Ultralink Ultra Flat HDMI and Challenger Right Angle Cables
Ultralink Unveils UFHDMI Ultra Flat HDMI Cables And C2HDMI-RA Challenger Series Right Angle HDMI
Ultralink/XLO Products, Inc., an innovative and prolific manufacturer of award-winning audio and video interconnects, cables and AC power products, unveils a number of new products carefully engineered for today’s “space at a premium” environments behind electronics or that ultra-thin flat screen ready for installation.
Ultralink UFHDMI Ultra Flat HDMI Cable
New UFHDMI Ultra Flat HDMI Cables
Our proprietary, patented design makes this the flattest HDMI cable you can find. Their ultra-short connectors are optimized for tight, low-profile installs. They feature 30 AWG OFHC copper conductors and low-capacitance gas-injected dielectric insulation, and meet the latest High Speed HDMI specifications. You can have them in Black or White in 1m, 2m, and 3m lengths. Included with each Ultra Flat HDMI cable is an adjustable Right Angle Strain Relief! UFHDMI is rated for 1080P, 12-bit Deep Color, and 3D.
Ultralink C2HDMI-RA Challenger Series Right Angle HDMI Cables
New C2HDMI-RA Challenger Series Right Angle HDMI Cables
Challenger Series Right Angle HDMI Cables meet and exceed new HDMI High Speed (for non-Ethernet) specifications. They feature 28 AWG 6N OFC copper conductors with full quad shielding — 2 each of aluminum/Mylar foil and tinned copper braids. Not all HDMI cables are created alike! With its low-capacitance gas-injected dielectric insulation and a CL3/FT4-rated outer jacket the C2HDMI-RA is approved for all in-wall installations. The Challenger Right Angle can be had in convenient 1, 2, 3, 4, and 5m lengths with durable, precision-molded connectors and 24k gold-plated connections. It supports 1080P, 12-bit Deep Color, 3D, 4K, Dolby TruHD, HDMI-CEC, and 120HZ refresh rate.
HDMI High Speed
Platinum MkII HDMI and Platinum MkII HDMI-XL
Reference quality cables with the look and feel of our perfectionist XLO™ and high-performance Argentum Acoustics brands at a fraction of the price. They feature cryogenically-treated silver-plated Laboratory-Grade 6N copper conductors and quad-shielding. We use the best Teflon dielectric insulation for the purest signal possible, along with precision-machined connectors manufactured to mil-spec tolerances with 24K direct gold-plated contacts. Platinum MkII is an “intelligent” cable with a connector chip that that removes corrupted HDCP and EDID data avoiding distortion products. The chip also enhances short- and long-run signal integrity. Platinum MkII is can be had in convenient lengths from 1 to 5m lengths, and Platinum MkII-XL from 30 to 75 foot lengths. Shorter runs of up to 5m of Platinum MkII deploy a nylon cable cover so they aren’t CL3/FT4-certified, but MkII-XL is certified for in-wall use. Platinum MkII supports 1080P, 12-bit Deep Color, 3D, 4K, Dolby TruHD, HDMI-CEC, and 120HZ refresh rate. Platinum MkII-XL also supports 30-bit Deep Color Depth.
The Ethernet Connection
We all know it’s coming, and we’ll be showing Ethernet versions of Ultra Flat, Challenger Series Right Angle, and Platinum MkII and MkII-XL. Ethernet will integrate many new and exciting audio and video technologies and Ultralink/XLO is at the bleeding edge ready to provide solutions.
How We Manage It
How does Ultralink offer so much performance at such ultra-value prices? Ultralink takes advantage of its economies of scale: Platinum II cables are easier to build than our Argentum and especially our XLO lines. They cost less to manufacture but are packed to the jacket with technology.
About Ultralink Products, Inc.
Ultralink/XLO Products Inc., headquartered in Ontario, California is an industry-leading manufacturer of high-performance audio and video cables and UltraPower™ AC power products, Canada’s market share leader in the field. In early 2002 Ultralink Products Inc. acquired XLO Electric Co., Inc. a well-known brand of audiophile reference cables and interconnects. Ultralink also introduced the elegant “Engineering Truth” Argentum Acoustics™ line of cables and accessories. Ultralink is a member of PARA, CEDIA and the CEA.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
