Camera Lenses
Tamron A005 70-300mm F/4-5.6 Telephoto Zoom Lens
An Extra Low Dispersion (XLD) lens made from high-grade materials delivers best in class resolution. Tamron's own Ultrasonic Silent Drive (USD) and Vibration Compensation (VC) make the lens fast, quiet and easy to use.
Tamron just released its anniversary model 70-300mm F/4-5.6 telephoto zoom lens featuring VC (Vibration Compensation) image stabilization and an ultrasonic auto-focus drive — USD (Ultrasonic Silent Drive). The SP 70-300mm F4-5.6 Di VC USD (Model A005) high-resolution DSLR telephoto zoom lens is available for the Nikon mount, with the development of compatible mounts for Canon and Sony to follow.
This new lens is designed for digital SLR cameras, and it can be used with both full-frame sensor and AF 35mm cameras with a zoom range of 70-300mm; or with APS-C sensor cameras where the angle of view will change the zoom range equal to 109-465mm.
With superior optical performance, Tamron's own USD (Ultrasonic Silent Drive) and VC (Vibration Compensation), the SP 70-300mm F4-5.6 Di VC USD (Model A005) provides the performance of a high-end premium telephoto zoom that is appealing to a broad spectrum of photography enthusiasts.
Unparalleled optical performance in a fast and steady telephoto zoom lens
In the pursuit to achieve the most outstanding image resolution in the 70-300mm class, Tamron's 60th Anniversary lens – the SP AF70-300mm F4-5.6 Di VC USD (Model A005) – utilizes an advanced optical design that features an LD (Low Dispersion) and an XLD (Extra Low Dispersion) lens element made from specialized materials that prevent chromatic aberration. As a result, the SP AF70-300mm Di VC USD boasts sharper contrast and greater descriptive performance than all others in its class.
In addition, it is the first Tamron lens sporting a USD (Ultrasonic Silent Drive), Tamron's very own ultrasonic auto-focus drive mechanism. This USD mechanism delivers fast focusing, making it a perfect telephoto zoom choice for photographing sports, racing, and other fast-moving subjects. The lens also boasts Tamron's proprietary VC (Vibration Compensation) image stabilization to assist in hand-held shooting, not only at long focal length ranges where blurring is common, but also under low-lit conditions, dramatically enhancing photographic freedom.
This combination of best in class image resolution, Ultrasonic Silent Drive and Vibration Compensation is a new achievement of Tamron technology, culminating in the production of a premium 70-300mm telephoto zoom lens.
See product brochure (pdf) for more info. MSRP is $449.
Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
Networking
