Florida International Audio Expo 2023: TAD CE1TX Loudspeaker
Discover why TAD’s $35,000 (with stands) TAD-CE1TX stand-mounted loudspeakers are so expensive.
TAD CE1TX Stand-mount Loudspeaker Pair
The Florida International Audio Expo is underway and there have been a number of interesting new product introductions including new electronics and loudspeakers from Focal/Naim and Orchard Audio. In addition, Japan-based TAD (Technical Audio Devices) has also made its way to the Florida Show with the North American debut of its New Evolution Series TAD-CE1TX Standmount Speaker
The TAD-CE1TX
TAD CE1TX Loudspeakers Lifestyle
TAD has preserved key elements of its previous Compact Evolution CE1 speaker while making upgrades to the woofer and midrange units and other subtle refinements that contribute to improved performance.
Key Features
CST (Coherent Source Transducer) Driver: This controls the directivity of the midrange and tweeter, delivering ultra-wide-range reproduction from 250Hz up to 100kHz with transparent and solid imaging.
CE1TX Tweeter: Borrowing from TAD’s Reference TX Series, the tweeter used in the CE1TX incorporates a light, rigid beryllium diaphragm manufactured with TAD’s proprietary vapor deposition technique. TAD’s computer-analyzed optimization technique Harmonized Synthetic Diaphragm Optimum Method (HSDOM) was applied in designing the form of the diaphragm.
As a result, TAD claims that the tweeter provides precise control of its divided vibrations and piston motions, supporting ultra-wide-range reproduction of up to 100 kHz.
TAD CE1TX mid-to-high driver
Midrange: The midrange features a newly developed magnesium diaphragm that results in high internal loss, meaning clear, distortion-free midrange reproduction.
TAD CE1TX mid-to-low Driver
TMACS II Woofer Diaphragm: This Second Generation Multi-layered Aramid Composite Shell is made from five layers of woven and non-woven aramid fabric. TAD claims that this results in a diaphragm that supports richer, clearer bass as well as coloration-free sound in the mid-to-low frequency range.
TAD CE1TX Loudspeaker Enclosure
Bidirectional Aerodynamic Slot (ADS) Port: CE1TX uses slit-shaped ports (ducts) in both side panels with flared openings to the front and rear to allow air to flow smoothly through them. This layout eliminates unwanted port noise to deliver rich and natural bass that can fill even the largest of rooms.
SILENT (Structurally Inert Laminated Enclosure Technology): The CE1TX enclosure combines strength and optimized vibration dampening. The enclosure has also been updated with a mirrored finish to accentuate the wood’s natural grain.
TAD Logo
Specifications
  • Model: TAD-CE1TX-WN
  • Speaker Type: 3-way, bass-reflex bookshelf/stand-mounted speaker system
  • Woofer: 18cm (7 1/16 in.) cone
  • Midrange/Tweeter Coaxial:
    • 14 cm (5 1/2 in.) magnesium cone
    • 3.5 cm (1 3/8 in.) beryllium dome
  • Frequency Response: 34Hz to 100kHz
  • Crossover Frequencies: 250 Hz and 1.8 kHz
  • Maximum input (power handling): 200W
  • Sensitivity: 85dB (2.83V, 1m)
  • Nominal Impedance: 4Ω
  • Weight: 29kg (63.9 lb) per unit
  • Dimensions (WHD): 287 × 510 × 447 mm  (11 5/16 x 20 1/16 x 17 5/8 inches)
TAD CE1TX Stand-mount Loudspeaker Pair Closeup
Included Accessories
  • Woofer grilles
  • Short cables (2)
  • Non-slip pads (4)
  • Cleaning cloth
  • Owner’s manual
TAD-ST2TX-K Optional Stands
  • Weight (per unit): 18.5 kg (40.8 lb)
  • Dimensions (WHD per unit with no spikes attached):
    • 399 x 591  x 485 mm
    • (15 11/16 x 23 1/4 x 19 15/16 inches)
  • Only sold in pairs
Included Stand Accessories (per pair)
  • Cone-shaped spikes (6)
  • Auxiliary feet (4)
  • Spike Holders (6)
  • Cork Sheets (6)
  • Assembly Screws (16)
  • Screws for securing the bottom of the speaker to the strut  (4)
  • Owner’s Manual
TAD CE1TX Loudspeaker Pair Front
Pricing & Availability
  • The TAD-ST2TX Stands (Pr): $2,500.
Pre-ordering is available through PAD (Pro Audio Design) HiFi and select specialty retailers
Related Reading
3 Comments
3 Comments
  1. Dan
    February 20, 2023 at 7:08 pm
    I red the post and couldn’t discover why this loudspeaker is so expensive. In which part of this post are you explaining it??
    • Ian White
      February 20, 2023 at 7:47 pm
      Dan,
      1. R&D costs
      2. Driver costs
      3. Cabinet
      4. Crossover
      Loudspeakers have a huge markup at this level — 50% of the retail price is what TAD charges the dealer for the pair. Assuming there isn’t a distributor and they sell it to dealers directly.
      Some manufacturers charge at least 5-7 times their costs to manufacture before the dealer price is figured into the final amount.
      Best,
      Ian White
  2. GM
    March 27, 2023 at 9:30 pm
    Far beyond my means, but I’ve long been intrigued by this model, ever moreso this new improved version.
Emotiva Nostala LB12 Loudspeakers Pair no grilles
Emotiva’s Nostala LB12 brings vintage style and modern engineering at $2,999/pair, offering strong performance in a crowded heritage speaker market.
Topping E50 II DAC on Desktop Topping E50 II DAC on Desktop
TOPPING’s new E50 II DAC packs AK4497S decoding, LDAC Bluetooth, ADAT support, PEQ, and strong I/O for $199, making it a flexible hub for...
ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands ELAC NAVA100 Adsum Portable Bluetooth Speaker in White in hands
ELAC enters the portable Bluetooth market with the NAVA100 ($229), a premium metal-built speaker with serious audio engineering, solid battery life, and a few...
AZLA TRINITY Earphones USB-C Version AZLA TRINITY Earphones USB-C Version
AZLA expands its lineup with TRINITY wired earphones and new MAX and XELASTEC 2 eartips, offering better fit, comfort, and value for Galaxy Buds...
WiiM Sound Lite Smart Speaker in white WiiM Sound Lite Smart Speaker in white
WiiM's original smart speaker sheds features to hit a lower price point ($229) for those who can live without a touch display and voice...
Final UX1000 and UX5000 Wireless Headphones Final UX1000 and UX5000 Wireless Headphones
Final's UX1000 budget wireless ANC headphones are only $65, while the step-up UX5000 add aptX Adaptive and LDAC for $250.
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
Polk Audio have been quite aggressive with their Reserve and Legend Series speakers, and news has dropped on a brand new lineup called the...
Celebrating 40 years, Acoustic Energy’s AE1 Anniversary Edition updates the iconic compact loudspeaker with modern drivers and refined engineering.
Perlisten A-Series loudspeakers are designed for stereo or home theater. Choose between two towers, a stand-mount and on-wall surround.
We put MartinLogan's least expensive speaker to the test to see if it can capture the magic of the company's far more expensive models.
DALI KUPID delivers compact, high-performance Hi-Fi sound with custom drivers, dual-flare bass, and broad amp compatibility under $750.
Estelon unveils the AURELLE stand-mount and Centre speaker, and AURUS subwoofer at High End Munich 2025, celebrating its 15th anniversary. Prices start at €7,500...
OePhi Lounge Series Loudspeakers aim to prove high levels of musical performance don't have to cost a fortune.
Full range sound from bookshelf speakers? Check out the new Radiant Acoustics CLARITY 6.2 and 4.2 loudspeakers featuring PURIFI USHINDI woofers and custom AMT...
