TA E-Series Music Receiver
T+A introduced the all-in-one high-end DAC, preamp, amplifier, CD player and networked music streamer with its new E-Series Music Receiver. It combines classic analogue technology with the very latest digital circuitry and forms the universal command centre of a modern, truly high-quality stereo system.
At the very heart of the MUSIC RECEIVER is a refined 32-bit duel-mono digital to analogue converter, which makes the very most of any digital music content that is stored on a network, a computer or CD via the front-loading CD mechanism. To make the most of other sources, five digital inputs (three x coax and two x optical) are supplied, with the coax inputs capable of 24-bit / 192 kHz processing for the highest quality. USB media storage devices and iDevice products (including control and charging) can also be connected directly to the rear via the two x 2.0 USB sockets. Making the most of the digital circuitry, a high-quality RDS FM tuner is also included.
The MUSIC RECEIVER features T+A’s latest innovative Streaming Client board, which allows for either wired or wireless access to network music servers and Internet radio. Compatible with all DNLA-compatible servers (UPnP 1.1, UPnP AV and Microsoft Windows Media Connect Servers), Internet radio can be easily set up using the vTuner internet radio service, which allows users to set up their radio playlists and favourites via the internet.
The MUSIC RECEIVER is not just a digital hub though. To make the most of ALL likely sources, the MUSIC RECEIVER features a high-end analogue pre-amplifier with three sets of analogue inputs (one in the form of a Tape In / Out), a pre-amplifier output for connecting to active speakers or additional power amplifiers, two sub-woofer outputs and one line-level output. Other useful functions include balance and tone controls, loudness, flat function and a sub-sonic filter for easy set up with sub/satellite speaker systems.
T+A Music Receiver - Back
Enabling the MUSIC RECEIVER to drive even large and demanding speakers effortlessly and to the highest standards of quality, T+A have implemented its PWM (Pulse Width Modulation) output stage, which eliminates any problems caused by voltage fluctuations in the mains power supply, and thereby excludes the possibility of signal distortion induced by the power supply voltage. When linked to T+A’s in-house developed switch mode circuits (using the very latest ultra-fast MOSFET transistors and high-energy intelligent driver modules) and the high-power toroidal transformer, the MUSIC RECEIVER is capable of nearly 100 Watts nominal output per channel into 8 Ohms.
To heighten the MUSIC RECEIVER’s audiophile credentials, the above electronics are all mounted in solid metal casework. Heavy-duty pressure-cast side panels are precision designed to couple to the aluminium front panel and cover, which wrap around the solid steel chassis for the very best isolation from unwanted external vibrations.
Price and Availability
The MUSIC RECEIVER from T+A is available now in the UK for £2,690 in either silver case with black side panels, black case with silver side panels, total silver or total black.
Specifications
Nominal output per channel 2 x 160 Watt into 4 Ohm, 2 x 94 Watt into 8 Ohm
Peak output 2 x 220 Watt into 4 Ohm, 2 x 150 Watt into 8 Ohm
Frequency response ±3dB: 1 Hz – 60 kHz
Total harmonic distortion < 0.01%
Intermodulation < 0.01%
Channel separations > 80 dB
Analogue inputs 3 x high-level 250 mV – 2.5 V / 20 kOhm
Digital inputs SP/DIF (16-24 bit): 3 x coax (192 kHz), 2 x TOS-Link (96 kHz), 2x USB for iPod and Hard disk
Analogue outputs Pre-amplifier output, Line Out, Tape Out (Stereo 2.5 V eff / 22 Ohm), Headphone > 50 Ohm
Digital outputs 1x coax, IEC 60958 (CDDA/LPCM)
CD-Player CD/DA, CD-R, CD Text
Streaming Client formats MP3, WMA, AAC, OGG-Vorbis, FLAC (96/24 via LAN), WAV (96/24 via LAN)
Playlists PLS, M3U, ASX (if supported by server)
Supported Media servers UPnP 1.1, UPnP AV, Microsoft Windows Media Connect Server (MS DRM10), vTuner Internet Radio Service, DLNA compatible servers
Standards Features DLNA, UPnP, MS-DRM10, Designed to play Plays for sure guidelines Web server (remote PC Web browser control), vTuner. Internet Radio Station database (automatic updates over Internet)
Interfaces USB 2.0 for Hard disk, iPod with control system and display, LAN, W- LAN, RS 232 Update and control interface
Radio FM Radio 87.5 – 108 MHz, overload damping >40 dB, RDS functions, station lists, station memory (presets)
D/A converter 32-bit, 384 kHz Sigma Delta, 8-times oversampling, double-mono Phase-linear 3rd order Bessel filter, 100 kHz
Analogue filter Phase-linear 3rd order Bessel filter, 100 kHz
Frequency response 2 Hz – 20 kHz 44.1 kHz
2 Hz – 22 kHz 48.0 kHz
2 Hz – 40 kHz 96.0 kHz
2 Hz – 80 kHz 196.0 kHz
Total harmonic distortion < 0.001%
Signal to noise ratio 109 dB
Channel separation 106 dB
Dimensions H x W x D 12 x 44 x 39 cm (4.7 x 17.6 x 15.6 inch)
Weight 10kg (22lbs)
Finishes Black case with silver side panels
Black case with black side panels
Silver case with black side panels
Silver case with silver side panels
Accessories Incl. system remote control handset, W-LAN aerial
Control interface RS 232 for update and control system
Mains socket 100-240 V, 50/60 Hz 300 Watt
Optional accessories iPod docking station
FD 100 bi-directional radio remote control handset with screen Metal IR remote control FM 100
Hisense XR10 High-end Lifestyle 4K Laser Projector
With 6,000 ANSI lumens, a TriChroma laser engine, all-glass optics, and liquid cooling, the Hisense XR10 targets the top tier of high-end lifestyle projectors.
Pro Audio Technology SR28212ai Speakers V2 Pro Audio Technology SR28212ai Speakers V2
Pro Audio Technology rolls out V2 speaker upgrades with improved drivers, DSP tuning, and lower noise for elite home theater performance.
Displace Pro TV 2 OLED on stand Displace Pro TV 2 OLED on stand
Need to mount a TV to the wall without drilling, screws or wires? Displace TV offers two ways to do it, with an added...
LG Sound Suite Soundbar System Lifestyle LG Sound Suite Soundbar System Lifestyle
LG's Sound Suite promises flexible setup, automatic calibration and room optimization with Dolby Atmos FlexConnect.
DALI SONIK Loudspeaker Series in walnut DALI SONIK Loudspeaker Series in walnut
DALI unveils SONIK, a seven-model loudspeaker series delivering trickle-down tech from KORE and EPICON, refined design, and accessible hi-fi performance for music and home...
Cleer ARC 4 white on-ear bud Cleer ARC 4 white on-ear bud
Cleer’s ARC 4 and ARC 4+ debut as the first THX-certified open-ear wireless earbuds, refining fit, sound quality, and spatial audio ahead of CES...
Christmas 2025 gift guide for tech, hi-fi audio, headphones and home theater
