SVS’s Ultra Evolution Flagship Speakers Are Now Shipping
From $899 to $4,999/pair, the new top-of-the-line SVS Ultra Evolution loudspeakers raise the bar for affordable home theater performance.
SVS Ultra Evolution Pinnacle Loudspeakers
At CES 2024, we got a first look (and listen) at the new SVS Ultra Evolution Loudspeaker Series. Their 5.2.2 Dolby Atmos home theater demonstration was the talk of the show; which is rather hard to accomplish in the rather cavernous LVCC with so much noise. There is no question that the new range offers excellent performance and that one can configure a wide range of systems to match your space at home.
As of today (March 26, 2024) five of the seven new SVS Ultra Evolution loudspeakers are now available for purchase. The new models include three new floorstanding speakers and two new bookshelf speakers sharing the same design features and form factors with varying driver and cabinet dimensions.
A dedicated three-way center channel speaker and versatile Ultra Elevation surround sound/Dolby Atmos speaker round out the line-up.
SVS Ultra Evolution Nano Stand-mount Loudspeakers
What is Ultra Evolution?
Ultra Evolution is the ultimate expression of SVS speaker design. The fusion of acoustic engineering breakthroughs and passion for audio excellence elevates the new series into the echelon of the finest loudspeakers in the world.
At first glance, the most striking design feature is the acoustically centered time alignment cabinet architecture. A curve in the front baffle aligns the sound emanation point of the tweeter and each driver on a vertical plane ensuring sound from each driver arrives at a listener’s ear in the exact same instant. This maximizes phase coherence for a more convincing and immersive soundstage with pinpoint accuracy and imaging.
SVS Ultra Evolution Pinnacle Time Alignement Comparison
For the tower models specifically, midrange drivers and woofers positioned above and below the tweeter allow for seamless crossover blending to create an idealized “point-source” where sound flows from a single point in front of the speaker to optimize dispersion characteristics.
New Tweeter
The diamond-coated aluminum dome tweeter is also completely new for SVS. Using a modern technology called vapor deposition, a layer of diamond carbon is grown on the surface of the aluminum dome to improve rigidity and critical acoustic properties. This breakthrough in material science raises the frequency response well beyond the limits of human hearing resulting in effortless, airy, and unveiled highs with no measurable distortion. It also pushes low frequency extension of the tweeter deeper for more seamless blending with the midrange.
SVS Ultra Evolution Tweeter Exploded
SVS Ultra Evolution Center Speaker
No detail was left to chance in the Ultra Evolution speaker design as evidenced by the organic cell lattice tweeter diffuser. While its main purpose is to protect the tweeter from physical damage, SVS engineers prototyped dozens of grille patterns to determine which provided the best acoustic performance. Through FEA analysis, a semi-random pattern derived from organic cell structures was chosen for its optimized off-axis frequency response and dispersion characteristics.
New Woofer Arrangement
Owing to the SVS subwoofer design pedigree is a new woofer execution in the three Ultra Evolution floorstanding speakers. Similar in design to the brand’s 3000 Micro Subwoofer, dual opposing active woofers on the top and bottom of the cabinet arranged in a force-balanced array render effortless low frequency response while addressing room modes.
SVS Ultra Evolution Pinnacle, Titan and Tower Loudspeakers
SVS Ultra Evolution Pinnacle, Titan and Tower Loudspeakers (left to right)
By having eight woofers from a pair of speakers, all firing in unison in different directions; deep, authoritative bass fills the listening area, smoothing out peaks and nulls. Mechanical energy from each front-firing woofer is equaled inside the cabinet by the rear-firing woofer, thus eliminating mechanical coloration. This results in pure, accurate low frequencies at any playback level.
Midrange drivers and woofers across all models feature glass fiber composite cones chosen for the superb stiffness-to-mass ratio and ability to convey stunning dynamics and pinpoint tonal accuracy. Separate, acoustically tuned internal chambers for the midrange drivers enhance separation and eliminate the potential for cabinet resonances, resulting in pristine sound across the frequency spectrum. Precision-cast aluminum-alloy baskets ensure precise alignment of critical components and maximize thermal dissipation.
SVS Ultra Evolution Pinnacle, Titan and Tower Loudspeakers Rear
Rear view of SVS Ultra Evolution Pinnacle, Titan and Tower Loudspeakers (left to right)
Also notable on the new speakers are chamfered front baffles to minimize edge diffraction for optimal off-axis frequency response. Crossovers feature premium-grade capacitors, inductors, resistors, and heavy-trace printed circuit board.
Voicing of the new Ultra Evolution is timbre-matched to all other SVS Prime and original Ultra models so users can mix between the three series to create a system. All speakers include detachable neodymium magnetic grilles. Elastomer bumper feet and metal spike feet attachments are available for tower models.
SVS Ultra Evolution Home Theater in White
SVS Ultra Elevation on the ceiling with Ultra Evolution Titan and Center in white.
The Ultra Elevation speaker is the highly anticipated upgrade to SVS’ popular Prime Elevation speaker. Featuring an angled front baffle and multi-angle bracket that allows for easy mounting on a ceiling or wall, Ultra Elevation offers unrivaled fidelity and placement flexibility letting users bring immersive Atmos speaker sound to any room.
“Ultra Evolution redefines what’s possible in its price range and well beyond by creating audio experiences that transcend their class and bring reference performance to more people than ever,” said Gary Yacoubian, SVS President. “I am so incredibly proud of what our design team accomplished. We really had no constraints and left no stone unturned. These new speakers represent the culmination of all our life’s work, and it shows in every aspect of design and performance. The sound is addictive, I literally can’t stop listening to them!”
Price & Availability
Ultra Evolution Nano and Ultra Evolution Tower models will ship later in Q2.
Finish options will be limited at launch. All models will soon be available in Piano Gloss Black, Piano Gloss White, and Premium Black Oak Wood Veneer finishes.
Tip: Which SVS Subwoofer Should You Buy?
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Whether you’re hunting for rare records or just enjoying the vibe, Amsterdam on RSD is the place to be.
Discover the best vinyl record storage systems under $500 in 2025—stylish, functional, and built to protect and display your growing LP collection.
HDTV 4K & 8K TV
With economic markets in turmoil, Sony just announced pricing for their new 2025 BRAVIA TVs and the news isn't great.
Looking to preserve your records for a lifetime of listening? A quality record cleaning brush is the first step. Here are our top picks...
The Totem Tribe Tower Thunderbird speakers combine bold design with innovative engineering to deliver exceptional sound in any room, even those with acoustic challenges.
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
For those about to rock, Sony salutes you... with three new Bluetooth wireless speakers and a cool wireless microphone kit.
Explore Craft Recordings' Record Store Day 2025 preview featuring exclusive releases from Carla Thomas, Thelonious Monk with Gerry Mulligan, and the Jazz Dispensary Night...
