Theory Audio Introduces Next Generation of DLC Loudspeaker Controllers
Specifically designed for use with Theory loudspeakers, new controllers offer a cosmetic refresh, Dante network audio with AES67 compatibility, and an all-new 8-channel amplifier.
Theory Audio Design DLC 2024
COVID had a profound impact on the world and that included numerous segments of the economy that have not yet fully recovered. If that sounds hard to believe as we finish Q2 of 2024, an in-depth look at the box office numbers across North America on Memorial Day weekend makes our case rather convincingly.
Just how bad was it? The worst in decades.
The pandemic forced moviegoers to watch from home and that became a huge opportunity for companies that could offer the best soundbars, in-wall/in-ceiling, and outdoor CI loudspeaker options.
Theory Audio Design took advantage of the newfound interest in the CI market and has been charging ahead ever since with some of the best solutions on the market. We’ve tried many of them at home and at industry trade events and the overall consensus is that Paul Hales builds a much better box than most of his rivals.
They also build amplified loudspeaker controllers and we’re not surprised to see a new series as they significantly expand their residential and commercial product lineups.
Theory Audio Design has announced 3 new Amplified Loudspeaker Controllers to drive their expanded CI loudspeaker lineup.
Overview
Ideal for residential or commercial installations, the new models provide intelligent power, a full DSP matrix, and TCP/IP control through a wired connection, or directly via its onboard Wi-Fi access point.
The DLC-250.8 and DLC-1500.4d are full-size rack mount units with extensive high power output and flexible setup options for large setups. The DLC-250.4 has almost all the features of the DLC-250.8, but has 4 instead of 8 channels and a more compact 1/2 rack design.
This is an option for more modest installations. Two of the three models, the DLC-250.4d and DLC-1500.4d, also add Dante and AES67 audio-over-IP digital I/O compatibility. S/PDIF master/slave functionality allows multiple DLCs to be used to cover all these needs and each loudspeaker controller only takes up two rack spaces maximum.
DLC-250.4d
Theory Audio Design DLC-250.4d Front and Rear View
The DLC-250.4d is a 4-channel Loudspeaker Controller that is designed to be a part of any Theory distributed audio system. With channel-pair power-sharing of up to 250W, each DLC-250.4d offers the flexibility to power any system size. The ½ RU DLC-250.4d ships with a rack kit to allow mounting of one or two units in a single rack space. An optional surface mount kit is also available if hiding the DLC-250.4d under a table or behind a TV is desired.
DLC-250.8
Theory Audio DLC-250.8 Front Angle
The DLC-250.8 is ideal for surround and distributed audio systems where Dante and AES67 are not required but when more channels per chassis are desired. DLC-250.8 offers the same power per channel and power-sharing capabilities as the DLC-250.4d with four additional channels (8 channels total) in a 1U chassis.
DLC-1500.4d
Theory Audio Design DLC-1500.4d Front and Rear Views
The DLC-1500.4d 4-channel Distributed Loudspeaker Controller packs massive power into minimal rack space, offering a massive 3,000W from a 16-pound, 2U chassis. Designed for high-output Theory distributed or surround audio systems, the DLC-1500.4d can deliver 1,500W into 4 or 8 ohms from any channel pair, or 800W into 2 or 4 ohms with all channels driven.
Home Theater Applications
For home cinema and surround sound systems, a single DLC-250.4d is perfect for 3.1 systems (or more when multiple amplifiers are used), a single DLC-250.8 can handle 7.1 systems, and the larger more powerful DLC-1500.4d can handle large screen and professional loudspeakers and subwoofers. The DLC platform is safety and EMC-certified and compliant with ErP and EnergyStar.
Theory Audio Design Soundbar Home Theater System Room Lifestyle
From Paul Hales, CEO and product designer for Theory Audio Design: “The new generation of Theory DLC loudspeaker controllers offer all the advantages of their predecessors with the addition of audio over IP, an entirely new 8-channel model, and a cohesive new industrial design across the line,…Now with Dante and AES67 compatibility, even the most complex Theory distributed audio systems can be set up and deployed quickly and painlessly with no bulky analog audio cables required. And the system is bulletproof so when the job is complete the installer can move on without concerns about support calls or truck rolls.”
Comparison
DLC-250.4dDLC-250.8DLC-1500.4d
Price$2,495$3,500$4,750
Channels484
Description4-Channels
Dante & AES67
Half-Rack Chassis
IP Control via Ethernet or Built-In WiFi Access Point
Power Sharing Between Neighboring Channels
8-Channels
1U Chassis
4-Channels
Dante & AES67
2U Chassis
LoZ BTL Mode
OperationLoZ and HiZ (70V/100V)LoZ and HiZ (70V/100V) LoZ and HiZ (70V/100V)
Inputs4 x Balanced Analog Audio
4 x RCA Unbalanced Analog Audio
1 x S/PDIF Digital Audio (stereo)
4 x Dante/AES67 Digital Audio
8 x Balanced Analog Audio
8 x RCA Unbalanced Analog Audio
Outputs4 x Speaker Outputs
4 x Dante/ AES67 Digital Audio
8 x Speaker Outputs
4 x Speaker Outputs
Trigger+12VDC+12VDC+12VDC
Audio Operation48kHz/24-bit48kHz/24-bit48kHz/24-bit
On-Board DSP48kHz/32-bit48kHz/32-bit48kHz/32-bit
DSP FeaturesLoudspeaker Processing For All Theory Models plus:
Input Matrix Mixer
5 Parametric Input
EQ Filters
Input Trim
Stereo/Mono Inputs and Zones
Signal Routing Including Priority Automatic Routing
Audio Ducking
10 Parametric Output EQ Filters
Crossovers
Gain
DelayPolarity
Peak and RMS Limiters
Loudspeaker Processing For All Theory Models, plus:
Input Matrix Mixer
5 Parametric Input
EQ Filters
Input Trim
Audio Ducking
Crossovers
Gain
DelayPolarity
Input Matrix Mixer
5 Parametric Input
EQ Filters
Input Trim
Audio Ducking
Crossovers
Gain
DelayPolarity
Frequency Response20Hz-20kHz, +/-0.25dB20Hz-20kHz, +/-0.25dB20Hz-20kHz, +/-0.25dB
Power Output250W per channel @ 4, 8, 16-ohms and 70V/100V
125W per channel @ 4, 8, 16-ohms all channels driven
125W per channel @ 70V/100V all channels driven
2x 1500W (BTL) @ 100V2x 1200W (BTL) @ 70V
4x 400W (SE) and 2x 1500W (BTL) @ 8-ohms
4x 800W (SE) and 2x 1500W (BTL) @ 4-ohms
4x 800W (SE) @ 2-ohms
Voltage GainVariableVariableVariable
Input Sensitivity (selectable)+14dBu
+4dBu
-10dBV (Unbalanced RCA)
Microphone
+14dBu
+4dBu
Microphone
+14dBu
+4dBu
Microphone
Power RequirementsStandby: <1W
(1/8 power, all ch. driven): 70W
Standby: <1W
Standby: <1W
Idle Noise(A-Wt)-78dBV-78dBV-78dBV
Signal-to-Noise Ratio>106dB>106dB>106dB
Distortion (1kHz, 1dB below max output)<0.02%<0.02%<0.02%
AC Operation100V-240VAC, 50-60Hz100V-240VAC, 50-60Hz100V-240VAC, 50-60Hz
Connection TerminalsEurblock ConnectorsEurblock ConnectorsEurblock Connectors
Outdoor CapabilityIndoor Use OnlyIndoor Use OnlyIndoor Use Only
Mounting PointsSurface or Rack Mount (with included/optional accessories)Rack Mount (with included/optional accessories)Rack Mount Ears Included
FinishMatte BlackMatte BlackMatte Black
Dimensions (HWD)1.75  x 8.7  x 11.7-inches
44 x 221  x 297  mm
1.75 x 19.0 x 12.6 inches
44 x 483 x 319 mm
3.50 x 19 x 12.6 inches
89 x 483 x 320 mm
Net Weight6.5 lbs.
2.95 kg
7.7 lbs.
3.5 kg
16.8 lbs.
7.62 kg
Included AccessoriesSingle and Dual Unit Rack Mount KitRack Mount EarsRack Mount Ears
Optional AccessoriesSurface Mount KitN/AN/A
Initial Thoughts
Theory Audio offers up some of the most practical solutions for residential and commercial audio applications and the three new Amplified Loudspeaker Controllers seem to continue that tradition.
Availability and Pricing
Theory Audio Design products can be purchased and installed through Authorized US and International Representatives at the following prices:
  • The DLC-250.4d is available for $2,495/each (US MSRP)
  • The DLC-250.8 is available for $3,500/each (US MSRP)
  • The DLC-1500.4d is available for $4,750/each (US MSRP)
Related Reading
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Lots of power, bridgeable configuration options, and rack-compatible sizes add flexibility to any custom home theater setup.
In-Wall Speakers
DALI expands its architectural product line with the Phantom M80 A In-Ceiling Speaker and CI AMP-4750 4-Channel DSP Amplifier.
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
In this episode the eCoustics teams reveals its Best in Show product awards from CEDIA Expo 2024 across 17 different categories.
Part 3 of 3 from CEDIA Expo 2024 highlights Ascendo, Theory Audio, Bowers & Wilkins, L-Acoustics, TCL, JVC and Grimani Systems.
Priced from $4,800 to $9,000 each, PRO Audio Technology's versatile new line of loudspeakers can handle near sound reinforcement levels while sounding like true...
Ask an Expert
Trinnov developed a high-tech solution to the age old problem of home theater installations: uneven bass response.
Theory Audio Design has adapted its award-winning in-ceiling and subwoofer drivers for outdoor use.
