Tsunami Announces TS Series Battery Terminals
HOLLY HILL, FLA., SEPTEMBER 26, 2007: Tsunami’s TSBT-PN TS Series battery terminals combine sleek design with superior construction and materials to create the total performance package. The pair consists of one positive and one negative terminals, with (1) 1/0GA, (1) 4GA, and (2) 8GA out.
Features include:
• Solid brass blocks
• Satin nickel-plated finish
• High resistance to corrosion
• Injection-molded durable silver base and tinted acrylic cover
TS Series battery terminals are part of Tsunami’s new TS Series, which includes fused and ground distribution blocks, capacitors and mobile and marine speakers. For best results, use with Tsunami premium battery cable.
For additional information, contact Metra Electronics toll-free: 800-221-0932, or visit www.tsunamionline.com. Call for availability.
Based in Holly Hill, FL, with offices in Long Beach, CA, Metra Electronics (www.metraonline.com) is a leader in the auto sound industry as parent company of such consumer and professional installation brands as Axxess, The Install Bay, Raptor, Silencer and Tsunami, as well as the Ethereal brand of home audio/video interconnects.
-30-
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
