Tributaries Debuts Innovative Wall-Plate System for Custom Installations
Industry-leading PROFIT Design adds quality, efficiency and value.
Orlando, FL–January 31, 2006–TRIBUTARIES Cable, producer of world-class audio, video, and digital cabling products for high-end audio-video entertainment systems and custom installations, has introduced an innovative new custom-install wall-plate system. The new PROFIT design fits into standard wall-box dimensions but uses direct termination and a modular design, making custom installation of the full range of high-grade audio, video, communications, and network cabling fast, efficient, economical, and secure.
Unlike wall-plate systems that require in-wall wiring to be first terminated with male connectors, only to be connected again in turn to the female (interior) side of a conventional “keystone” jack, the PROFIT technology utilizes a range of specifically engineered, high-quality, gold-contact connectors that terminate directly to the in-wall cabling, then snap instantly into any of the system’s selection of Standard or Decora Wall Plates. Because no additional parts or crimps are required, PROFIT promises superior connections, enhanced reliability, and reduced installation times.
TRIBUTARIES offers PROFIT snap-in inserts for RCA jack, speaker wire, F-connector, BNC-connector, RJ11 (telecom), and RJ45 (network) connections. With these custom-designed inserts, the company delivers improved signal transfer, reliability, and standard-setting installation speed and convenience. For example, the PROFIT speaker-wire insert uses dual, large-contact setscrews for secure, high-end signal performance and quick setup; the CAT5E-certified RJ45 and the RJ11 PROFIT inserts use simple, no-tool, snap-down termination.
All six PROFIT inserts simply snap in to any PROFIT standard-type wall plate (which are available with cutouts to accept from one to six inserts), or into single, duplex, triplex, or quad subplate inserts for single or dual-gang Decora Wall Plates. Quality-formed from tough, heavy-duty plastic to accommodate even the most refined installations, all Standard and Decora PROFIT Wall Plates and subplates are available in Ivory and White, while the standard-type plates are also offered in Almond and Black.
The full range of TRIBUTARIES innovative PROFIT Wall Plates and insert connectors are now available. Product pricing is available by contacting the factory.
About TRIBUTARIES
Established in 1991 in Orlando, Florida, TRIBUTARIES Cable is an acknowledged leader in the design, production and distribution of high-quality audio and video interconnect cables, speaker wires and electronics. The company prides itself on its customer service, and has won the CE Industry magazine “Inside Track” Supplier Loyalty Awards a total of nine times in the past ten years.
TRIBUTARIES Cable is a wholly owned subsidiary of Gordon J. Gow Technologies, Inc.
For more information, please visit www.tributariescable.com.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
