TV Ones Professional Analog and DVI Cross Converter Now Shipping
The latest problem solving product added to the arsenal of TV One-task products is the 1T-VS-558 Video Scaler. It accommodates resolutions up to WUXGA and 1080p and allows conversion between them as well as between digital and analog. The unit also accepts 480i or 576i YUV interlaced analog component video, such as from a DVD Player for up-conversion. The unit has separate inputs consisting of DVI-D, Analog RGBHV/YPbPr and Analog YUV/YPbPr. It will output Analog RGBHV via HD-15 and DVI-D via a DVI-I connector respectively.
Advanced features, such as 3-D Motion Adaptive De-Interlacing and 3-D Noise Reduction, provide extremely high quality signal conversion. An OSD (On Screen Display) menu system makes the 1T-VS-558 easy to set up and control using the front panel joystick or the Infrared Remote Control. An Auto Adjust button allows for the automatic size and position of the image. DVI Inputs and Outputs are fully HDCP Compliant.
The unit requires external 5VDC and an AC Adapter is provided. It has a locking DC connector for added security. An optional RM-220 Rackmount kit is available that can house either one or two units. The unit has a suggested retail price of £298 (€386) and is available now.
More information regarding this unit along with the entire TV One product line can be found on the TV One website, www.tvone.eu, alternatively you can contact the European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
