Earbuds & In-Ear Headphones
TEAC inCore Audio ZE-1000 Hi-Definition Earphones Announced
New Sound Isolating Stereo Earphones for Quality Music Listening
TEAC America, Inc. announces the addition of TEAC inCore Audio ZE-1000, its new Hi-Definition Earphones, to its Audio Product line.
With “inCore Audio” TEAC is presenting a new set of earphones that are designed for music lovers looking for a rich and lifelike listening experience. Comfortable and stylish, inCore Audio delivers full range audio that — due to the patented 5-layer silicone ear pads — seal off ambient noise resulting in greater acoustic isolation.
Thanks to the dual hi-definition BA (Balanced Armature) drivers and the unique sound isolating in-ear design, inCore Audio earphones deliver a great listening experience with thrilling dynamics, yet characteristically “natural” with layers of musical textures and subtleties.
TEAC’s inCore is not only designed for music lovers looking to upgrade the earphones included with their iPod or MP3 player, but it’s also a perfect companion to audio fans that like to listen to their favorite CDs “on-the-go” … or on-stage.
Not only the four integrated high performance micro-speakers contribute to the inCore’s high-quality sound, the included sound isolating silicone ear pads also block ambient noise up to -30dB and assure a perfect fit and comfort. An airtight seal within the ear canals is a key to optimizing sound isolation.
From vocals to acoustic guitar to flutes to drums, the result is a more rewarding personal listening experience that can be taken anywhere, anytime. Additionally, you are no longer forced to maximize the volume, where ambient noise is high, which may save your hearing in the long run.
TEAC inCore Audio ear pads come in three sizes (S, M, L) and accommodate many different ear shapes. In addition to the sound isolating pads and modular cable, TEAC also provides a durable and compact carrying case as well as a 1/4-inch (63mm) jack for home stereo system application and an airplane adapter-plug. Being on an airplane, you will enjoy the comfort of sound isolation and noise reduction of inCore during extended wear.
Technical Data at a Glance
Model name ZE-1000
Speaker type Dual Balanced Armature Drivers (Two per ear piece)
Sensitivity 109dB SPL/mW
Impedance (1kHz) 15 ohms
Frequency response 20 Hz – 20 kHz
Cable length 47 in. / 1.2 m
Weight 0.5 ounces / 15 g
Stereo plug 1/8 in. / 3.5 mm
About TEAC America, Inc.
TEAC America, Inc., the largest subsidiary of the Japanese electronics maker TEAC, distributes high grade audio video electronics, consumer electronics, computer data recording and storage devices, computer peripherals and professional recording equipment as well as disc publishing and duplication products. Products are marketed by TEAC America under the brand names ESOTERIC, TEAC and TASCAM. TEAC America, Inc., was established in 1967.
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
