Audio Cables
Trends Audio CQ-500 Audiophile Speaker Cable
Trends Audio introduced the CQ-500 Audiophile Speaker Cable constructed with Single Crystallized Copper (OCC) conductor materials — a special type of high purity Oxygen Free Copper (OFC) in which the whole copper rope is a composite of single copper crystal. There is no “Crystal Boundary” between crystals for extremely high signal transmission capability. (“Crystal Boundary” reflects and refracts the signal to produce distortion and signal decline.)
Trends CQ-500 Audiophile Speaker Cable is protected by insulation layer and the core conductor is twisted by multiple OCC copper ropes. Also, the Trends 24K gold-plated plugs are connected into both ends and it is the prefect combination between Trends TA-10 Class-T amplifier and Trends SA-10/10R speakers for setting up a cost effective audiophile stereo and home theatre systems.
Specifications
  • Conductor: Single Crystallized Copper (OCC)
  • Braiding Shield: Sliver-Plated Pure Copper
  • Plug: 2 x Banana Plug ~ 2 x Banana Plug or 2 x Crab Plug ~ x Crab Plug
  • Plug Material: 24k Gold-Plated Pure Copper
  • Overall Diameter: 16mm
  • Length: 2.5M
  • Piece: 2
  • Snack-Skin Sleeve: Yes
  • Ferrite Ring Noise Filter: Yes
  • Color: Black
Price and Availability
Trends Audio CQ-500 Audiophile Speaker Cable is available now for $109 (with Banana Plug) or $119 (with Crab Plug).
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
