Swann Security Home Series Alarm Range
Wireless, do-it-yourself alarms offer professional home security protection at an affordable price
Swann Security announced its first line of audible home security alarms with the Home Series Alarm Range. Designed to be used as standalone alarms or in conjunction with a Swann home surveillance solution, Swann's new Home Series Alarm Range is comprised of various alarms that emit a loud siren once a security breach has been detected. With an entire line of window, door and general motion detection alarms, Swann's Home Series Alarm Range is designed to give home owners peace of mind without the high-priced hassle of professionally monitored systems.
The home is most vulnerable at its entrances, specifically doors and windows, so Swann has created its Home Series Alarm Range to secure those points of entry. When the alarm sensors are activated via a door/window opening or motion being detected, an audible alarm is sounded to deter thieves and alert homeowners of a breach. Not only are these alarms designed to keep criminals out of the home, but they also help homeowners keep track of what is going on inside of the home. Customers, who have small children or are taking care of elderly parents, will gain peace of mind knowing that they will be alerted anytime a door or window is opened.
Window Alarm – Alarm sounds when there is an attempted forced entry
  • Sensor detects the vibration of a window during an attempted forced entry
  • Loud siren (110db+) provides strong deterrence against intruders
  • Easy to install — self-adhesive pad supplied, no tools required
  • Single push button for low battery testing
  • High/Low sensitivity selection & On/Off switch
  • Requires 4 “LR44” Alkaline batteries (included)
  • MSRP: $9.99
Magnetic Window Alarm – Compact magnetic alarm for discreet window/door protection
  • Powerful siren (110db+) sounds when windows/doors are opened
  • On/Off switch concealed under panel
  • MSRP: $9.99
PIR Motion Alarm – Passcode protected security alarm with motion detection
  • Passcode protected, powerful siren (110db+) sounds when any activity is detected by PIR movement sensor
  • 120 degree wide angle detection with multi-directional mounting bracket
  • 2 settings — chime sound (alert mode) & 110db+ siren (arm mode)
  • Easy to use with entry and exit delays & low battery indication
  • Requires 3 “AA” batteries (not included)
  • MSRP: $24.00
Magnetic Keypad Door Alarm – Passcode protected doorway security alarm with siren
  • Powerful siren (110db+) sounds when movement is detected by the magnetic sensor
  • Passcode protection allows authorized entry
  • MSRP: $19.99
Anti-Flood Alarm – Protect your home & property from water damage
  • Monitors areas for potential water leaks (laundry rooms under cabinet plumbing, hot water tanks, A/Cs, etc.
  • Alarm is triggered once water leakage or flooding is detected
  • Omni-directional sensor for fast & accurate water detection
  • Requires 2 “AAA” batteries (not included)
  • MSRP: $12.99
Ceiling Alarm – 360 degree motion detection with remote control
  • Unique smoke alarm design to maximize security effectiveness
  • Slim infrared remote control for On/Off and Chime/Alarm selection
  • Monitors a 360 degree area up to 9 feet
  • Powerful siren (110db+) has continuous sound level
  • 100% wireless — easy to install without impacting your home decor
  • Delay feature allows you to enter & leave without activating the alarm
  • Requires 3 “AA” batteries (not included) & 1 “CR2032” battery for remote control (included)
  • MSRP: $29.99
Wireless Doormat Chime – Know when someone's at the door with a pressure-activated doormat chime
  • Position under a mat or carpet to know when someone is there
  • Conveniently position the chime unit up to 100 feet away from the mat
  • Customize the unit with 3 unique chimes & adjustable chime settings
  • Pack includes doormat, chime unit and additional doorbell unit
  • Chime unit is both mountable and self-standing
  • Batteries last up to 6 months; requires 3 “AA” batteries (not included)
  • MSRP: $29.99
Swann's Home Series Alarm Range will be available this fall through Swann's network of retailers.
Anker Nebula X1 Projector
Go wireless with the Anker Nebula X1 projector—perfect for creating a backyard movie theater without the hassle of cords. Maybe one.
JL Audio C6-653cs Speakers for Ford F-150 JL Audio C6-653cs Speakers for Ford F-150
Car Speakers
Upgrade your Ford F-150's audio with Garmin's new JL Audio C6 three-way speakers and Stealthbox subwoofer. Experience powerful sound and custom fit for your...
Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black. Bowers and Wilkins Px7s3 headphones in Indigo Blue and Anthracite Black.
Some of our favorite over-ear wireless noise cancelling headphones are getting a major update. But will tariffs make these practically unaffordable in the United...
Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black Andover Audio SpinBase Max 2 Wireless Speaker under Turntable in Black
Designed to sit under any turntable, the $549 SpinBase MAX delivers room-filling sound with minimal footprint—ideal for vinyl lovers seeking performance and convenience in...
Roku New Products Unveiled - 2025 Roku New Products Unveiled - 2025
HDTV 4K & 8K TV
New Roku Streaming Stick and Streaming Stick Plus are Around 35% slimmer than the competition and can be powered by a TV's built-in USB...
LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds LG xboom with Will.i.am 2025 Bluetooth Speakers and Buds
Earbuds & In-Ear Headphones
LG adds "abracadabra" to their xboom product line with the Grab, Bounce, and Stage 301 bluetooth speakers and Buds, tuned by will.i.am
