TAD Labs Introduces the Evolution Series TAD-C1000 Preamplifier
The TAD-C1000 Preamplifier is a stereo masterpiece that shares design language with the critically acclaimed Evolution Series.
TAD-C1000 Preamplifier Silver Front
TAD Labs is better known for its award-winning loudspeakers that are used in some of the most respected studios in the world and that includes the TAD CE1TX Loudspeakers that we just reviewed.
When it comes to its components, the iconic Japanese brand has more of a following overseas where the products have wider distribution. All of that appears to be changing with the new Evolution Series which is now available in North America.
Technical Audio Devices Laboratories (TADL) has announced the TAD-C1000 preamplifier, the newest addition to its Evolution Series of hi-fi audio components.
Sharing design language with existing Evolution Series components including the TAD-D1000TX disc player, TAD-DA1000TX DAC, and TAD-M1000 power amplifier, the TAD-C1000 masterfully amplifies signals from any source component without compromising accuracy and purity in signal processing, transmission, and output amplification.
Preamp Circuit
TAD Labs has developed a preamplifier version of a single-stage, current-feedback amplifier originally developed for the M700 power amplifier and other TAD hi-fi components and incorporated it into the flat amplifier section of the C1000.
To achieve the highest level of complementarity of signals, TAD has tested the performance characteristics of each FET device and chosen matching pairs for positive and negative elements for the C1000. This attention to detail has taken the stability of the preamplification circuit to a high level.
TAD-C1000 Preamplifier Front in Black
Center-mounted, ball-bearing-supported volume knob
The volume knob has an exquisite look and feel. It is mounted on high-precision ball bearings to ensure an exceptionally smooth rotation. Its center-mounted design signifies the symmetrical layout of the internal circuits in the tradition of Evolution Series of hi-fi components.
Perfectly symmetrical circuit layout
To suppress even the smallest amplification errors of positive and negative signals, as well as between right and left channels, the audio circuit patterns and parts are symmetrically laid out on the bottom chassis. The pursuit of perfectly symmetrical design does not stop there. TAD has even gone as far as to lay out two power transformers, the chassis construction, and rear-panel jacks symmetrically to achieve optimum weight and vibration balances. With these elaborate symmetrical designs, signals that go through the C1000 are amplified in a unified electrical and mechanical environment, which contributes to a sound with a greater stereophonic impact.
TAD-C1000 Preamplifier Back
Intricate vibration-control design
The heavy, sturdy body of the C1000 is supported by the signature spike-shaped feet of the Evolution Series. The minimum contact with the surface on which the C1000 sits keeps external vibrations from travelling through the feet and eliminates any adverse effect on circuits and parts inside the case. Furthermore, two power transformers are each mounted on a 6-mm thick brass base that dampens transformer-induced vibrations.
High-purity power circuit
To increase the purity of power supply, the internal coil of the transformer is directly connected to the power supply circuit, minimizing the contact points with lead wires. Moreover, terminals for directly connected coils, mounting terminals for motherboards, and clamping screws are all made of oxygen-free copper coated with nonmagnetic materials to eliminate even the slightest magnetic distortions.
The audio and control circuits are each powered by a dedicated large toroidal transformer. The one for the audio circuit has independent internal coils for right and left channels. This ingenious grounding system ensures perfect symmetry between positive and negative signal levels and between right and left channels.
Custom Parts
TAD’s custom-made electronic volume control circuit boasts ladder-resistance switching that achieves exceptionally precise attenuation performance and an ultra-low distortion of less than 0.0005% at 1 Vrms input. In addition, the power circuit employs TAD’s custom-made electrolytic smoothing capacitors, as well as large-capacity, ultra-low distortion film coupling capacitors to achieve a wider low cut-off frequency range.
Remote Control for TAD-C1000 Preamplifier
Price & Availability
The TAD-C1000 will be available in October 2023 for $24,950 USD at select specialty retailers.
Specifications
  • Input jacks:
    • 4 balanced
    • 2 unbalanced
  • Output jacks:
    • 2 balanced
    • 2 unbalanced
  • Rated output voltage:
    • 1.6 V (balanced)
    • 0.8 V (unbalanced)
  • Maximum output voltage:
    • 14 Vrms (balanced)
    • 7 Vrms (unbalanced)
  • Signal-to-noise ratio: 120 dB
  • Frequency response: From 10 Hz to 100 kHz at -1 dB
  • Power requirements:
    • AC 120 V, 60 Hz (USA);
    • AC 220 V to 240 V, 50 Hz /60 Hz (Europe, Asia)
  • Power consumption: 26 W (0.5 W or less during standby)
  • Dimensions:
    • 440 mm (W) x 150 mm (H) x 406 mm (D)
    • 17-5/16 in. (W) x 5-14/16 in. (H) x 16 in. (D)
  • Weight: 17.0 kg (37.4 lbs)
For more information: technicalaudiodevices.com/evolution/
Related Podcast: Cost-no-object Gryphon Audio’s #1 Dealer, Joseph Cali at T.H.E. Show 2023
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
Goldmund Theia and Rhea Passive Loudspeakers Goldmund Theia and Rhea Passive Loudspeakers
Audio Cables
At $18,000 per pair, the TAD ME1TX feature an upgraded CST Driver and other refinements.
At $1,999, the Technics HA-507 is a pure analog headphone amplifier and preamplifier with a balanced/dual mono configuration.
For $25K, TAD's Evolution Series 250-watt per channel stereo power amplifier promises even greater purity, responsiveness, and accuracy.
Loudspeakers
Our hi-fi show coverage of T.H.E. Show SoCal 2024 includes stereo systems ranging from a few hundred dollars to over $500K.
At $50K, the Momentum C4 preamplifier gets a new remote and works seamlessly with optional digital streaming module for another $10K.
At $68,500 the TAD-C700 Reference Series Preamplifier includes a 400 VA power supply with a toroidal transformer.
With fully balanced and improved circuitry throughout, the BAT VK-85 Preamp and REX 300 Amp claim pure musicality from a $27,500 combo.
At $9,000 each, McIntosh offers audiophiles a choice of either solid state or vacuum tube preamplifiers.
