The TV One-task 1T-DA-631 HDMI Extender is a dynamic cable equalizer that restores the HDMI v1.3 signal at the end of long cable runs, just prior to the input to the display. The 1T-DA-631 is the first of its kind to offer DDC Correction ensuring that the HDMI signal stays true to the original form. The ultra-compact, high-performance 1T-DA-631 has a Recommended Retail Price of £56 (€83) and is now available.
The 1T-DA-631 has a maximum distance of 40 meters from the source to the Equalizer input and up to 5 meters from the output to the display when using Z-Plus grade HDMI cables. All signal components present within the encoded signal are maintained, including Stereo or 7.1 Audio and HDCP encryption. The circuitry enhances both Plug and Play characteristics as well as the HDCP signal component. HDTV resolutions of 480p, 720p, 1080i and 1080p are supported.
The unit comes in a rugged metal case and is powered from an external power adapter provided with the unit. It features a locking DC Power Adapter for security.
