TV One adds a new 8-input SD/HD-SDI Switcher to its product range
TV One announces the introduction of its latest addition to the TV One product family, the S2-108HD 8-input SD/HD-SDI Switcher. Capable of switching between eight separate inputs of SD-SDI or HD-SDI signals, this new unit addresses the constantly evolving needs of the Pro AV and Broadcast markets.
This 8-input and dual output SD/HD-SDI switcher has been primarily designed to work with the C2-2000 series of switcher/scalers and down converters as an optional Input Expansion Module to provide additional SD/HD-SDI inputs via BNC connectors. Like all current S2 series units that are available, it can connect to the C2-2000 series using an included OPTION interconnect cable and is fully integrated into the control system of the C2-2000 unit to become part of a single Multi-Format Seamless Switcher.
The S2-108HD can also be used as a standalone routing switcher and is fully compliant to SMPTE 292M and 259M. An automatic reclocking and equalization of the incoming signal is employed by the unit for HD-SDI sources from as far as 200m and SD-SDI sources from over 300m away.
It has two SD/HD-SDI outputs (on BNC’s) available that will both output the selected input source simultaneously and each input selector button on the front panel has a small LED light to signify which input has been selected for the output. This light will remain steady and constant when a recognised and accepted signal is connected and will begin to flash if the signal is not acceptable or the signal is lost. As well as using the Front Panel push buttons, the unit can also be controlled using an IR Remote Control and via RS-232.
The S2-108HD is housed in a desktop case and optional single or dual rackmount kits are available. With a recommended retail price of £850 (€1250) this unit is available to order now.
This product along with the entire TV One product line can be viewed on their website www.tvone.eu, alternatively you can contact their European Sales and Technical Department on +44 (0) 1843 873311 or at sales.europe@tvone.com.
T.H.E. Show and IASCA Logos
Car Audio
Upcoming T.H.E. Show events to showcase the latest in car audio systems in partnership with IASCA.
Schiit Audio Mimir DAC Schiit Audio Mimir DAC
The Schiit Mimir DAC offers high-res 32-bit PCM sound, digital preamp functionality, and balanced outputs, all without the fluff of MQA or DSD—just pure,...
NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record NAGAOKA MP-700 Phono Cartridge Playing Vinyl Record
With a non-traditional phono cartridge design, NAGAOKA's MP-700 elevates the vinyl record listening experience at a rather steep price.
Anker Nebula X1 Projector Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
