Theory Audio Design’s iws12-6 & iws12-9 In-Wall Subwoofers Are Going To Shake Your Foundation: CEDIA 2022
Theory Audio Design has introduced 2 new architectural subwoofers designed to work with their existing soundbar theater system.
Theory Audio Design IWS12-6 In-wall Subwoofer pair
High-end commercial and residential audio brand, Theory Audio Design has announced its first subwoofers designed for in-wall or in-ceiling installation for either residential or commercial applications, the iws12-6 and iwsS12-9.
One advantage of these subwoofers is that they eliminate the need to find floor space for traditional subwoofer boxes. However, to ensure they are placed in the right spot, they need to be installed by an authorized dealer.
It’s also important to note that, unlike most subwoofers, these subwoofers are passive. This means you have to place an external amplifier between the subwoofer and home theater processor.
Theory Audio Design In-wall Subwoofer family
Theory Audio Design iw5, iw6, iw25 in-wall speakers and iws12-6 in-wall subwoofer.
In the case of Theory Audio Design, you have to use a Theory ALC (Amplified Loudpseaker Controller) to power the iws12-6 or 12-9 compact enclosures. The subs are the perfect complement to Theory Audio’s other speakers.
EIC Ian White reviewed the Theory Audio Design 5.2.2 Soundbar System in 2021 and considers it to be the benchmark for all soundbars regardless of price. Either subwoofer announced at CEDIA 2022 can be integrated into that system.
Theory Audio Design iws12-6 In-wall Subwoofer pair
The iws12-6 has an enclosure that can be installed flush into 2×6 stud walls, or surface mounted with only 5.5-inches of total depth.
The iws12-9 adds more installation flexibility as it can not only be wall or ceiling mounted but can also be placed on the floor as an in-room subwoofer where a compact, high-performance subwoofer is desired.
Theory Audio Design iws12-9 Subwoofer
Specifications
The following features and specifications are shared by both the iws12-6 and iws12-9 subwoofers:
  • Subwoofer Type: Passive, Requires external amplification from a  THEORY ALC Amplifier (1 channel for each subwoofer used).
  • Driver Number and Size: 1 x 12-inch driver with 1400 watt, 4-inch voice coil, Long throw design.
  • Frequency Response: 24 – 125Hz ±3dB, bass extension down to 18Hz ±10dB
  • Sensitivity: 95.5dB
  • Power Handling: 700 watts (AES)
  • Impedance: 8 ohms
  • Weight: 49lbs
Differences
Subwoofer Model iws12-6iws12-9
Available ColorsBlack, Optional White Perforated Metal GrilleBlack, Back Perforated Aluminum Metal Grille, Optional White Perforated White Metal Grille
Included AccessoriesLow Profile Angle Mount Brackets for 16-inch O.C. StudsBlack Perforated Aluminum Grille
Optional AccessoriesWhite Perforated Low-Profile GrilleYoke Surface Mount Bracket, White Perforated Metal Grill
Dimensions (WHD)14 x 60 x 5.5-inches34 x 14 x 9-inches
Price$1,900$2,050
Tip:  Price does not include installation or other required components.
Theory Audio Design products can be purchased and installed through Authorized US and International Representatives.
View all products announcements from CEDIA 2022.
Networking
Earbuds & In-Ear Headphones
In-Wall Speakers
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Unwind in the ultimate man cave and escape into home entertainment bliss with incredible gift ideas for hi-fi audio or home theater.
With a 5,000-lumen light output the Optoma UHZ68LV home theater projector can work with screens up to 300-inches.
Audio Cables
What we know so far about the new HDMI 2.2 specifications and whether they really matter.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
At $279.99, the Creative Pebble Nova desktop speakers feature coaxial drivers with both wireless and wired connectivity.
The eCoustics editorial team grows to its largest point ever, adding coverage for new music releases and custom installation A/V solutions.
New products from Apple, Beats, JBL, Sony and Hisense are sure to be atop everyone's wishlist this Holiday season. Order now to beat the...
