TV One-task DVI Routing Switcher with HDCP Now Available
The 1T-SX-524 is a professional HDCP Compliant DVI routing switcher that can switch up to four inputs.
MARGATE, Kent UK, 07th March 2008 — The TV One-task 1T-SX-524 DVI Switcher is a compact, high performance product designed to meet the most demanding requirements for the switching of DVI signals with HDCP copy protection. The 1T-SX-524 has four inputs, and it can be controlled from the front panel input selection button or the included infrared remote control. The unit has a recommended retail price of £195 (€287).
The 1T-SX-524 has a maximum pixel rate of 165 MHz and provides resolution capabilities up to 1920×1200 and 1080p. It has DVI-I connectors for the input and outputs and is powered by an included power adapter that provides 5VDC for operation. If a conflict exists with other IR remote controls in the operational environment, the included IR remote controller can be easily reprogrammed to avoid the problem.
An LED display indicates the current input selection and the presence of DC Power. An IR Remote Receiver Option is available for applications requiring the unit to be hidden from view or when it is desirable to extend the range beyond a direct view of the unit such as around a corner.
This product as well as the entire TV One product line can be viewed on their website www.tvone.eu, alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Hisense S5 DecoTV Front Lifestyle Hisense S5 DecoTV Front Lifestyle
Hisense’s S5 DécoTV proves not every TV needs to be enormous, blindingly bright, or pretending to be a gaming rig—just a smart, good-looking 32-inch...
LG Micro RGB Evo TV 2026 LG Micro RGB Evo TV 2026
LG previews its Micro RGB evo MRGB95B 4K TV ahead of CES 2026, marking a rare LCD shift with bold color claims, AI processing,...
2026 Samsung R95H 4K TV Angle 2026 Samsung R95H 4K TV Angle
Samsung expands its Micro RGB LED TV lineup for 2026, adding 55–100″ models alongside the 115″ flagship as competition in RGB-based TVs heats up.
Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers Bang & Olufsen Beolab 90 Phantom and Mirage Editions Loudspeakers
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
