A/V Furniture & Accessories
SVS SoundPath Tri-Band Full-range Wireless Transmitter Unveiled
$199 SVS SoundPath Tri-Band wireless audio transmitter / receiver combo wirelessly connects subwoofers or powered speakers, even in congested wi-fi signal areas.
SVS SoundPath Tri-band Wireless Audio Adapter Above on Product Packaging Box
SVS today announced announced a $199 accessory that transmits a wireless audio signal to any powered subwoofer or speaker. The new product called the SVS SoundPath Tri-Band Wireless Audio Adapter sends a LFE or full-range stereo signal at 16-bit/48KHz up to 130-feet line-of-site. For improved fidelity without dropouts, it claims ultra-low latency and auto-switching between three bands for use in crowded wireless signal areas where single-band wireless transmitters are prone to interference.
SVS SoundPath Tri-band Wireless Audio Adapters Transmitter and Receiver
The SVS SoundPath Tri-Band Transmitter and Receiver have same inputs and connections.
Because the SVS SoundPath Tri-Band adapter transmits a true Left/Right stereo signal at full-range frequency response (6 Hz to 20kHz +/- 0.5 dB), the adapter also wirelessly connects a stereo speaker zone and powered wireless surrounds in home theater applications. Up to three adapters can be paired simultaneously to create a multi-room distributed audio system.
The SoundPath Tri-Band Wireless Audio Adapter reduces cable clutter and expands subwoofer placement options without sacrificing sound quality. Placement is a critical factor in subwoofer performance and the new adapter creates more possibilities to optimize in-room output.
SVS SoundPath Tri-band Wireless Audio Adapter Box Contents
What’s in the box: SVS SoundPath Tri-band Wireless Audio Adapter
“As people add more devices to their homes, interference becomes a real issue. The Tri-Band technology our engineers deployed makes wirelessly connecting a subwoofer or powered speakers completely impervious to interference, while reducing cable clutter. It really solves a lot of problems when setting up a home theater or audio system.”
Gary Yacoubian, SVS President and CEO
Setup
SVS SoundPath Tri-band Wireless Audio Transmitter Connected to A/V Receiver
Setup of the adapter is said to be simple and quick. All current SVS subwoofers like the 3000 Micro feature USB inputs on the rear panel for powering the SVS SoundPath Tri-Band Wireless Audio Adapter’s receiver. Once both transmitter and receiver are powered, simply connect the transmitter to an AV receiver, TV audio output, or other audio source via RCA interconnect. Then, connect the receiver to a subwoofer, powered speaker, or loudspeaker amplifier via RCA Interconnect. The transmitter/receiver arrive pre-paired so wireless signal transfer begins within seconds.
Key Specifications
  • Frequency Response: 6Hz – 20 kHz +/- 0.5 dB
  • Operating Frequencies: 2.4 GHz, 5.2GHz, 5.8 GHz
  • Transmission Range: 130 feet (line of site)
  • Latency: <19 microseconds
Price & Availability
The SVS SoundPath Tri-Band Wireless Audio Adapter is available now for $199.99 at svsound.com.
For areas without wi-fi interference, SVS offers the single band SoundPath Wireless Audio Adapter for $119.99 at svsound.com.
Campfire Audio Alien Brain IEMs Front and Back
Earbuds & In-Ear Headphones
Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases Cleer Audio ARC 3 Sport Pro Open-Ear Wireless Earbuds Lifestyle Use Cases
Priced at $259.99, the Cleer ARC 3 Sport Pro, are open-ear true wireless earbuds with a built-in SPO2 sensor, heart rate monitor, and Dolby...
Samsung S95F Flagship OLED TV for 2025 Samsung S95F Flagship OLED TV for 2025
HDTV 4K & 8K TV
We can tell you how much Samsung's latest OLED and Frame Pro TVs and new soundbars cost. But don't ask us how they look...
Priced from $1,999, two new 15-inch SVS 5000 R|Evolution Subwoofers are just one step down from the flagship 17-Ultra Series.
SVS will showcase their flagship Ultra Evolution home theater speaker system for T.H.E. Film Festival movie screenings.
Audio Cables
At £600, the EE1 Plus is designed to reduce interference and noise on wired networks, but do you really need it?
Ask an Expert
The ultimate guide to choosing a SVS subwoofer for home theater or high fidelity music listening? All 16 models compared!
2024 Black Friday tech deals you won't want to miss on hi-fi, headphones, and home theater gear this Holiday Season.
Mixed in with the robots, electric cars, AI solutions, VR headsets and smart glasses, we found these exciting and innovative audio/video products that hit...
After three days roaming the hallowed halls of CEDIA Expo 2024, here are our picks for "Best in Show."
Improve the performance of your stereo or home theater system with our favorite subwoofers from RSL, SVS and JBL for any budget.
