Loudspeakers
THIEL Audio Announces Delivery of CS3.7 Loudspeakers
US loudspeaker company THIEL Audio (www.thielaudio.com) has announced that the much anticipated CS3.7 floor standing 3-way loudspeaker is now shipping to authorized dealers. The CS3.7 utilizes all newly developed drivers, including a 5-inch ribbed midrange diaphragm that eliminates audible resonances while simultaneously reducing diffraction and reflection of energy from the very high output 1-inch tweeter. The 10-inch woofer diaphragm geometry increases strength while lowering overall mass for wider bandwidth and higher efficiency. The output of the woofer is augmented by an auxiliary bass radiator. “My goal in designing the CS3.7 was to achieve a level of performance greater than any previous product,” says Jim Thiel. “To achieve that goal the 3.7 incorporates all we have learned, every innovation we have developed over the last 30 years, and adds to that several exciting, newly developed solutions to some of the most difficult challenges confronting the loudspeaker engineer. It is this pursuit of the highest possible sound quality that motivated me to begin THIEL, and it is still my passion.” The enclosure of the CS3.7 abounds with innovations as well–the cabinet top is made of formed aluminum that lessens cabinet resonances, diffraction, and serves to reduce internal standing waves. The bent-laminated side panels are extremely rigid and the driver mounting surface (baffle) is machined aluminum. MSRP for the CS3.7 is $9900 per pair.
TECHNICAL HIGHLIGHTS
• Extremely accurate frequency response
• Complete phase and time coherence
• New ribbed driver diaphragm geometry for greatly reduced internal resonances
• High Sensitivity (90db)
• Low diffraction/coloration cabinet design due to ultra-rigid formed aluminum top and machined aluminum baffle, bent-laminated cabinet sides, and internal bracing
• Low distortion short coil/ long gap, copper stabilized motor systems
• Ultra high quality electrical components (crossover network)
• Coaxial/Coincident midrange/tweeter assembly
SONIC PERFORMANCE
• Highly realistic tonal character
• Accurate and precise imaging
• Ultra low distortion resulting from short coil/ long gap, copper stabilized driver magnet systems
• Overall high resolution resulting from low resonant driver diaphragms, exceptionally strong cabinet design and construction, and unusually high quality electrical components
• Wide dynamic range resulting from high efficiency and high output driver designs
CELEBRATING 30 YEARS OF HIGH PERFORMANCE IN 2007
THIEL Audio Products Company is a privately-held engineering-driven organization that performs research, design, and manufacturing of loudspeakers for the highest quality home music and video sound reproduction. Our products incorporate a variety of technological advancements in driver design, acoustical construction techniques, and crossover design. All our work is directed toward one end: to provide the most realistic sound reproduction possible. THIEL manufactures sixteen individual products; the surface-mount PowerPoint 1.2; in-wall PowerPlane1.2; in-ceiling HigherPlane1.2; flat-panel video display speaker ViewPoint; SS1, SS2, SS3, and SS4 subwoofers; bookshelf-sized SCS4 and MCS1; and the floor-standing CS1.6, CS2.4, CS3.7, all ranging in price from $990 to $9,900 EA.
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
