Ultimea Announces Poseidon E40 Portable Projector
Now on sale for $359, Ultimea’s Poseidon E40 smart projector brings Netflix movie watching to the backyard. Screen not included.
ULTIMEA Poseidon E40 Portable Projector Front and Back
Ultimea is an emerging brand in both the video projector and soundbar markets; we have previously reported on their Apollo S40 soundbar and Thor T60 Laser TV.
The latest entry in their expanding product offerings is the Poseidon E40 portable smart projector which offers some very practical features for those looking for a reasonably-priced first projector or users who already have a high-end main system, but would like something compact and affordable for a second room or the backyard. Ultimea claims that the Poseiden E40 can project images up to 150 inches
ULTIMEA Poseidon E40 Portable Projector Outdoor LIfestyle
Poseidon E40 Features
Light Output: The most important feature of a video projector is the ability to produce enough light to project a viewable image on the screen. Although many projectors can output more light than the E40, considering its compact size and price point, this projector can output more light than many portable projectors in its price point with 1,000 ANSI Lumens
The Poseidon E40 utilizes LCD chips supported by an LED light source.
Ultimea Poseidon E40 Portable Smart Projector Lens Assembly
E40 Lens Assembly
USPAA Technology: The ULTIMEA Poseidon E40 offers intelligent features that facilitate easy setup, simply press a button to achieve automatic 6D keystone correction, autofocus, and intelligent obstacle avoidance. With additional ToF+CMOS technology, the projector supports precise calibration, rapid focusing, and intelligent obstacle detection for the projection screen. The intelligent screen alignment feature adjusts the projector’s position.
Ultimea Poseidon E40 Portable Smart Projector USPAA
Full HD and HDR: The ULTIMEA Poseidon E40 features native 1080p (Full HD) resolution. This supports clarity and detail shine for an immersive viewing experience. HDR is also supported (HDR10+ and HLG). This combination supports better color accuracy, contrast, and rendering of subtle details in both dark and light scenes,
Tech Note: The E40 will accept a 4K video resolution input, but will scale the image to 1080p for projected image display.
Tech Note: Although HDR is supported, because the E40 is not as bright as most TVs that have HDR compatibility, the HDR effect will be less pronounced.
Smart Features:  To enjoy your projector you need to be able to access the content that you like. The E40 fills the bill with both physical and wireless connectivity.  In addition to AV and HDMI sources, the E40 has built-in WiFi and streaming capability with the Android TV OS 11 with over 1000 streaming apps including Netflix Certification
Ultimea Poseidon E40 Portable Smart Projector Android TV
Audio: Most projectors don’t have built-in audio, and for those that do, it is recommended that the user purchase a soundbar or connect to a home theater audio system for the best listening results.  However, for small rooms or portable setups, the E40 does incorporate Dolby Audio in combination with a 2 x10-watt speaker system.
Portability: Weighing just 3.15kg, you can use the Poseidon E40 at home or on the go. It is small enough to into a backpack or luggage.
Voice Control: With built-in Google Assistant, you control select features via voice command. In addition, built-in Chromecast allows users to cast content from compatible smartphones and tablets.
Specifications
  • Display Technology: LCD
  • Light Source: LED
  • Light Source Life: > 10 Years
  • Brightness: 1000 ANSI Lumens
  • Native Resolution: 1920 × 1080 Pixels (Full HD)
  • Contrast Ratio: 2000:1
  • Lens: 5-layer Coated Optical Lens
  • Full-Sealed Optical Engine: Yes
  • Throw Ratio: 1.23:1
  • Auto Focus: Yes
  • Intelligent Obstacle Avoidance: Yes
  • Intelligent Screen Alignment: Yes
  • Auto Keystone Correction: 6D Keystone Correction
  • Recommended Image Size: 80-120in (up to 150-inches is possible)
  • Projector Placement Options: Front, Rear, Front Ceiling, Rear Ceiling
  • Zoom: 50%-100%
  • Audio Speaker:  2 × 10W with DSP
  • System RAM: 1G
  • Storage: 8G
  • Mirroring Display: Chromecast
  • Connectivity:
    • USB 2.0 ×1
    • HDMI ×1
    • AV ×1
    • DC ×1
    • Audio Out ×1(3.5mm)
  • WiFi:  Dual-band 2.4/5GHz
  • BluetoothVer 5.3
  • Remote Control: 360 All-round Remote Control
  • Fan Noise: <30dB
  • Power Dissipation: 200W
  • Power Input: DC 24.0V 8.33A
  • Dimensions: 211 × 174 × 281 mm/8.3 × 6.8 × 11.1 in
  • Net Weight: 3.15kg/ 6.94 lbs
  • Total Weight:  4.5 kg/9 Ibs
  • Included Accessories:
    • Remote Control
    • User Guide
    • HDMI Cable
    • Power Adapter
    • Warranty Card
Ultimea Poseidon E40 Portable Smart Projector Views
Price and Availability
The Ultimea Poseidon E40 is listed for $599.99 at Amazon, but there’s currently a 40% off discount code applied at checkout which brings the price down to $359.99.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
These 4K Ultra HD Blu-ray discs will help you stress-test your home theater setup, from visual effects to acoustic performance.
Hi-Fi Components
Goer Dynamics will expand the distribution of Gryphon Audio Designs into Asia and open up opportunities in the luxury car audio sector.
Audiophiles owe themselves a listen to Craft Recordings Original Jazz Classics Series of new Miles Davis vinyl reissues.
Ready to dive into the dark, twisted world of film noir? Check out the 20 best films, plus where to grab the sharpest Blu-ray,...
