ULTIMEA’s Thor T60 Laser TV Promises to be the God of Light with 4,000 Lumens of Output
4,000 lumens of output? We suspect that number drops significantly once calibrated and not run on the highest setting but ULTIMEA’s Thor T60 Laser TV has some excellent features as well.
Ultimea Thor T60 UST Projector with screen
Although the vast majority of homes have a TV as the center of their home entertainment setup, a growing number of consumers are opting for the UST (Ultra Short Throw) projector (aka Laser TV) option.
One reason that UST (Ultra Short Throw) video projectors are becoming an increasingly popular solution is that you can have a really big screen viewing experience even with limited space.
A new brand that has decided to enter the UST market is ULTIMEA, which has announced the launch of the ULTIMEA Thor T60 Triple Laser TV
Ultimea Thor T60 UST Projector Front Angle
Thor T60 Basics
The T60 features a long-lasting Tri-Color Laser Light Engine and an abundance of features that bring big-screen movies, sports, and gaming to prospective buyers.
The ULTIMEA Thor T60 has a minimalist design that can blend into any décor and almost all room sizes. The projector unit can be placed just inches from the wall for the most popular screen sizes. The T60 can project a 100-inch image with a projector-to-screen distance of 7.2 inches.
Tip: If you are worried about unwanted projector noise, the Thor T60 runs at a very quiet level of less than 30 dB.
Ultimea Thor T60 UST Projector Low Angle
Laser Light Engine
With the Tri-Color Laser Engine and HCTC 3.0 Technology, the T60 is designed to deliver precise color purity, wide color gamut (120% BT.2020), and wide contrast (4,000:1).
Tip: Laser light engines don’t require periodic replacement as the traditional lamps used in many projectors do.
To deliver optimal brightness, the Thor T60 employs ULTIMEA’s trademark technology, BrightMX, with an output of 4000 ANSI Lumens. This makes the T60 less susceptible to ambient daylight and provides enhanced visual display quality under varying lighting conditions.
Tip: Regardless of how much light the projector can output through its lens, for daylight viewing an ALR (Ambient Light Rejecting Screen) should be considered.
ULTIMEA Thor T60 Laser TV Lumens Comparison
How The Thor T60 Displays 4K Resolution
The Tri-Color Laser Engine is combined with a .47-inch 1080p resolution DLP imaging chip (aka DMD – Digital Micromirror Device) from Texas Instruments. The chip contains 2.1 million pixels (very tiny mirrors). The projector is able to display 4K UHD resolution (8.3 million pixels) via shifting the pixels on the 1080p chip both vertically and horizontally at 240Hz (240 times per second). This process is so fast the image displayed on the screen is classified as a 4K UHD resolution image.
DLP 4K Pixel Shifting
Gaming Support
ULTIMEA’S customized image technology also provides seamless video without lag and an ultra-low latency of less than 25ms that refines clarity and fluidity in visuals, simulating the intricacies of human sight.
HDR
The Thor T60 supports Dolby Vision HDR which provides a more realistic viewing experience from compatible games, movies, and streaming video.
Audio
In addition to video display, the Thor T60 has an integrated two-channel audio system. However, for better sound (including Dolby Atmos-pass through), the T60 can also be connected via HDMI-eARC, Digital Optical, or analog output to an external soundbar or audio system.
From ULTIMEA Founder Bob Xiong: “Our mission with the ULTIMEA Thor T60 was to eliminate the barriers between viewers and an authentic cinematic experience. Most homes are limited by screen size, daytime brightness, or lackluster audio. With the Thor T60, we harnessed the power of the Tri-Color Laser Engine and MEMC dynamic compensation to ensure that every frame is a vivid work of art, regardless of ambient lighting. The integration of Dolby Atmos and Dolby Audio puts viewers right in the middle of the action for a truly immersive audio and visual experience. Thor T60 is more than a projector; it’s a revolution in home entertainment.“,
Ultimea Thor T60 UST Projector Screen sizes
Features & Specifications
  • 4K Ultra HD Resolution Display: 1080p pixel shift to 4K UHD
  • Tri-Color Laser Light Engine:  Up to 30,000 hours lifespan
  • Color Gamut: 120% BT 2020
  • Contrast Ratio: 4,000:1
  • Throw Ratio: .0.21:1
  • Image Size Range: 80 to 200 inches
  • ULTIMEA Image Enhancement Technologies: HCTC, BrightMAX, AI Image Engine
  • HDR Support: Dolby Vision, HDR10
  • Motion Processing: MEMC Dynamic Compensation
  • 3D Support: Active Glasses, compatible with 3D Blu-ray and other platforms.
ULTIMEA Thor T60 Laser TV 3D Viewing
  • Processing Chip: 2GB RAM + 32GB ROM
  • Audio System: 15W x 2
  • Surround Sound Support: Dolby Atmos/DTS-HD pass-through
  • Wireless Connectivity: Wi-Fi (2.4 Ghz/5 Ghz), Bluetooth 5.0
  • Wired Inputs: HDMI 2.1 x 2 (one is eARC enabled), USB 2.0 x 2,
  • Wired Outputs 1 x digital optical out, 1 x digital coaxial out, 1 x 3.5mm analog,  1 x rs232, 1 x Ethernet/Lan
ULTIMEA Thor T60 Laser TV Connections Rear
ULTIMEA Thor T60 Laser TV Android TV
  • Smart OS: Android TV ver 11.0. Access to thousands of streaming apps. Chromecast Built-in is also included.
  • Voice Control Support: Google Assistant
  • Input Lag for Console Gaming: Between 10 and 25 milliseconds
  • Dimensions: 650 x 365 x 135.5 mm (25.6 x 22.2 x 11.4 in)
  • Weight: 12 Kg/26.4 lbs
Package Contents
  • Power Cables (US, UK, EU)
  • HDMI Cable
  • Remote Control
  • 3D Glasses x 2
  • Warranty Car
  • User Manual
Ultimea Thor T60 UST Projector Accessories
Availability and Pricing
The ULTIMEA Thor T60 Laser TV is expected to become available in November 2023 for a kickstarter promotional price of $3,799 (37% off of the forthcoming retail price). Screen Not Included
LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Netflix expands its viewing flexibility by embracing HDR10+, but there are a couple of catches.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Ask an Expert
HLG is one of several HDR formats in use. Find out what makes if different and what this means for TV viewing
Ask an Expert
Dolby Vision gets all the HDR hype, but HDR10+ also has a lot to offer. Let’s check out more about this dynamic HDR format.
With an RGB triple laser light source, Google TV, built-in battery, and low price, the Photon Go might be a great home entertainment option.
Ask an Expert
Dolby's version of dynamic HDR (High Dynamic Range) can make Ultra HD 4K content come alive in your living room or home theater.
Sister Company to UST Projector Maker AWOL, Valerion has a line of standard throw projectors that might be just right for you
Can the XGIMI Ascend help the sagging UST projector market? The combination of ALR screen and soundbar looks great on paper but we still...
