TAD Labs Introduces the Evolution Series TAD-GE1 Speaker System
The TAD-GE1 (Grand Evolution One) floorstanding loudspeakers are one step below the company’s flagship for less than half the price.
TAD-GE1 Loudspeakers
Having just reviewed the superlative TAD Labs CE1TX earlier this month, we were curious if the Japanese manufacturer planned on offering something similar in a floorstanding model for less than the price of a German SUV.
eCoustics Sr. Editor, William Jennings, is smiling right now somewhere in Tennessee; primary because he’s getting one of the first samples of this loudspeaker in November after Capital Audio Fest to review.
The $65,000 USD price tag might dampen his enthusiasm somewhat. Someone hide the children. And his enormous headphone collection.
Technical Audio Devices Laboratories, Inc. (TAD Labs, TADL) have announced the TAD-GE1 (Grand Evolution One) speaker system as the newest addition to its Evolution Series of hi-fi audio components.
Borrowing internal technology and design language from TAD’s top-of-the-line Reference TX Series as well as the distinguished wood-grain finish of the critically acclaimed CE1TX standmount speaker, the GE1 epitomizes the very best of TAD.
“When we set out to design the GE1, we were aiming for a model that could sit between CE1TX and the Reference One TX in both performance and price,” said Shinji Tarutani, CEO of TAD Labs.
Main Features
CST Driver
The TAD-GE1 boasts TAD’s proprietary CST Driver, which controls the directivity of the concentrically mounted midrange and tweeter over an extended frequency range from the point of matching phase. This culminates in clear and solid imaging, as well as natural sound field reproduction.
The midrange cone controls the directional characteristic of the concentrically mounted tweeter to bring the phase and directivity of their output in line in the crossover region.
The result is ultra-wide-range reproduction from 250 Hz up to 10 kHz by the CST Driver alone, while achieving a natural attenuation characteristic and directivity pattern across all bands.
Beryllium Diaphragm
The TAD-GE1 uses a light yet rigid beryllium diaphragm for its tweeter, manufactured with TAD’s proprietary vapor deposition technique. TAD’s computer-analyzed optimization technique called Harmonized Synthetic Diaphragm Optimum Method (HSDOM) has been applied in designing the form of the diaphragm.
This technique enables precise control of the diaphragm’s divided vibrations and piston motions, which makes the ultra-wide-range reproduction of up to 100 kHz possible.
Magnesium Diaphragm
The midrange’s diaphragm is made of magnesium, which is one of the lightest metals and has a high internal loss—ideal characteristics for materials to be used for diaphragms.
The application of hybrid chemical conversion coating and painting to the surface gives it additional hardness and a yet greater internal loss.
The result is clearer, distortion-free midrange reproduction unaffected by unwanted resonance. In addition, resonance in the mid-to-high frequencies generated by interactions between the suspension and diaphragm is effectively controlled to achieve an even lower distortion and a greater transient response.
MACS II Diaphragm (Multi-layered Aramid Composite Shell Second Generation)
A refined woofer diaphragm made of five layers of woven and non-woven aramid fabric optimizes the physical property of the shell-shaped diaphragm that integrates the center cap and cone into a single piece.
The result is a richer and clearer bass and the smooth, coloration-free reproduction in the mid-to-low frequency range.
SILENT Enclosure
The TAD-GE1 comes in a SILENT enclosure, which combines sturdy birch-plywood braces with medium-density fiberboard (MDF) panels having a high internal loss to provide superb strength and an outstanding vibration-dampening characteristic.
Moreover, the combination of acoustic tubes placed inside the enclosure as part of TAD’s ingenuous Acoustic-Filter-Assisted System Tuning (AFAST), which reduces the low-order standing-wave mode, and acoustic absorbent carefully chosen and placed inside effectively suppresses standing waves that would adversely affect the sound field and imaging performance of the speaker.
TAD-R1TX Reference One TX Loudspeakers
TAD-R1TX Reference One TX Loudspeakers ($160,000/pair)
ISO Drive Technology
The ISO (isolation) Drive Technology, originally incorporated into the top-of-the-line TAD-R1TX speaker system and tweaked for the TAD-GE1, was applied to the way the CST Driver was mounted to the enclosure.
With this technology, the CST Driver is acoustically and mechanically isolated from the enclosure by a mount base and damper bushes.
This is designed to keep vibration generated by the CST Driver from traveling to the enclosure. As a result, the driver performs as it should, reproducing waveforms accurately and delivering crystal-clear sound.
The sturdy base to which the CST Driver is mounted to the enclosure was machined from a 25 mm thick solid aluminum plate and is shaped in such a way to offset the slant of the baffle and orient the CST Driver directly toward the listener.
Bidirectional ADP System
The Bidirectional ADP (Aero-Dynamic Port) System positions a port on the bottom of the enclosure with its openings to the front and rear of the enclosure. The port has a horn-shaped interior that reduces port noise and achieves greater efficiency in driving the port to help reproduce clear and responsive sound in the mid-to-low frequency range.
The combination of the port flare made of die-cast aluminum and the symmetrical front-back layout of the port effectively offsets the physical force that vibrates the enclosure and, as a result, helps reproduce a powerful bass.
Moreover, the 15 mm-thick aluminum base plate attached to the bottom of the enclosure increases the stability of the speaker system when placed on the floor and counterbalances the reaction caused by the powerful driving force of the twin woofers.
“The GE1 delivers the sound field and imaging performance comparable to that of the Reference Series speaker systems,” said Dave Malekpour, president of PAD HiFi, TAD’s US distributor. “It’s an impressive speaker and we can’t wait to debut it at Capital Audio Fest in November.”
Specifications
Type 3-way, bass-reflex floor-standing speaker system
Woofer 18 cm cone x 2
Midrange and tweeter Coaxial 14 cm cone and 3.5 cm dome
Frequency response 27 Hz to 100 kHz
Crossover frequencies 250 Hz and 1.8 kHz
Sensitivity 88 dB (2.83 V at 1 m)
Maximum input 250 W
Nominal impedance 4 ohms
Unit polarity Bass: +; midrange: +; high: +
Dimensions
(WxHxD)
15.5″ x 47.7″ x 21.5″
(394 mm x 1212 mm x 547 mm) (without spikes)
Weight 141 lbs (64 kg)
Accessories2 Woofer grilles, 2 short cables, 3 cone-shaped spikes, 2 auxiliary feet, 3 spike holders, cleaning cloth, owner’s manual
Price & Availability
The TAD-GE1 will be available for purchase through select dealers starting November 2023. The MSRP for the pair is $65,000 USD.
For more information: technicalaudiodevices.com
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Our favorite audio accessories can make your turntable, speakers or headphones sound even better.
Loudspeakers
Bang & Olufsen bets big on Union Square’s comeback, opening its largest store in a San Francisco still digging out from years of crime...
Our favorite projectors of 2025 offer the best picture quality and value at their price across UST, lifestyle and standard throw models.
From $6,000, the Pro-Ject Classic Reference turntable combines a vintage look with high-end construction and performance for audiophiles.
NBC Universal's flagship streaming service is promising live football broadcasts in 4K/HDR with Dolby Atmos surround sound, but will it work on your gear?
The Tivoli SongBook MAX is retro, loud, and weirdly addictive. Mid-century design meets Miami volume—your neighbors may never forgive you.
Looking for the best bookshelf or stand-mounted speakers below $1,000? We've awarded 10 loudspeakers that have impressed us enormously.
Bang & Olufsen is offering 10 pairs each of its flagship loudspeaker, the Beolab 90, in two new finishes for those with absolutely zero...
