TP-LINK TL-WR700N 150Mbps Wireless N Mini Pocket Router
TP-LINK announced a 150Mbps Wireless N Mini Pocket Router (TL-WR700N) which can be used to create an instant Wi-Fi hotspot by plugging in an Ethernet cable from your existing network or modem. It is a smart solution to efficiently expand your wireless network for the use of Wi-Fi enabled laptops, mobile phones, tablets, game consoles and more. The Mini Pocket Router operates as an Access Point to create a Wi-Fi hotspot from a wired source. It also functions as a Wireless Router, Range Extender or Wireless Bridge. The stylish cube design is small enough to fit into your pocket and plugs right into an electrical outlet without the hassle of using a power cord.
TL-WR700N is small enough to put into your pocket and take on the road to share the Internet. When your hotel only offers a wired network connection, just plug the network cable into the TL-WR700N and enter the default password to enjoy the convenience of wireless networking in your hotel room.
TL-WR700N supports the newest 802.11n standard, and provides backward compatibility with older 802.11b/g standards as well. With wireless speed up to 150Mbps, high bandwidth-consuming applications such as video streaming, using VoIP, or online gaming
Features
  • Wireless N speeds of up to 150Mbps
  • Compact, sleek design
  • Fully compliant with 2.4GHz-2.4835GHz Wireless Frequency
  • Supports AP, Bridge, Repeater (Range Extender), Wireless Router operation modes
  • Compatible with any Wi-Fi enabled devices, such as iPhone, iPad, Android Phones, Kindle, game consoles and other entertainment devices
  • Advanced security and encryptions
Price and Availability
The TP-LINK TL-WR700N Pocket Wi-Fi Router will be available November 23, 2011 for $29.99.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
