Synthesis One Array ML Premier Home Theater Speaker System
Two Powerful Brands, One Extraordinarily Powerful System
Harman has combined two of its brands — JBL Synthesis® and Mark Levinson® — to create one powerful home theater system: the Synthesis® One Array ML Premier.
This upgraded blend of the JBL Synthesis® One Array with the new Mark Levinson® 500H Series amplifiers represents one of the most dynamic systems in the industry. The Synthesis® One Array already sets new standards of technological innovation and manufacturing quality, and the groundbreaking 500H Series amps redefine acoustic detail with breathtaking realism.
This system delivers flawless sonic accuracy at any volume level, with Mark Levinson® providing the very best in amplification to power the JBL® compression drivers as well as the dome and cone speaker configurations. With customized calibration and installation, and optional JBL® Factory Calibration, this unique system offers precise, consistent sound for true theater quality witheven greater intimacy.
Retail Price: $88,100
Synthesis® One Array ML Premier Home Theater System:
Electronic Components Loudspeakers
  • 1 — SDP-40HD Surround Processor
  • 2 — No 535H Multichannel Amplifiers
  • 2 — S820 Stereo/Mono Amplifiers
  • 1 — SDEC4500 Digital Equalizer / Active Crossover
  • 1 — S4500XLRIC Interconnect Kit
  • 3 — SAM1HF High-Frequency Horn Modules
  • 3 — SAM2LF Low-Frequency Woofer Modules
  • 4 — S4Ai Multipolar In-Wall Surrounds
  • 2 — S1S-EX Passive Subwoofers
Specifications
  • THX Ultra2 certified
  • Six HDMI 1080p inputs
  • Dolby, DTS, THX and Logic7 processing
  • Fully balanced outputs
No. 535H Multichannel Amplifier
  • 5 x 200 watts @ 8 ohms all channels driven
  • Independent power supply components per channel
  • Balanced and single-ended inputs
  • 2 x 200 / 1 x 800 watt bridgeable THX amplifier
  • Auto turn-on and power-sequencing circuitry
SDEC4500 Digital Equalizer / Active crossover
  • 12 x 20 channel input/output capability
  • 256-band parametric EQ with DSP time-alignment
  • Fourth-order electronic crossover networks for biamplification
  • Balanced and single-ended inputs and outputs
  • Fully balanced XLR/Phoenix SDEC EQ interconnects
  • Low-noise quad wire construction with full braid shield
  • Specifically designed for Synthesis systems
SAM1HF High-frequency Horn Module
  • 2-way design, constant directivity horn array
  • 3″ Aquaplas-treated aluminum diaphragm HF compression driver
  • 1″ Pure titanium Ultra-HF compression driver
SAM2LF Low-frequency Woofer Module
  • Dual 8″ aluminum cone drivers
  • Specifically designed for use with SAM1HF
S4Ai MultiPolar In-Wall Surround
  • Selectable Monopole/Bipole/Dipole configuration
  • Triple 1″ pure titanium diaphragm HF drivers
  • Dual 4″ cast-frame MF drivers
  • 8″ Dual-voice-coil, cast-frame LF driver
  • Flush-mounts into standard 2″ x 4″ stud walls
  • 18″ Aquaplas-treated fiber-composite cone
  • Front-firing ports for custom installation
SDP-40HD Surround Processor - Front
SDP-40HD Surround Processor - Back
SDEC4500 Digital Equalizer/Active Crossover
SAM1HF High-Frequency Horn ModulesSAM2LF Low-Frequency Woofer Modules
S1S-EX Passive SubwooferMark Levinson No 535H Multichannel Amplifier
JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
Chord Suzi Pre and Suzi Chord Suzi Pre and Suzi
Suzi by Chord Electronics delivers compact, modular high-end audio with a built-in phono stage, ULTIMA tech, and flexible DAC/streaming integration.
