Tailored HD Cinema Display Extension Solutions from Gefen Cater to Mac Users
WOODLAND HILLS, CA — September 16, 2004 — Connectivity solutions provider Gefen today announced the availability of new Apple HD Cinema Display Extension Kits. Distances ranging from 10 to 300 feet are bridged by multiple cables that sustain high definition resolutions up to 1920×1200.
The kits are tailored to fit pre-set distance specifications, and contain the appropriate extension device, depending on the length desired, plus the cabling needed to relocate a 20 or 23 inch Apple HD Cinema Display, keyboard/mouse, plus a Firewire peripheral away from the computer.
Extension devices include a DVI Repeater, a small device that sits between two DVI cables regenerating the video signal from one through the other, or a DVI-1000 HD Extender, which uses a sender and receiver connected by cabling to extend the display. In some cases, a cable-only solution is used, depending on the length desired.
Kits are currently available for the following lengths: 10, 15, 25, 30, 40, 50, 60, 100, 160 and 300 feet. Two of the kits, the 30 and 60 foot, are available in an alternate version that uses less than one inch wide cabling in conduit.
Specific kit contents and wiring diagrams are available online at www.gefen.com. Prices range from $217 to $4065. For Apple’s line of ADC flat panel digital displays, Gefen provides a variety of ADC Extender Kits, also available online. Gefen’s solutions may be purchased direct or through a Gefen reseller, located around the world and also listed online.
About Gefen Inc:
Gefen provides computer and electronics connectivity solutions through its ex-tend-it Professional Series, which offers multi-platform extension, switching, distribution and conversion technologies. Gefen is currently pioneering a full line of HDTV products that enable high definition digital video to be split, switched and extended. A selection of SDI, HDMI, fiber optics, DVI and CAT5 cabling is
available through Gefen as well as audio, USB, CAT5, PS/2, RS232 and similar peripheral support solutions. Detailed product information may be found at www.gefen.com.
Stratton Acoustics Element 6 (Left) and Element 8 (Right) Loudspeakers
Networking
Earbuds & In-Ear Headphones
