Trends BA-10 Bi-amp Audio System
Trends Audio introduced the BA-10 Bi-amp Audio System, which combines their PA-10.1D Tube Pre amplifier with two TA-10.2 SE Power Amplifiers. With this arrangement each TA-10.2 amplifier operates over a restricted frequency range. This restricted range presents each TA-10.2 amplifier with a much simpler job and each TA-10.2 amplifier is less likely to “influence” the sound in some way. The speaker’s internal crossover consists of a LPF (low pass filter) and a HPF (high pass filter).
Monoblock setup
Horizontal Bi-amp setup
Vertical Bi-amp setup
Features
  • Doubling surface area of contacts.
  • Doubling surface area of wires.
  • Be able to curtail the wires to better suit each application.
  • Reducing the load on each amp.
  • Reducing the bandwith of the wires often results in greater detail.
  • The reduction of load is even greater.
  • Have fun tube rolling with the fantastic Pre amplifier.
  • New 4mm thick aluminium case provides outstanding shielding & grounding capability to keeps the background silent and maximize the S/N ratio.
The Trends BA-10 Bi-amp Audio System includes the following components:
  • 2 x Trends TA-10.2P Class-T Power Amplifier.
  • 1 x Trends PA-10.1D Tube Headphone/Pre Amplifier.
  • 2 pair x Trends QB-773 Audiophile Audio Cable.
Price and Availability
Trends BA-10 Bi-amp Audio System is available now:
  • $699 (with Russian 6H23n tube) SE version
  • $699 (with USA 12AU7 Tube) GE version
Skullcandy Method 360 ANC Wireless Earbuds inside case in-hand in bone (white)
Earbuds & In-Ear Headphones
In-Wall Speakers
