A/V Furniture & Accessories
Preview: SVS Introduces the SoundPath Speaker Level Subwoofer Adapter
This $79.99 accessory helps connect a powered subwoofer from audio components that don’t have a subwoofer output.
SVS SoundPath Speaker Level Adapter Audio Out Connected
SVS is well-known for its subwoofers and speakers, but it also offers a selection of connectivity solutions under its SoundPath label that makes setting up your audio and home theater systems easier.
The latest connection solution from the SVS SoundPath line is the Speaker Level Subwoofer Adapter.
What is the SVS SoundPath Speaker Level Sub Adapter?
Many integrated amplifiers and legacy stereo receivers lack line-level RCA outputs for a subwoofer. This means that it is ordinarily not possible to connect a powered subwoofer to older audio systems.
This adapter converts speaker-level outputs to RCA line-level outputs for safe, pristine signal transfer to a powered subwoofer.
The SVS SoundPath Speaker Level Subwoofer Adapter solves this problem by stepping down the voltage from a speaker-level connection to RCA line-level voltage. The supports a safe connection with no loss of fidelity and no additional power drawn from the amplifier for use with a subwoofer.
How To Use The Subwoofer Adapter
SVS SoundPath Speaker Level Adapter Setup Diagram
For connection from the speaker outputs of a receiver or amplifier to the inputs on the Subwoofer Adapter, 24K gold-plated 5-way speaker-level binding posts that can accommodate bare-wire, spade, or banana connectors are included.
Tip: SVS SoundPath Bi-wire Speaker Cable can be used for an easy connection to both the loudspeaker amplifier and the adapter as well.
SVS SoundPath Speaker Level Adapter Audio In
Size: 1.5” (37 mm) H x 3.9” (99 mm) W x 4.1” (103 m) D
From the Adapter to the Subwoofer, 24K gold-plated stereo RCA line-level output jacks are provided to ensure a secure connection to the line-level inputs of the powered subwoofer
Tip: SVS SoundPath RCA Subwoofer Cables can be used between the Adapter and the powered subwoofer you are connecting to.
Once all is connected, users can then adjust the low pass filter/crossover and other settings on the subwoofer for optimal performance with their legacy system.
Tech Note: According to SVS, the Subwoofer Adapter can pass full range signal from 10Hz – 80kHz (+/-0.01dB) – although subwoofers rarely need anything higher than about 300Hz.
What’s Inside
Internal components of the Subwoofer Adapter include premium-grade narrow-tolerance resistors and wide-trace PCBs for high-current and extreme power handling. This is designed to yield wide bandwidth and ultra-low distortion for pristine signal transfer, pinpoint accuracy, and compatibility with high-end audio systems.
From Gary Yacoubian, President, SVS: “The SVS SoundPath Speaker Level Subwoofer Adapter is a true problem solver for audio fans, and like with all SVS accessories, it does it in the most high-fidelity way possible,…Vintage audio gear is experiencing a comeback and we’ve seen a big uptick in demand for people wanting to connect SVS subwoofers to legacy components. We went through an incredibly rigorous design process to ensure performance will exceed the expectations of discerning audiophiles and HiFi enthusiasts.”
Audio out RCA cables connect directly into a powered subwoofer.
Initial Impressions
For those who own older amplifiers or receivers and would like to add a powered subwoofer to their setup, the SVS SoundPath Speaker Level Subwoofer Adapter is one way to do it. If your receiver or amp has A/B speaker connections and you set it to run the A and B sides at the same time, you can use the A side to run your main speakers and use your B side to connect the Subwoofer Adapter – which, in turn, can connect to a powered subwoofer. Just like that you can turn your old two-channel stereo system into a 2.1 channel setup.
A very practical product and it is not outrageously expensive.
Price & Availability
The SVS SoundPath Speaker Level Subwoofer Adapter is available now for $79.99 direct from SVS.
Related Reading
iFi iDSD Valkyrie DAC/Headphone Amplifier
K2HD Technology, DSD Remastering, 5,700mW peak output, lossless Bluetooth, and 18-hour battery life are just some of the features of the iFi iDSD Valkyrie.
UberLight Frame LED Light Lifestyle UberLight Frame LED Light Lifestyle
With 500 lumens of LED lighting across a slim beam, no dust or dirt on your vinyl records can hide from the UberLight Frame.
Audiolab 6000A MKII Integrated Amplifier Lifestyle Black Audiolab 6000A MKII Integrated Amplifier Lifestyle Black
After 7 years, Audiolab has replaced the classic 6000A with the MkII iteration. New toroidal output transformer, 32-bit ES9038Q2M ESS Sabre chip, and HDMI...
Sennheiser HD 550 Headphones Sennheiser HD 550 Headphones
Gaming is driving the headphone market and Sennheiser's new HD 550 might be a fantastic option below $300 for audiophiles and gamers.
JBL Synthesis SMA-8300 and SMA-4750 Stacked JBL Synthesis SMA-8300 and SMA-4750 Stacked
Lots of power, bridgeable configuration options, and rack-compatible sizes add flexibility to any custom home theater setup.
Rega Brio MK7 Integrated Amplifier Rega Brio MK7 Integrated Amplifier
Rega's forthcoming Brio MK7 Integrated Amplifier will be available this month and is creating a stir with its internal DAC for only $1095.
These Quadraphonic albums have been digitized from analog four-track Quad mixes and are now available on Blu-ray discs.
Craft Recordings announces seven titles coming to participating independent music retailers on Record Store Day, April 12, spanning jazz, salsa, rock and soul.
Daily Deals
Spring time is here and with it the opportunity to bring home a giant TV at a great price to enjoy all the basketball...
The award-winning Focal Bathys wireless noise cancelling headphones arrive in a new black color option for $699, the same price as before.
Is it possible to make Hi-Fi and home theater work in really small spaces? EIC Ian White's journey into the great unknown of cabin...
Over-Ear Headphones
Are the Grado Signature S950 really that different? Two significant changes to their design and a more balanced sonic approach make them an emotional...
The Quality of Physical Media, The Convenience of Digital Download.
Headphones
An affordable electrostatic headphone? The STAX SR-X1 makes that a real possibility for those who have always wanted to experience what makes them unique.
