TV One-task adds RGB/YPbPr Distribution Amplifiers with Stereo Audio
The TV One-task 1T-DA-472 and 1T-DA 474 are high-quality Distribution Amplifiers that distribute two and four RGB/YPbPr signals. They can handle video bandwidth in excess of 500MHz and computer resolutions up to 2560×1600. Both models can send signals over distances of up to 300 feet from the source, without signal deterioration, and are now available for shipping across the world.
The 1T-DA-472 and 1T-DA-474 provide VESA industry standard DDC (Data Display Channel) bi-directional communications for host control of the downstream monitors. Video Input and Output connectors are HD-15 type and 3.5mm Mini-Stereo type for audio. The audio response is 20Hz to 20 KHz.
Both units are housed in small rugged metal cases. They are 5VDC powered and a Power Adapter is included. The DC power connector is a locking type for security. For best performance at long distances, premium grade cables are recommended. Optional single or dual rackmount kits are available.
The suggested retail prices for the units are £76 (€112) for the 1T-DA-472 and £110 (€162) for the 1T-DA-474.
More information regarding these units along with the entire TV One product line can be found on the TV One website, www.tvone.eu, alternatively you can contact the European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
