Ultimate Ears Refreshes BOOM Series Portable Bluetooth Speakers and Introduces EVERBOOM
UE introduces four new 4th generation portable Bluetooth speakers: WonderBoom 4, Boom 4, MegaBoom 4 and EverBoom.
UE EVERBOOM, WONDERBOOM 4, MEGABOOM 4, BOOM 4 portable Bluetooth Speakers
Can you feel it? It’s only June but the heat has already arrived in many parts of the country and it looks like it is going to be a rather hot summer. Whilst not everyone loves the excessive heat and humidity, beaches are already packed from Maine through the Jersey Shore and all the way down the coast to many parts of Florida. Taking a portable Bluetooth speaker with you that can withstand the elements has become part of the summer experience and the category continues to grow with new models from Sonos, Bluesound, JBL, Bose, Monster, Sony and more.
Another key brand that is expanding its offerings is Logitech-owned Ultimate Ears. UE has focused on improving sound quality and connectivity with each new generation of speakers with an emphasis for use in larger outdoor spaces. The EVERBOOM is the latest product offering from Ultimate Ears.
UE EVERBOOM is a waterproof portable speaker designed to deliver 360° sound. As the little sister to the previously launched EPICBOOM, the EVERBOOM comes in an even more compact package, which is perfect for outdoor lovers who need a speaker that can keep up with their adventurous lifestyle.
UE EVERBOOM portable Bluetooth Speakers Lifestyle women on boat
UE EVERBOOM
EVERBOOM Core Features
Portability: The EVERBOOM is designed to deliver high-quality sound in a portable package. Its carabiner allows easy clipping to bags, gear, and backpacks.
Sound: Despite its small size the EVERBOOM provides clear, resonant sound. The speaker drivers are precision-tuned which supports punchy mids, clear highs, and deep bass. An Outdoor Boost button is provided to optimize outdoor sound.
Rugged Design: The EVERBOOM has an IP67 rating. This means that it is waterproof, dustproof, and floatable.
Long Playtime: The EVERBOOM can provide up to 20 hours of music playtime on a full battery charge.
Bluetooth Support: The EVERBOOM supports Bluetooth version 5.1 and has a 55-meter transmit/receive range for connecting to smartphones and other compatible Bluetooth source devices.
NFC (Near Field Communication): The one-touch NFC feature allows quick pairing with NFC-compatible smartphones.
Boom App: The EVERBOOM is compatible with the BOOM app (includes PARTYUP which allows the pairing of multiple Ultimate Ears speakers). You can also wirelessly connect to compatible EPICBOOM, BOOM, MEGABOOM, and HYPERBOOM speakers for an expanded sound experience
Megaphone Feature: This transforms the EVERBOOM into a megaphone with a simple tap on the Ultimate Ears BOOM app. Whether calling friends to the dance floor or making announcements, your voice will project loud and clear.
Tip: Megaphone is being made available for use on all Ultimate Ears speakers that are compatible with the BOOM app.
From Jonah Staw, General Manager of Ultimate Ears: “Our users have dynamic lives that require a soundtrack as adaptable and resilient as their various activities,…EVERBOOM is our answer to their call for a portable speaker that marries robustness with superior sound quality. It’s meant to be a core part of their explorations.
More From UE
In addition to the EVERBOOM, UE is also updating its BOOM series lineup which keep the same form factors as previous generations, but expand color choices with the refreshed WONDERBOOM 4 (smallest), BOOM 4 (second smallest) and MEGABOOM 4 (tallest).
  • BOOM 4 and MEGABOOM 4 speakers feature enhanced deep bass radiators to unlock an even bigger sound and are made with more recycled materials than their predecessors.
  • WONDERBOOM 4 includes a podcast mode for enhanced listening to favorite hosts and stories.
UE WONDERBOOM 4
WONDERBOOM 4
UE MEGABOOM 4
UE MEGABOOM 4
Left to right: UE EVERBOOM, WONDERBOOM 4, MEGABOOM 4, BOOM 4 portable Bluetooth Speakers for 2024
EVERBOOMWONDERBOOM  4MEGABOOM 4BOOM 4
Price$249.99$99.99$199.99$149.99
Portable Wireless SpeakerYesYesYesYes
Immersive or Spatial 360° SoundYes360 sound with Big BassYesYes
Podcast ModeYes
One Touch (NFC)Yes
One Touch (Button)YesYesYes
MegaphoneYesYesYes
Party UpYesYesYes
Double UpYes
Outdoor BoostYesYesNot Mentioned
Boom App  (iOS/Android)YesNot MentionedYesYes
Features via Boom App Remote On/Off
EQ Presets (Signature, Bass Boost, Cramped Spaces, Deep Relaxation, Podcast/Vocal),
Customizable EQ
Tap Controls
Not MentionedRemote On/Off
Customizable EQ
Tap Controls
Remote On/Off
Customizable EQ
Tap Controls
BluetoothVersion 5.1 Version 5.2Version 5.1 Version 5.1
Bluetooth® Range180 ft
(55 meters)
130 ft
(40 meters)
180 ft
(55 meters)
150 ft
(45 meters)
Battery Play Time20 hours14 hours20 hours15 hours
Charge TimeLess than 3 hours with PD charger 15W or aboveLess than 3 hours (with BC1.2 Compliant Adapter)Less than 3 hours with PD charger 15W or aboveLess than 3 hours with type C charger 7.5W or above.
Weatherproof RatingIP67 IP67IP67IP67
Available FinishesCharcoal Black
Azure Blue
Enchanting Lilac
Raspberry Red
Active Black
Hyper Pink
Cobalt Blue
Joyous Bright
Active Black
Cobalt Blue
Enchanting Lilac
Raspberry Red
Active Black
Cobalt Blue
Enchanting Lilac
Raspberry Red
DimensionsHeight: 205 mm (8.07 in)
Length: 110 mm (4.33 in)
Width: 85 mm (3.34 in)
Height: 104 mm (4.1 in)
Diameter: 95.3 mm (3.75 in)
Height: 225 mm (8.8 in)
Diameter: 87 mm(3.43 in)
Height: 184 mm (7.24 in)
Diameter: 73 mm  (2.87 in)
Weight960 g420 g935 g620 g
SustainabilityMade of 100% post-consumer recycled polyester fabric and a minimum of 58% post-consumer recycled plastic.Made of 100% recycled polyester fabric and a minimum of certified 31% post-consumer recycled plastic Made of 100% post-consumer recycled polyester fabric and a minimum of 58% post-consumer recycled plastic.Made of 100% post-consumer recycled fabric and a minimum of 52% certified post-consumer recycled plastic
UE BOOM 4
UE BOOM 4
Initial Impressions
Ultimate Ears has an ever-expanding lineup of compact portable Bluetooth Speakers, and the EVERBOOM is designed for those who like all of the capabilities of the previously released EPICBOOM, but in a smaller package. Meanwhile, the new WONDERBOOM 4, MEGABOOM 4, and BOOM 4 arrive in new colors, but are nearly identical to their predecessors. So buyers may opt for discounted 3 series models while supplies last at Amazon.
Competition in the Bluetooth portable speaker category is pretty stiff, with lots of choices from several brands, but Ultimate Ears is serious about taking this on with its extensive lineup. With Summer 2024 now here, UE could make a big impact with those who love the outdoors.
UE EVERBOOM portable Bluetooth Speaker Colors Front
UE EVERBOOM portable Bluetooth Speaker Colors Rear
UE EVERBOOM colors (front and rear)
Pricing and Availability
The Ultimate Ears EVERBOOM, WONDERBOOM 4, BOOM 4, and MEGABOOM 4 Bluetooth speakers are available in the U.S. at the following prices:
  • EVERBOOM: $249.99 (Charcoal Black, Azure Blue, Enchanting Lilac, and Raspberry Red).
  • WONDERBOOM 4: $99.99 (Active Black, Hyper Pink, Cobalt Blue, and Joyous Bright)
  • MEGABOOM 4: $199.99 (Active Black, Cobalt Blue, Raspberry Red, and Enchanting Lilac)
  • BOOM 4: $149.99 (Active Black, Cobalt Blue, Raspberry Red, and Enchanting Lilac)
Related Reading
Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
JADIS JS2 SL DAC Front Angle Top Open JADIS JS2 SL DAC Front Angle Top Open
Do you really need a DAC that costs between $14,000 and $18,000? Bluebird Music thinks the Jadis Vacuum Tube JS5 or JS2 SL are...
Samsung Neo QLED TV 2025 with Vision AI Samsung Neo QLED TV 2025 with Vision AI
HDTV 4K & 8K TV
Samsung just unveiled pricing and availability details for its full line of Neo QLED TVs in both 4K and 8K resolution. Potential buyers may...
Samsung HW-Q990D. Samsung HW-Q990D.
The first soundbar with Eclipsa Audio decoding, Samsung's new flagship Q990F may be the one to beat in 2025.
HDTV 4K & 8K TV
The traveling headphone show, CanJam came to New York City last month and we were there. Here are a few highlights.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Craft Recordings announces seven titles coming to participating independent music retailers on Record Store Day, April 12, spanning jazz, salsa, rock and soul.
Daily Deals
Spring time is here and with it the opportunity to bring home a giant TV at a great price to enjoy all the basketball...
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Is it possible to make Hi-Fi and home theater work in really small spaces? EIC Ian White's journey into the great unknown of cabin...
