Totem Acoustic’s KIN ONE Loudspeaker Looks Rather Ideal For Smaller Rooms and the Desktop
At $599/pair, the Totem Acoustic KIN ONE bookshelf speakers promise performance far beyond its size and price.
Totem Acoustic KIN One Bookshelf Speakers Front Colors
Totem Acoustic has been one of the foundational brands in Canadian high-end audio for almost 38 years, and the Quebec-based manufacturer has certainly proven that it knows how to build great sounding loudspeakers. There are enough industry awards in its front lobby to make even the Montreal Canadiens a tad envious. Can the new Totem Acoustic KIN ONE earn additional hardware for the lobby?
The two-way monitor loudspeaker has been their area of expertise and few companies have done so well with consistency.
Think highly musical, accurate, perfect phase coherency and three-dimensional  expansiveness, all the while, yielding performance that defies their size.
Over the years, Totem Acoustic’s loudspeakers also became a lot more expensive and that priced them out of the entry-level segment of the market which became dominated by Q Acoustics, PSB, Wharfedale, KEF, and ELAC.
It’s much easier to make a great loudspeaker with a much higher price point compared to something that is priced in the $500 to $600 range; the compromises when it comes to driver selection, crossover components, cabinet design and materials, and finishes are completely different.
KIN ONE
Totem Acoustic KIN One Bookshelf Speaker Colors
Totem Acoustic KIN ONE Bookshelf Speakers in pink, black, orange, white and teal.
So why are we excited about the new Totem Acoustic KIN ONE?
$599 USD. Say it again. $599 USD.
Through the use of “trickle-down” technology with respect to driver technology, cabinet design and its crossover circuitry, the KIN ONE performs far beyond both its price point and physical stature. In essence, a great deal of technical know-how learned from Totem products, including the legendary “Model One” and Element FIRE v2, was applied to the KIN ONE design.
Further, thanks to 5 different satin finishes and its placement flexibility — this new bookshelf loudspeaker might be a great option for smaller rooms and even your desktop.
Totem Acoustic KIN One Bookshelf Speaker in Teal Lifestyle
On a technical level, the KIN ONE uses specific custom proprietary drivers. The MHEX woofer (Multiple Strata Hex Cone) is stiffer than metal but reacts very fast and sounds like paper.
The titanium infused soft dome tweeter is matched to both this woofer and the cabinet, resulting in perfect phase response. Next, upon a first look at the KIN ONE you can’t help but notice they appear to be a much smaller version of the “Element Fire V2” (which has an MSRP that is 14 times more expensive).
This specific cabinet geometry assists with the precise base tuning of the KIN ONE in conjunction with the crossover. Using just seven high quality precision components, the 2nd order crossover is minimalist but an effective way to achieve maximum performance from the two aforementioned drivers and the custom cabinet.
Finally, there’s an “L shaped” port to achieve a much longer length in a small cabinet to virtually eliminate cabinet resonances. This port design allows information to exist below 65 Hz (i.e. 40 Hz @ -12dB).
KIN ONE Features:
  • Ported 2-way design
  • 1” Titanium Infused Soft Dome tweeter
  • 4” MHEX Cone Woofer
  • Nominal Impedance: 6 ohms
  • Sensitivity: 89 dB @ 1watt
  • Crossover Frequency: 2.5 kHz (second order)
  • Frequency Response: 65 Hz to 22 kHz ± 3 dB
  • Recommended power: 20 – 100 watts
  • Dimensions (W x H x D):
    • 5” x 9.5” x 6.25” (bottom) x 5.25” (top)
    • 12.7 x 24.3 x 15.9 cm (bottom) x 13.3 cm (top)
  • Weight: 6.25 lbs each
  • Available satin finishes: Pink, Blue, Orange, Black and White
  • Matching magnetic grills included
  • Recommended placement: 3” – 2’ from rear wall / 3’ – 12’ apart
  • Wallmount Thread: ¼”–20 allowing the speakers to be mounted directly on the wall
Totem Acoustic KIN ONE Bookshelf Speaker in Pink Lifestyle
Totem Acoustic KIN ONE Bookshelf Speaker in pink
Initial Thoughts
The $500 to $700 category has a lot of competition from the aforementioned brands and the KIN ONE will have to offer more than just solid build quality and engineering to compete.
The cabinet is on the smaller side and we suspect that the loudspeaker will benefit from some low end support in the form of a subwoofer to really show off what it can do above 80Hz.
Totem has established that it knows how to build a great sounding loudspeaker and we suspect that these will offer the “house” sound with some trade-offs in regard to bass response.
The impedance and sensitivity rating look rather amplifier-friendly on paper, but our experience with their loudspeakers over the years tells us that they like power and that “20 watts” on the low end is probably not going to cut it.
A network amplifier from Denon, NAD, Bluesound, WiiM, or Marantz might be ideal for these and keep the overall footprint rather compact. However, Totem’s integrated KIN AMP (with Bluetooth aptX HD, 100-watts per channel, analog & digital inputs) could be a cost-effective pairing at $1,199.
Having not listened to these yet, we don’t know which way the tonal balance and overall presentation tilts.
At the $599 USD price, they might be a great option if you don’t have a lot of space.
Where to buy: kinbytotem.com
Related reading: Totem Acoustic’s LOON Bookshelf Speakers Are Crazy Affordable
XGIMI is marketing its portable projection screen as a complement to its MoGo 3 Pro video projector for outdoor movie watching.
LG G5 OLED TV Lifestyle LG G5 OLED TV Lifestyle
HDTV 4K & 8K TV
Will LG's new quad stack Primary RGB Tandem OLED panel make the G5 the best TV of 2025? And what should we expect from...
HOUCHMAND M1 System Lifestyle Image HOUCHMAND M1 System Lifestyle Image
The Houchmand M1 is an ultra high-end all-in-one two-channel digital music system with optional subwoofer for a sky high price.
Hisense 2025 ULED TV line-up Hisense 2025 ULED TV line-up
HDTV 4K & 8K TV
Brighter, bigger, and more powerful, the Hisense 2025 ULED TV lineup should have something for everyone.
Pro-Ject Automat A1.2 Turntable Lifestyle Pro-Ject Automat A1.2 Turntable Lifestyle
Updated with a new die-cast aluminium platter, Pick It MM E phono cartridge and other refinements, the Automat 1.2 might be the most logical...
NAGRA Compact Phono Stage Angle NAGRA Compact Phono Stage Angle
At $4,950, the Nagra Compact Phono is a "lower cost" high-end audio solution for getting the most out of your vinyl record listening experience.
Larger cabinet, bi-wiring, new crossover, and reengineered bass port are only some of the changes for the new Triangle BOREA BR04 which will retail...
Before you get too excited, British audiophiles are getting a much better deal on these Heritage Series Limited Edition loudspeakers.
For 2025, the Audioengine A2+ now includes Bluetooth 5.3, 24-bit audio, and USB-C connectivity - still at an affordable price.
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
Looking for the best bookshelf or stand-mounted speakers below $1,000 in 2023? We have 11 options that have impressed us enormously.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
The definitive buying guide to the best bookshelf speakers from $300 to $1,400. Our picks from the best high-end brands.
Can an innovative 17-year old speaker designer with a familiar last name breathe new life into the jaded audiophile loudspeaker industry?
