In-Wall Speakers
Triad DS700se Invisible In-Wall Speakers
Triad DS700se LF In-Wall Speakers
Triad Speakers just released a behind-the-wall 2-way loudspeaker system comprised of two vibration panels per channel: one for high frequencies with another for lows. Each DS700se speaker panel is fed by an external crossover / limiter. The net result is a fuller frequency response (50Hz – 20 kHz); improved mid-range and treble, and greater power-handling (200 Watts peak per channel) than available from the company’s single-panel models. Given its low-frequency capabilities, the DS700se is ideal for home theater and distributed-audio applications that require a high-performing yet completely concealed loudspeaker.
Triad DS700se LF closeup
Triad DS700se LF (low-frequency panel) closeup, also pictured top
The DS700se is the latest addition to Triad’s DesignerSeries invisible speaker line (which consists of 7 single-panel models). Like all the invisible models, the DS700se panels are comprised of a powder-coated aluminum frame, an extremely rigid aluminum honeycomb core with paper skin covering, and electro-mechanical drive devices. The drive devices are transducers comprised of the finest rare earth neodymium magnets. The transducers, which function much like magnets and voice coils in a traditional loudspeaker system, are attached to the aluminum honeycomb core which serves as the vibrating element to generate sound waves.
The DS700se panels easily fit between the wall studs in typical home construction; their depth requirements are less than two-inches. The panel’s paper skin provides a high-bond surface for excellent adhesion to plaster, drywall compound and mud skims.
Triad DS700se HF closeup
Triad DS700se HF (high-frequency panel)
”We found that due to the nature of the dual vibration panel technology, mounting them high atop the wall — in what typically would be deemed an off-axis location — still sounded great;
it did not have any adverse affect on performance or imaging,” says Triad President Larry Pexton. “This added versatility is another significant selling-point of this speaker.”
Price and Availability
The Triad DS700se Invisible In-Wall Speakers are available now for $2,250 per channel including the HPF-2 limiter / filter protection unit. Also available is an optional back-box for sound control. The speaker carries a 10-year limited warranty
DS700se Specifications
  • Dimensions of the DS700se high-frequency panel (inches): 17-23/32 x 13-37/64 x 1-37/64
  • Dimensions of the DS700se low-frequency panel (inches): 17-23/32 x 7-7/8 x 1-37/64
Power-handling per channel (continuous / peak): 100W/200W
  • Frequency Response: 50Hz – 20 kHz
  • Sensitivity: 87dB/2.83V/1m
Impedance: 4 Ohms
Triad DS700se HF In-Wall Speakers
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
