The KP-900 can be added to the kitchen, the bedroom, the bath, even outdoors — or independently to each location. Equally important, there’s no need to break into walls to add new wiring, since the KP-900 is completely wireless. It operates using Infrared (IR) signals with a range of 30-50 feet, or Radio Frequency (RF) signals with a range of 50-100 feet when used with an optional MRF-350 or MRF-260 RF Base Station. In RF mode, components can be controlled without pointing at them, and even if they are in other rooms, hidden in cabinets, or are behind closed doors.
The KP-900 is also compatible with URC’s pioneering MSC-400 Master System Controller, which provides installers with options and advantages not otherwise available, including triggered macros, RS-232 and relay control, video and voltage sensors, among much else.
For homes that already have wall-mounted volume controls, adding a KP-900 keypad lets users operate their systems from whatever room they’re in. They can turn the system on or off, select what to listen to or watch, change songs, CDs, channels, sources, and more. They can harness previously unused features their components might already possess, like second zone outputs, and use the keypad anywhere in the room by simply lifting it from its home bracket.
Programmed to Please
The KP-900 is designed to be professionally programmed using proprietary URC software through a Windows PC equipped with a USB port. The software is available at no extra cost from the URC Web site, www.universalremote.com. While a basic set-up only takes a few minutes, fully automating an A/V system requires a detailed knowledge of the equipment, the user’s preferences, and how the system is connected.
The KP-900 boasts a generous 4 Megabits of user-configurable Flash memory, which supports up to 400 full pages of commands that can be distributed into as many as 255 devices. Additional features include a 255-color backlighting palette for the LCD display, one-touch blue backlighting for all the hard buttons, the ability to learn new IR commands, a small integrated speaker for audible feedback, a built-in sleep timer, and a USB cable. Four AAA batteries supply reliable, long-lasting power.
The KP-900 Wireless Keypad will be available in March from authorized Universal Remote Control dealers at a suggested price of $599. It can be seen with URC’s other outstanding products in Booth 530, Orange County Convention Center, during the show.
About Universal Remote Control, Inc. Headquartered in Harrison, New York, Universal Remote Control, Inc. is a world leader in the design, engineering, manufacture and distribution of high-quality remote control devices. Since its establishment in 1991, the company has become highly regarded by consumers and professionals alike, and won numerous industry awards. It supplies millions of remote controls each year to consumers around the world through four primary distribution channels: consumer retail, custom professional, subscription broadcast and OEM.
Over the years, clients have included many leading high-end audio and video manufacturers, and consumer electronics and subscription broadcast companies, including Adcom, B&K, Bright House, Cablevision Systems Corp., Charter Communications, Comcast, Crestron, Denon, Faroudja, Harman/Kardon, Klipsch, Krell, Lexicon, McIntosh, Motorola, NCTC, Rotel, Parasound, Polk Audio, Time Warner Cable, Toshiba, Xantech and Zenith.
Universal Remote Control products are manufactured in Asia and North America in factories that meet rigorous CE, ISO 9001, ETTS, IQNET and TQM certification requirements. For additional technical information, please visit www.universalremote.com.
Vertere DG-X Turntable Red
With a precision main bearing, cutting-edge motor drive, and advanced Groove Runner X Tonearm, the DG-X delivers unparalleled sound clarity and resonance elimination. Explore...
Campfire Audio Axion IEM Connected USB-C with Controller Campfire Audio Axion IEM Connected USB-C with Controller
Earbuds & In-Ear Headphones
Offering premium sound quality, USB-C connectivity with a DAC, and seamless integration with iPhones and Android smartphones, the Axion IEMs are Campfire Audio's most...
Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle Rotel DX-5 Integrated Amplifier Silver Front Angle View Lifestyle
At $1,499, the Rotel DX-5 is a compact sized 25-watt per channel stereo integrated amplifier with Bluetooth, HDMI-ARC and Roon.
Wattson Audio Madison Power Amplifier Front Wattson Audio Madison Power Amplifier Front
Discover the new Madison Power Amplifier from Wattson Audio — a Swiss-engineered Class A/B amp delivering rich harmonics, ultra-low distortion, and dynamic performance in...
WiiM Voice Remote 2 with components lifestyle WiiM Voice Remote 2 with components lifestyle
With WiiM's continuing quest to improve the music listening experience, the upgraded Voice Remote 2 improves control for WiiM devices.
Sharp TIVO TV Lifestyle Man View Sharp TIVO TV Lifestyle Man View
HDTV 4K & 8K TV
Would you buy a 55-inch Sharp 4K TV with built-in TiVo for $299.99? Let's take a look at what it offers.
