Theory Audio Design Unveils Next Generation Amplified Loudspeaker Controllers: CEDIA 2022
Theory Audio Design announces the DLC-250.4, 1000.4, and 1500.4 Amplified Loudspeaker Controllers for their CI loudspeaker lineup.
Theory Audio Design 1500.4 Pair Angle
High-end commercial and residential audio brand, Theory Audio Design has 3 new Amplified Loudspeaker Controllers to drive their expanded CI loudspeaker lineup. Paul Hales introduced the DLC-1000.4, DLC-1500.4, and DLC-250.4 at CEDIA 2022 and the prices are surprisingly lower than expected.
Overview
The DLC-1000.4 and 1500.4 are full-size rack mount units with extensive high power output and flexible setup options for large-scale setups. The DLC-250.4 has almost all the features of the 1000.4 and 1500.4 but has a more compact 1/2 rack design with less power output. The DLC-250.4 is an option for more modest installations.
Theory Audio Design 250.4 Front and Rear
Each model offers 4-channels of intelligent power, a full DSP matrix, and is TCP/IP controlled through a wired connection, or directly via its onboard Wi-Fi access point.
In addition to custom home theater setups, the DLC models offer extensive system setup flexibility for hotels,  houses of worship,  educational facilities, and corporate environments where there are multiple rooms of varying sizes.
The DLC Loudspeaker Controllers provide high-quality amplification and superior speech intelligibility throughout large spaces.
S/PDIF master/slave functionality allows multiple DLCs to be used to cover all these needs and each loudspeaker controller only takes up two rack spaces.
For home cinema and surround sound systems, the DLCs are perfect to power large screen loudspeakers and subwoofers with up to 250 Watts (DLC-250.4), 1000 watts (DLC-1000.4), and 1500 watts (DLC-1500.4) per channel into 4, 8, and 16-ohms, or 70V/100V hi-z systems.
Theory Audio Design 1500.4 Angle
Specifications
Product Description
  • 4-Channel Amplified Distribution Loudspeaker Controller
  • IP Control
  • Integrated WiFi Access Point
  • Power Sharing
  • Lo-Z and Hi-Z (70V/100V) Operation
Inputs
Outputs
  • 4 x Speaker Outputs
  • 1 x S/PDIF Digital Audio Out
  • 1 x +12VDC Trigger
Audio Operation: 48kHz/24-bit
On-Board DSP: 48kHz/32-bit
DSP Features
  • Loudspeaker Processing for all Theory Models
  • Input Trim
  • Signal Routing
  • Gain
  • Delay
  • Polarity
  • Limiter
Frequency Response: 20Hz-20kHz, +/-0.25dB
Power Output (DLC-250.4)
  • 250W per channel @ 4, 8, 16-ohms, and 70V/100V
  • 125W per channel @ 4, 8, 16-ohms all channels driven
  • 125W per channel @ 70V/100V all channels driven
Power Output (DLC-1000.4)
  • 1000W per channel @ 4, 8, 16-ohms, and 70V/100V
  • 500W per channel @ 4, 8, 16-ohms all channels driven
  • 500W per channel @ 70V/100V all channels driven
Power Output (DLC-1500.4)
  • 1500W per channel @ 4, 8, 16-ohms, and 70V/100V
  • 800W per channel @ 4, 8, 16-ohms all channels driven
  • 800W per channel @ 70V/100V all channels driven
Voltage Gain: Variable
Input Sensitivity: Variable
Signal to Noise Ratio: >106dB
Distortion (1kHz, 1dB below max output): <0.02%
Power Related Specs
  • Standby: <1W
  • 1/8 power, all channels driven: 70W (250.4),  315W (1000.4), 470 watts (1500.4)
  • Idle Noise(A-Wt): -78dBV
  • AC Operation: 100V-240VAC, 50-60Hz
Dimensions (HWD)
  • DLC-250.4: 1.75 x 8.7 x 11.7-inches
  • DLC-1004.4/1500.4: 3.5 x 19 x 12.6
Weight
  • DLC250.4: 6.2 lbs.
  • DLC-1004.4/1500.4: 16.5 lbs.
Accessories (DLC-1000.4 and 1500.4)
  • Rack Mount Ears
Accessories (DLC-250.4 only)
  • Single and Dual Unit Rack Mount Kit
  • Surface Mount Kit
Theory Audio Design 1000.4 Angle
Availability and Pricing
  • The DLC-1000.4 is available to order now for $3,500/each (US MSRP)
  • The DLC-1500.4 will begin shipping in December for $4,250/each (US MSRP).
  • The DLC-250.4 (coming soon).
Theory Audio Design products can be purchased and installed through Authorized US and International Representatives.
Theory Audio Design Unveils Ic6 In-Ceiling Loudspeakers
Theory Audio Design 5.2.2 Surround Sound System: Long Live Movies
Theory Audio Design: 6 Questions For Paul Hales
Theory Audio Design Releases Expanded Automator Software
Theory Audio Design Introduces In-Wall Loudspeaker And Two Accessories For Installation Flexibility
More New Products from CEDIA 2022
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
At only $1,995, Strato M is Kaleidescape's lowest cost movie server/player, but there is a catch.
Sony just unveiled two new entry-level Dolby Atmos-compatible soundbars for those who want to beef up their TV sound without breaking the bank.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Close To Perfect, Expanded Atmos Mix Takes Yes Surround Sound To Immersive Heights.
HDTV 4K & 8K TV
Philips has teamed up with Roku to deliver a budget priced 65-inch OLED TV (model 65OLED974/F7) that's only $1,299 at Sam's Club.
Behind the scenes, Fraunhofer makes audio products sound better and easier to use. Find out what their latest innovations bring to the table.
Priced at $234.99, the Cleer ARC 3 Gaming Edition comes with a USB-C dongle for low latency wireless gaming.
