Tannoy Relaunches Super Gold Monitor Series Speakers
Experience the accurate sounds of Tannoy’s Super Gold Monitor (SGM) loudspeakers series originally used by mastering engineers in the 80s.
Tannoy SGM 10, 12, 15 Loudspeakers
In conjunction with their announcement of the Stirling III LZ Special Edition, Tannoy is also offering up a new speaker line, the Super Gold Monitor Series. This series consists of three sizes: 10, 12, and 15 inches, and offers a classic vintage look with the same core features designed to deliver great sound in a variety of settings, from the recording studio to the living room.
Tannoy’s Monitor Gold loudspeakers were originally launched in the 1980’s, and were used by high-profile recording studios when mixing and/or mastering some of the most iconic albums and soundtracks in history. Artists like Michael Jackson, Elton John, The Eagles, Billy Idol, Depeche Mode, Christina Aguilera, and soundtracks for films like Top Gun, Breakfast Club and Catch Me if You Can had Tannoy speakers as the final link in the signal chain in the studio.
The Super Gold monitor speakers are the perfect companion when listening to music with fast transients and plenty of attack, such as Funk, EDM, Jazz, and World Music. This is accomplished through several features.
Construction: The Super Gold Monitor speakers incorporate 19 mm (3/4″) Particle Board, MDF with plywood internal bracing. The bracing uses DMT (Differential Materials Technology) to couple driver to cabinet
Tannoy Dual Concentric Precision Driver
Dual Concentric Drivers: Tannoy invented the dual concentric speaker in 1947, and it has been refined and improved continuously over the decades. The Super Gold incorporates the latest improvements.
In a Dual Concentric design, the woofer and tweeter are merged; with the main benefit being the coherency of the sound coming from a single point. Since sound is coming from the same point, it supports point-source imaging, adding to a spherical wavefront that ensures even dispersion both vertically and horizontally. This provides a wide sweet spot that doesn’t require that the listener sit dead center to experience great music listening with an accurate soundstage.
The dual concentric drivers incorporate ferrite with copper demodulation rings in combination with a high flux magnetic circuit, which performs better than the original 1970s Alnico-designed concentric drivers.
Bass Reflex: To support sound quality further, the Super Gold Monitor speaker enclosure also includes front-mounted ports. The 10 and 12-inch models include two ports, and the 15-inch model provides 3 ports. Mounting the ports on the front allows near-wall or soffit placement, supporting optimal low-frequency performance.
Tannoy Super Gold Monitor Adjustments
Level and Crossover Control: The Super Gold Monitors provide an easy-to-use front panel two-way energy control system. This allows users to adjust the high-frequency output level and crossover slope to fine sound reproduction to the room environment or listener preference.
Connections: The Super Gold include heavy-duty 24-carat multi-layer gold-plated speaker connection binding posts for optimum signal transmission and integrity. The connections are Bi-Wire compatible.
Tannoy Super Gold Monitor Speaker Line Comparison
Tannoy Super Gold Monitor Speaker Range - SGM 10, SMG 12, SMG 15 Loudspeakers
SGM 10SGM 12 SGM 15
MSRP$5,998$7,998$11,998
System2-Way Standmount2-Way Floorstanding2-Way Floorstandng
Enclosure TypeDual Port/Bass ReflexDual Port/Bass ReflexTriple Port/Bass Reflex
Low-Frequency Driver 1 x 10″ (254 mm) paper pulp cone with twin roll impregnated fabric surround,
52 mm (2″) edge wound voice coil
1 x 12″ (300 mm) paper pulp cone with twin roll impregnated fabric surround,
1 x 15″ (380 mm) paper pulp cone with twin roll impregnated fabric surround,
High-Frequency Driver1 x 1.3″ (33 mm) aluminum/magnesium alloy dome with edge-wound voice coil1 x 1.3″ (33 mm) aluminum/magnesium alloy dome with edge-wound voice coil1 x 1.3″ (33 mm) aluminum/magnesium alloy dome with edge-wound voice coil
Frequency Response (± 6 dB)40 Hz – 30 kHz38 Hz – 30 kHz35 Hz – 30 kHz
Recommended Amplifier Power20 – 200 W20 – 250 W20 – 300 W
Power handling (IEC)100 W continuous
400 W peak
125 W continuous
500 W peak
150 W continuous
600 W peak
Sensitivity (1 W @ 1 m)89 dB 91 dB93 dB
Impedance8 Ω8 Ω8 Ω
Crossover Frequency1.2 kHz1.2 kHz1.1 kHz
Adjustments±3 dB over 1 kHz to 30 kHz shelving,
±3 dB over 1 kHz to 5 kHz shelving,
2 dB to -6 dB per octave over 5 kHz to 30 kHz slope
Connectors 5 x 4 mm 24ct Tannoy customized binding posts, Bi-wire compatible5 x 4 mm 24ct Tannoy customized binding posts, Bi-wire compatible5 x 4 mm 24ct Tannoy customized binding posts, Bi-wire compatible
FinishWalnut veneer and high acoustic transparency nylon grill coverWalnut veneer and high acoustic transparency nylon grill coverWalnut veneer and high acoustic transparency nylon grill cover
Dimensions (HWD)350.5 x 309 x 523.2 mm
(13.8 x 12.2 x 20.6″)
447 x 308 x 863.3 mm
(17.6 x 12.1 x 40″)
650.2 x 424.9 x 1033.5 mm
(25.6 x 16.7 x 40.7″)
Weight18.5 kg (40.8 lbs)29.4 kg (64.8 lbs)50 kg (110.2 lbs)
Tannoy SGM 15 Loudspeaker Lifestyle
Included Accessories
  • Accessory pack (included)
  • Bi-wire bridge connectors
  • Tannoy High-End Loudspeaker Wood Wax
  • Rubber feet
Pricing & Availability
Tannoy Super Gold Monitor (SGM) Speakers are available through Tannoy and authorized dealers and distributors at the following prices (per pair).
  • SGM 10: $5,998 (£5,995/€5,998)
  • SGM 12: $7,998 (£8,249/€7,998)
  • SGM 15: $11,998 (£11,495/€11,998)
ATC SCM20ASL Active Bookshelf Speaker in High Gloss Cherry Finish
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Earbuds & In-Ear Headphones
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Sony 2025 BRAVIA family of products Sony 2025 BRAVIA family of products
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Chord's new Suzi Pre preamplifier and Suzi power amplifier are scheduled for release Fall 2024.
With improved drivers and the addition of an active crossover option, the Klipschorn AK7 and La Scala AL6 are ready to take on all...
The Arendal Sound 1961 loudspeaker line is not ready to be retired. Check out all 6 speakers and 2 subwoofers priced under $2000/pair.
Focal extends its wired headphone range with two affordable models based on the Bathys architecture in open and closed-back configurations.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
The 300 series implements some of the technologies used in the flagship Corinium speakers at a more affordable price point
The Bowers & Wilkins 703 S3 is the least expensive floorstanding loudspeaker with a tweeter-on-top design in the 700 series.
In-depth review compares the Q Acoustics 5050 floorstanding loudspeakers ($1,999/pair) with three different amplifiers to reveal what makes them sing.
