Totem Acoustic’s LOON Bookshelf Speakers are Crazy Affordable
At $1,299/pair, the Totem Acoustic LOON is the company’s most affordable bookshelf speaker yet.
Totem Acoustic Loon Bookshelf Speakers in White, Walnut and Black Ash
For nearly four decades, Montreal-based Totem Acoustic has been a leader in developing loudspeakers capable of reproducing a genuinely musical and involving experience.
Entering its 37th year of operation, Totem Acoustic has introduced its most affordable bookshelf loudspeaker. At $1,299/pair the Totem LOON Monitor joins other bookshelf models including the Bison Monitor ($2,250/pair), Signature One ($3,500/pair) and Element Fire V2 ($7,500/pair). In addition LOON can also be used as rear surround speakers with the Bison Series.
Totem Acoustic says its new LOON as its namesake implies, has an entrancing, hypnotic and mystical ability to transmit sound in a fluid and completely engaging manner. Like a Loon, transferring not only sound but a mysterious, sonic energy that endlessly engages… transferring deep emotion, speed and balance within a quasi-full range sound experience.
As Totem Acoustic’s smallest bookshelf speaker, LOON should work best in smaller listening spaces, while carrying on the brand’s award-winning performance set decades ago from the original Model 1 (discontinued).
Totem Acoustic Loon Bookshelf Speakers Walnut
Totem Acoustic LOON
LOON Compared
LOONBison MonitorSignature OneElement Fire V2
MSRP$1,299/pair$2,250/pair$3,500/pair$7,500/pair
Design:Ported 2-way designPorted 2-way designPorted 2-way designPorted 2-way design
Recommended Power: 20-110W30-150W50-200W50-250W
Frequency Response (±3 dB)51 Hz – 26 kHz 40 Hz – 29.5 kHz45 Hz – 22 kHz30 Hz – 22 kHz
Woofer:5.75” woofer with copper clad voice coil5.25″ (13.335 cm) long throw (3 inch Voice Coil)6.5″ (16.51 cm)  3″ (7.62 cm) voice coil7″ Torrent
Tweeter:1” (2.54 cm) laser etched textile soft dome tweeter1.3″ (33 mm) Laser Etched Textile Soft Dome1″ (2.54 cm) aluminum dome, chambered1″ (2.54 cm) Titanium dome with 3/8″ aluminum faceplate
Impedance:8 Ohm8 Ohm8 Ohm8 Ohm
Sensitivity:87 dB87 dB87.5 dB88 dB
Placement from rear wall:6” – 3′6″ – 3′
(15.2 – 91.44 cm)
1′ – 3′
(30.48 – 91.44 cm_
As little as 6″, but varies based on electronics and room acoustics
Placement distance apart:3’ – 8’3′ – 10′
(91.44 – 304.8 cm)
4′ – 12′
(121.92 – 365.76 cm)
As little as 2′, but varies based on electronics and room acoustics
Break-in Time:70-100 hours70-100 hours100-150 hours200-300 hours
Crossover Frequency:2.5kHz (first order)2.5 kHz (first order)2.5 kHz compensated, 2nd orderFirst order crossover on tweeter only
Speaker Terminals:4 way Bi-Wire-able4 way Bi-Wire-ableBi-wireable, Gold WBT connectorsBi-wireable, Platinum WBT connectors with Annealed aluminum plate
Weight: 8.5 lbs29.75 lbs
(13.49 kg)
23.1 lbs
(10.5kg)
32.4 lbs
(14.74kg)
Width:6″6.732″
(171mm)
7.67″
(19.5 cm)
8.81″
(22.38 cm)
Height:10.75”13.110″
(33.3 cm)
13.77″
(35 cm)
16.6″
(42.164 cm)
Depth:8”
(8.375” with grill)
9.567″
(24.3 cm)
9.961″ (with grille)
(25.3 cm)
10.62″
(27 cm)
11.7″
(29.718 cm)
Totem Acoustic Loon Bookshelf Speakers White
Totem Acoustic LOON
In the words of chief designer Vince Bruzzese, “The LOON monitor offers a very uncomplicated placement, virtually a Plug n’ Play loudspeaker that yields great sonics even when listening from over 45 degrees off-axis. Bass is deep and tight, yet not exaggerated, with an excellent impact and decay all from a very small cabinet. Furthermore, there is absolutely no sense of boxiness in the sound and voices never sound congested.”
The LOON is said to produce full bandwidth sound even at low volume, all the while with astonishing imaging. Totem also claims LOON sounds fabulous with all genres of music at any listening volume.
Totem Acoustic Loon Bookshelf Speakers Black Ash
Totem Acoustic LOON
Price & Availability
The Totem Acoustic LOON has an MSRP of $1,299/pair USD and is now shipping in Black Ash, Black Walnut (new) and Satin White.
LOON will be actively displayed during AXPONA, APRIL 12 – 14, 2024 in suite 378 at the Schaumburg Convention Center,  Chicago, IL.
Totem Acoustic Loon Bookshelf Speaker Rear Walnut
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
HDTV 4K & 8K TV
DTS:X is an immersive surround sound format that is both similar to and different from Dolby Atmos. Find out how DTS:X and its variations...
Does it make sense to spend more than most audiophiles spend on their entire system on a little box that makes your power clean?
HDTV 4K & 8K TV
The well known TV reviewer and tech journalist extraordinaire has announced the launch of a new company, CD Creative Media LLC and a new...
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Discover the best affordable Hi-Fi brands of 2025 leading the stereo audio revival with premium sound at budget-friendly prices.
