TIDAL for Bugatti Royale Loudspeaker: High End Munich 2023
TIDAL Audio and luxury automaker, Bugatti, have collaborated on a 4-way active loudspeaker that promises performance commensurate with its 6-figure asking price.
Tidal for Bugatti Royale Black and White Loudspeaker Pair
High End Munich 2023 is in our rearview mirror and one trend that we noticed from the show was the introduction of flagship and cost-no-object loudspeakers from a increasing number of brands. TIDAL has always focused on the top end of the market so we’re not surprised to see this collaboration with Bugatti; the new TIDAL for Bugatti Royale Loudspeakers are a lot more than just some styling changes and have certainly attracted a lot of attention.
Taking its name from the Bugatti Royale automobile these speakers are designed to look as good as they sound. Hopefully better.
tidal-bugatti-black-rra
Tip: TIDAL Audio is a different company than the Tidal Music streaming service you may be more familiar with.
Core Features
Woman listening to Tidal for Bugatti Royale Black Loudspeakers
At its core, the TIDAL for BUGATTI Royale is a 4-way hybrid-active multi-channel powered active loudspeaker. This means that these speakers house their own amplifiers, so no need to connect them to an external amplifier or AV receiver, and sources can also be connected directly. However, the speakers do need to be connected to AC power.
The Royale features luxurious industrial strength a TIRALIT™ Ultra polycast matrix cabinet with decoupled isolation front plate and stand frame.
Tidal for Bugatti Royale White with Wood Veneer Loudspeakers
There are two cabinet themes:
  • DUOTONE – This theme offers choices of colors and materials that harmonize with each other. One example is a white front combined with a polished Macassar veneer back. Another choice might be a combination of a black piano finish with dark grey carbon fiber.
  • MONOCOQUE  – This theme provides a “shaped out of one block” theme. Buyers have a choice of single colors in either real piano lacquer or original Bugatti lacquer.
Tidal for Bugatti Royale Monocoque Loudspeaker Pair
Specifications
  • Amplification: TIDAL T4B amplifiers.
  • Tweeter: 1 x 30 mm high efficiency T4B diamond tweeter
  • Mid/Woofer: 1 x 127 mm high efficiency T4B diamond midrange-woofer
  • Woofer: 2 x 170 mm T4B woofers with aluminum-magnesium alloy diaphragm
  • Subwoofer: 4 x 265 mm T4B long-throw subwoofers with aluminum-magnesium diaphragm
  • Frequency Response: Information not provided
  • Crossover Points: Information not provided
  • Connections: LAN-remote, XLR, Royale-Link, power cord input
  • Onboard Controls: Bass tone/bass level/bass adjustment based on speaker placement.
  • Dimensions (HWD – each speaker): 144 x 28 x 60 cm (56.7 x 11 x 24 inches)
  • Net Weight: 2 x 217 Kg / 2 x 480 lbs.
  • Price: €260,000 – €503,000 ($318,000 – $616,000 USD) per pair, depending on the finish options chosen.
Tidal for Bugatti Black Carbon Loudspeaker Driver Detail
Finish Options: Customers can order their own “pair unique”. This includes metal parts: Aluminum, Stainless Steel, and Precious Metal. Finish options include velvet glass-pearl blasted, brushed, or structure, silver, gray, dark, or other custom colors. Side speaker grills are available in carbon fiber, leather, or one of several metal options.
Tidal for Bugatti Royale Monotone Black and White Loudspeakers
Tip: The first models were in either “ROYALE Edition Blanc” and “ROYALE Edition Noir” (White or Black) exterior finish options. Each was limited to only 15 pairs of each.
Tidal Royale MC-1
Tidal Audio Royale MC-1 DAC Controller
In addition to the speakers, TIDAL Audio also offers their recommended source controller, the Royale MC-1 DAC (Digital-to-Analog Converter) with lossless volume control.
Tip: Tidal Audio Refers to the Royale MC-1 as a Digital to Music Converter (DMC). For the purposes of this article, the two terms are interchangeable.
Tidal Audio Royale MC-1 DAC Controller Black
MC-1 Specifications
  • Control: Wireless Remote control and iOS devices (no Android).
  • Wired Sources: Internal streamer (upgradeable) or digital in via Toslink, BNC, RCA, AES, USB.
  • Wireless Sources: Streaming content via USB, DNLA network, Airplay, and music streaming services
  • Finish Options: Customer choice of metals, carbon fiber, leather, and colors for top cover and side panel inlays.
  • Dimensions (WDH): 46 x 42 x 12 cm (18.1 x 16.5 x 4.72 inches)
  • Net Weight: 1 x 33 Kg (72 lbs 13 oz)
  • Price: €48,000 (~$52,000 USD)
Availability
For details on pricing options, availability, and delivery for both the loudspeakers and MC-1, check out the Bugatti Partner Website
Tidal for Bugatti Duotone Orange Black Loudspeakers
Tidal for Bugatti Royale Blue and Black Loudspeaker Pair
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
With support for 32-bit/384kHz PCM, DSD and aptX HD, the Rotel DX-3 cuts down on the number of components you need for headphone listening...
Digital Music Systems
The Audioengine B1 has been updated with Bluetooth 5.3, aptX Adaptive, and 32-bit Audio, but still has the same $189 price tag
Our favorite floorstanding loudspeakers to buy in 2024 are from Bowers & Wilkins, JBL, Magnepan, Q Acoustics, SVS and Zu Audio,
At $3,680, the Eversolo DMP-A10 music streamer packs in so much it just may be the Swiss Army Knife of network streamers.
Borrowing design concepts from TEAC’s top-of-the-line 700 Series, the standout feature of the UD-507 is TEAC’s new proprietary "TRDD5" (TEAC Reference Discrete DAC) designed...
